Old 10-14-2019, 11:40 PM #1
Chmteacher Chmteacher is offline
Chmteacher is on a distinguished road
Newbie with a leak
Hi everyone,
Just bought a '98 4x4 that has a small tear in what I'm guessing is the rack and pinion boot/bellow. There is a small amount of light brown fluid dripping from the spot but steering seems fine.
1) how quickly do I need to repair this?
2) is there a way to tell if I can just repair the boot?
Thanks so much!
Newbie with a leak-2-jpg  Newbie with a leak-1-jpg
Chmteacher is offline   Reply With QuoteReply With Quote
Old 10-15-2019, 12:34 AM #2
JohnOfTheJungle JohnOfTheJungle is offline
JohnOfTheJungle will become famous soon enough
The boot just covers the inner tie rod, so repairing it won’t stop a leak. The leak is probably coming from the seals inside the rack, which is common.
I’d say search the forums for how to flush your power steering fluid and go ahead and do that and clean your filter. Maybe there’s some stopleak you can try putting in, I don’t know never used any myself.
Then just monitor the leak, you can drive for years with it leaking. The only problem is it does wash out the grease for the inner tie rod, which over time can cause it to loosen up and make your steering sloppy.
It’s definitely not life or death, eventually you’ll probably want to get a new steering rack which is about a $500 part if you buy OEM and most of the day to change it if you’re running new lines like I did.
1997 Limited 4x4 3.4l 199k E-locker Blue Wire Mod | 255/85 r16 Maxxis Bighorn MT - LX450 9 wrap + Tokico black rear | Front: 2.5" King Coilover set @ 2" lift | True North Fab Front Bumper + Warn m8000 + Baja Designs Squadron Sport | Custom Sliders | NguyenWorks Rear Bumper + Tire Swingout
JohnOfTheJungle is offline   Reply With QuoteReply With Quote
Old 10-15-2019, 12:55 AM #3
pluton's Avatar
pluton pluton is offline
Real Name: Keith
pluton has a spectacular aura about pluton has a spectacular aura about pluton has a spectacular aura about
pluton's Avatar
Real Name: Keith
Agree with everything John said. If the Dexron-3 equivalent ATF is brown, it's long overdue for a change. It's supposed to be a cheerful pale red color. Easy job, many how-tos on here, easy to figure out. Cleaning the screen in the bottom of the reservoir is pretty easy also.
pluton is offline   Reply With QuoteReply With Quote
Old 10-15-2019, 01:06 AM #4
Thank you both very much! Happy to see how alive this forum is.
fine , quickly , repair , small , steering
She's taking a leak! Rear axle seal leak that is.... fightman80 3rd gen T4Rs 76 09-18-2014 04:52 PM
Coolant leak solution, pepper, eggs or liquid aluminum stop leak? BUGSEY General Discussions 1 01-30-2014 01:32 PM
Radiator leak, and oil leak maybe tranny? Not sure what should I do? ironmaidn23 Classic T4Rs 14 06-25-2013 10:34 AM
Newbie needs 94 valve cover leak help tautemarite New Members 0 12-16-2011 09:09 PM
Coolant leak, whining noise, vacuum leak, alternator, starter, battery issues Max O 3rd gen T4Rs 4 12-03-2009 10:31 AM
