Old 10-14-2019, 02:27 PM #1
Cvett95 Cvett95 is offline
Cvett95 is on a distinguished road
What Should I do? - Front End Damage
One of the biggest things thatís held me back from completely modifying my front end is the damage caused by one of the previous owners The bumper support arm on the passenger side along with the bumper itself is bent/bowed respectively and rusting quickly. I had the frame looked at by a buddy who worked for a frame shop before he moved to S. Africa who said there is a miniscule bend in the frame rail but is not a hazard nor does it cause alignment/tracking issues, so Iím not interested in swapping frames/build up a new truck.
As for an approach to all this, I was thinking of torching/hammering the arm mount back into place as best I can using the opposite support arm/new OEM bumper to test fit and then welding a support from the rail mount to the new arm.
That's my best guess. Any constructive input is greatly appreciated.
Here are a few pics: Bumper Damage - Album on Imgur
Ď97 SR5 2x4 177k | Front: Bilstein 5100+toytec 600# /Rear: Fox 2.0 Performance Series Struts+SuperFlex coils, JBA UCA, Whiteline LCA bushings, OEM Ball Joints, Tie Rods, and Front Links, 2nd Gen Rear Links, T-Belt, T-Stat, Water Pump, B&M 70268, 295/70/17 Nitto Trail Grappler Wrapped GX470 wheels, UltraGauge, Trans Temp Gauge, HID Retrofits, Recycled Barn-Door Cargo Drawers, Home-made Doggy Divider, Satoshi Inspired Grille, Max-life ATF, Toyota Red Coolant, 5w-30 Pennzoil Ultra Platinum w/20% HD Hyper-Lube, eBay Window Visors, Tint, $20 Walmart Keyless Entry, Cheap Alpine H/U and Speakers, Bed Lineríd frame, and a whole bunch of fishing gear.
Cvett95 is offline   Reply With QuoteReply With Quote
Old 10-14-2019, 03:22 PM #2
Joelzy's Avatar
Joelzy Joelzy is offline
Joelzy is just really nice Joelzy is just really nice Joelzy is just really nice Joelzy is just really nice Joelzy is just really nice
Joelzy's Avatar
my front end was toast when i got my 4R, bumper was creased and pushed back into the condenser and radiator, both of those bumper mounts were bent all to hell.
I found the bumper only for 50 bucks and the mounts on a Pick-N-Pull 4R for like 5 bucks but im sure they are for sale online somewhere. I would usually be the guy to try and bend it back out but i would bet they are cheap and you wouldn't have to mess with it.
Ė96 SR5 5SPD Elocker "the Barnacle"
Ė02 bmw 540i6
Ė19 Highlander SE
Joelzy is offline   Reply With QuoteReply With Quote
Old 10-14-2019, 04:02 PM #3
BrianK14 BrianK14 is offline
BrianK14 is on a distinguished road
I've got an OEM chrome bumper I'll sell you. And I'll even through in the mount brackets, no charge.
BrianK14 is offline   Reply With QuoteReply With Quote
Old 10-14-2019, 05:06 PM #4
phattyduck is a splendid one to behold phattyduck is a splendid one to behold phattyduck is a splendid one to behold phattyduck is a splendid one to behold phattyduck is a splendid one to behold phattyduck is a splendid one to behold phattyduck is a splendid one to behold phattyduck is a splendid one to behold
The bumper mount does look a bit bent, but not crazy bad. Just get a replacement bumper with brackets and bolt it on. There is some adjustment room and you should be able to get it aligned and looking decent.
'16 Honda Odyssey
Old 10-14-2019, 05:15 PM #5
jross20's Avatar
jross20 jross20 is offline
jross20 will become famous soon enough jross20 will become famous soon enough
jross20's Avatar
Buy an ARB deluxe
Then get some steel plates
Then...
Old 10-14-2019, 05:30 PM #6
brillo_76's Avatar
Real Name: Jon
brillo_76 is a splendid one to behold brillo_76 is a splendid one to behold brillo_76 is a splendid one to behold brillo_76 is a splendid one to behold brillo_76 is a splendid one to behold brillo_76 is a splendid one to behold
brillo_76's Avatar
Real Name: Jon
I have just like that bent. What I am going to is just cut the bracket off and weld on a new one. Mine actually bent the one side of the bracket in. See what Braink wants for that oem bumper and brackets before I ask him to send it to me for my Tetanus 2...:P
1997 4X4 V6 5 Speed Sr5 4 Runner (97 5 speed )
1997 4X4 V6 Red limited 4 Runner (97 Limited)
1998 4X4 V6 Sr5 Red 4 Runner (98 Tetanus1 )
1998 4X4 V6 Sr5 Silver 4 Runner (98 Tetanus2)
2001 4X4 V6 Sport Green 4 Runner (01 Green Sport)
Old 10-14-2019, 08:17 PM #7
@BrianK14 How much are you wanting for the bumper? Even if it were an irresistible deal, we live quite a ways away and I'm sure shipping wouldn't be cheap.
Old 10-14-2019, 08:18 PM #8
BTW thanks for all of the input guys
Old 10-14-2019, 10:39 PM #9
brillo_76's Avatar
Real Name: Jon
brillo_76's Avatar
Real Name: Jon
That's what we are supposed to do. Help each other out so that we can keep some of the 3rd gen alive...
arm , bumper , frame , mount , support
Front end damage jminn723 3rd gen T4Rs 15 06-12-2020 08:34 PM
Front end Damage Repair Atoyot Rennur4 3rd gen T4Rs 18 11-25-2018 09:09 AM
99 sr5 4x4 with front end damage Chrizzouse For Sale: Vehicles 0 01-28-2016 10:36 PM
Front-end Damage fdjrtr 5th gen T4Rs 14 04-02-2014 02:56 PM
front bumper damage monson770 3rd gen T4Rs 0 02-13-2011 02:34 PM
Feedback Buttons provided by Advanced Post Thanks / Like (Lite) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
