Here this may help. Your ignition may be jammed up from initially trying bent key, if the door locks work ok, this may be the case. Its common thing in many cars and they can be un-seized, this is where the steering wheel locks up and ignition wont turn.
You can spray in penetrating oil, (Triflo is recommended but WD-40 too if you cant get any), lightly tap on the key with a hammer and try turning the wheel. I helped a stranger I met on on side of road stuck with this very problem, got him started and he was able to drive away.
Here is a full video on a walk thru on this method, and shows you on cylinder removal as last resort.
YouTube
