Old 11-04-2019, 09:10 PM #61
VernySanders's Avatar
VernySanders VernySanders is offline
Real Name: Werner
VernySanders will become famous soon enough VernySanders will become famous soon enough
Real Name: Werner
Originally Posted by brillo_76 View Post
Wow. I know you can save the trannys if you exchange the fluid quickly. I seen one do this and we exchanged the fluid and it's still going. The pan magnets should be cleaned and filter changed as well. I still waiting with popcorn on the OP thread here..
Welp... massive failure.
JK!!! Hahaha shes running great, went and got an alignment this weekend, the place snapped my tie rod so replaced both inners for free using napa parts. I was fond of this because I personally dont want to waste any money on OEM spec parts as I'll be going longtravel this spring. So far so good even with the 33s on it. I have noticed I drive with overdrive off a lot more now. More pep. I have a cold air intake a high flow cat I deleted the second cat and simulated the o2 to a 3 inch exhaust to a borla XR1 dumped before the axle. So much more power than when I first bought the truck. I've been contemplating engine and trans swap options or header / supercharger options. If I do an engine trans swap it's going to be something v8. Sad to say but probably Chevy. LS. Anyhow all that is off topic lol
VernySanders is offline   Reply With QuoteReply With Quote
fluid , noise , oil , pump , trans
HELP! Sounds TURRIBL after timing belt & water pump Double0-12 3rd gen T4Rs 20 03-30-2019 12:03 AM
4.7 sounds like supercharger on cold start. Not the air pump bubbazr2 4th Gen T4Rs 3 04-22-2017 12:13 AM
Sluggish cold start, suspect fuel pump NEED ADVISE T4Rscott 3rd gen T4Rs 13 01-06-2015 05:20 PM
V8 start up sounds GMZ 4th Gen T4Rs 2 11-17-2012 08:39 PM
Why doesnt my 4runner start when its cold...it will start with some gas pedal 96boo2 3rd gen T4Rs 1 03-07-2007 10:56 PM
