Old 10-15-2019, 07:58 AM #1
ReconcileUs's Avatar
ReconcileUs ReconcileUs is offline
ReconcileUs is on a distinguished road
Question Is my climate control supposed to illuminate on ‘99 SR5
Hi,
Since I bought my truck used not too long ago, my climate control/AC cluster has never lit up in the dark when I turn on the lights.
I was wondering, do I just need to change the bulbs and fix it or does it not even light up?
ReconcileUs is offline   Reply With QuoteReply With Quote
Old 10-15-2019, 08:25 AM #2
dogtail's Avatar
dogtail dogtail is offline
Real Name: Keith
dogtail has a spectacular aura about dogtail has a spectacular aura about
dogtail's Avatar
Real Name: Keith
Yup, should lite up. Common for old bulbs to burn out. Best thing is to convert all dash lights over to LED. You can search on forum for write up and part numbers. I used Super Bright LEDs brand for mine.
*1999 3.4L, 4wd/5spd, swapped motor and trans, heavy use DD, seasonal rust proofing using WD-40 only
*2000 3.4L, 4wd/5spd, parts rig, picking the carcass
dogtail is offline   Reply With QuoteReply With Quote
Old 10-15-2019, 12:48 PM #3
Yes, I believe it is 2 #74 size bulbs for the climate controls. The 3 buttons above the climate control should also light up (rear window, ECT PWR and Defrost). Those are little mini bulbs that are harder to find...
'17 Chevy Volt Premier
'16 Honda Odyssey Elite
Old 10-15-2019, 01:28 PM #4
photoleif photoleif is offline
Real Name: Leif
photoleif will become famous soon enough
Real Name: Leif
like @dogtail , i used superbright LEDs for mine and got it illuminated again. when we got the vehicle, basically zero lights worked. the entire instrument panel was dark, dome light was out, fogs were out. there are lots of great writeups to show you how to do them all, and which bulbs to order. i ended up getting turn signal indicator lights (instrument panel) that are *too* bright, but will live with it for a while.
'99 'Highlander' 4R SR5 5VZ-FE | 5-spd | LED lighting | TBU | 265-75R17 Duratrac stuffed after some pinch-weld convincing
'95 Xtra cab 5VZ-FE swap 5-spd | 33x10.50-15 BFG AT/KOs | 4" Superlift | ARB rear locker | OME torsion bars | Total Chaos idler arm & uniball | Smittybilt bumpers | Sportsman topper | Aisin manual hubs | K&N | Dual Optimas | Extended diff breathers | Bilstein 5100s | De-striped | Hella pencil-beams
photoleif is offline   Reply With QuoteReply With Quote
Old 10-15-2019, 06:50 PM #5
APhelps APhelps is offline
APhelps has a spectacular aura about APhelps has a spectacular aura about
I find a lot of LED bulbs (the ones I've used) can tend to be too bright for the application.
I've noticed that a few of the sockets don't seem to work nearly as well as they use to though even when using the right bulb.
APhelps is offline   Reply With QuoteReply With Quote
Old 10-15-2019, 08:12 PM #6
dogtail's Avatar
Real Name: Keith
dogtail's Avatar
Real Name: Keith
Well the dimmer allows you to set the dash lights to the brightness you want. Does your dimmer work? I know you have to pay special attention to seating the sockets well. I had to pull my cluster out once or twice to re-seat them right on install so they would all work. But all has been good since my install, I like the light level on mine. You could go with an amber color LED to tone it down as apposed to a bright white if you want.
Old 10-15-2019, 10:00 PM #7
I suppose if you change out every bulb that will work. I had some LEDs as my turn signals for a short while and it was blindingly bad.
Old 10-16-2019, 07:36 AM #8
dogtail's Avatar
Real Name: Keith
dogtail's Avatar
Real Name: Keith
Yeah I don't think hardly any people change out to LED for dash turn signals and idiot lights, not needed and too bright. Those lights don't really burn out cause they're not turned on that much. LED is good for dash and cabin lighting. For dash lighting you can totally dial it in to your preference with the dimmer.
Old 10-20-2019, 12:00 PM #9
Question
Hi. I want to thank everyone that replied for their help. I love this forum. I have the climate control bulbs figured out. The glove box bulb is also the same #74 as the climate control.
Now I'm trying to figure out about the dash bulbs. I want to change the bulbs for my speedometer and RPMs to LED. I'm goona search but based upon my previous search I feel like the information regarding the dash and climate bulbs is very hard to come by and has a lot of dead links, compared to other things. SuperBrightLEDs has a good website though.
edit: LED Dash lights FAQs - Toyota 4Runner Forum - Largest 4Runner Forum
guess I'm all good.
Old 10-24-2019, 11:45 AM #10
3bears 3bears is offline
Real Name: 3 Bears
Real Name: 3 Bears
\been a while since I have driven at night, and noticed those bulbs are burned out, (rear window, ECT)...any idea bulb number
Old 10-24-2019, 11:49 AM #11
NEOx
Old 10-24-2019, 12:39 PM #12
Real Name: 3 Bears
Real Name: 3 Bears
Originally Posted by ReconcileUs View Post
thanks
Old 10-24-2019, 09:13 PM #13
JRZEE2000TR4LTD's Avatar
JRZEE2000TR4LTD JRZEE2000TR4LTD is offline
Real Name: John
JRZEE2000TR4LTD will become famous soon enough JRZEE2000TR4LTD will become famous soon enough
Real Name: John
thanks
Specifically like these 3mm (the size of the "hole") in any flavor. You'll need 2
NEOx LED Bulb - High Power Instrument Panel LED | Super Bright LEDs
SILVER 2000 4runner Limited TOTALED
WHITE/SILVER 1999 4runner Limited l Rear Locker l Tundra/890 coils | 5100 Bilsteins all around | Sonoran Steel Bumpstops l 199 mm Tundra brake upgrade | SCS Matte Gray Ray10 Rims | 275 70 17 BFG KO2 tires | LR UCAs | EIMKEITH panhard brackets | LED interior upgrade l Rear LED tailights l Pioneer AVH-X5700BHS Alpine Type "R" speakers NVX JAD800.4 Class D Amp Kenwood Under seat Subwoofer l Front window tint 20% l Weathertech window visors and floormats l OutGear Solutions Full Length roofrack l Morimoto 40" LED lightbar
JRZEE2000TR4LTD is offline   Reply With QuoteReply With Quote
Old 10-25-2019, 01:01 AM #14
MarkBlack's Avatar
MarkBlack MarkBlack is offline
Real Name: 1997 4RUNNER
MarkBlack is on a distinguished road
MarkBlack's Avatar
I'm glad you asked the question! I just assumed there wasn't any lights!
MarkBlack is offline   Reply With QuoteReply With Quote
climate , dark , lights , turn , wondering
Hilux Surf climate control = 4runner climate control? CDNsurf 3rd gen T4Rs 4 02-27-2015 08:27 PM
Is the line on the 4WD knob supposed to illuminate on SR5? genec 5th gen T4Rs 19 01-01-2014 09:46 PM
Is the E-locker switch itself supposed to illuminate? Stretch1100 3rd gen T4Rs 8 11-03-2011 11:35 AM
new climate control, will this give me dual climate control? 4Runner8 4th Gen T4Rs 4 10-20-2010 11:33 PM
'02 Upgrade standard climate control to auto climate control unit? bradym239 Engines / Suspension / Wheels / Tires / Audio / Accessories 4 06-10-2004 01:37 PM
