Old 10-16-2019, 08:17 PM #1
3rzrunner's Avatar
3rzrunner 3rzrunner is offline
3rzrunner is on a distinguished road
3rzrunner's Avatar
Higher RPM Tach gauge...
Hey guys. Been away for a while as the runner has been sitting while I gather all my needed parts for the engine build.
I have somewhat of an odd question.
Is there a tach that I can easily drop in that maintains the original cluster and has a higher max rpm reading? Ours currently goes to 7. I was looking for something that will have divisions up to 8K or 8.5K...
Thanks !!
Higher RPM Tach gauge...-139fba2c-e680-4b89-aae1-eaf58489931b-jpg
1997 SR5 4WD 3RZ/5spd. Evergreen Pearl/Oak. Elocked. 4.56 Toyota Gearing. Full body resto/Custom 3 Stage "Tri-Coat" 751 paint job. 2.5" OME lift/w Bilstein Shocks. JAOS Spoiler. Duratracs. Custom Taco Rims. EBC Brakes. SS Braided lines. Marlin Crawler Trans & parts. Marlin HD clutch. URD short shift kit. 1st Gen Shift Knobs. MStudt's endlinks. JBA SS exhaust. LCE Headers. K&N. 140A CS144 alt. Big 3/4 wiring. Hella/PIAA Lighting. 2nd Gen Map Light Mod. Custom LED switchback DRL/Turnsignals. 32" Curved LED bar. Front Tint. A/D/S/ Stereo. SoundProofed. RangeRover seat swap. 99 Clears. A/C. PWR everthing. EastWood Frame coating. AMSOIL. Custom sleeping solution.
3rzrunner is offline   Reply With QuoteReply With Quote
Old 10-18-2019, 01:39 AM #2
3rzrunner's Avatar
3rzrunner's Avatar
Bumppp
Old 10-18-2019, 01:46 AM #3
UnderFire's Avatar
UnderFire UnderFire is offline
UnderFire has a spectacular aura about UnderFire has a spectacular aura about UnderFire has a spectacular aura about
UnderFire's Avatar
I can't think of anything off the top of my head. Only possibility I can think of is a 3UZ powered Lexus, but I don't know what the factory redline would be.
Sent from my JSN-L23 using Tapatalk
'97 3RZ 5 Speed "FrankenRunner" (Build Thread) - Dormant
The "shitmobile" 500$ 3RZ Auto 4Runner - (Saved from the Scrapyard: Resurrecting a 500$ 3rd Gen
02 Tacoma Double Cab, mid-travel, locked, armored, supercharged and riced. (Longbed and 5 speed in the works)
UnderFire is offline   Reply With QuoteReply With Quote
Old 10-18-2019, 08:42 AM #4
jross20's Avatar
jross20 jross20 is offline
jross20's Avatar
Why do you want to do that?
Old 10-18-2019, 01:12 PM #5
There probably isn't an off-the-shelf option available. If you can get a custom gauge face made, you can probably tweak the response of the tach to match it by modifying some resistor values on the tach driver...
I have previously modified a tach to respond to a different voltage level, the frequency response is probably also modify-able...
Camry tachometer testing - YouTube
'17 Chevy Volt Premier
'16 Honda Odyssey Elite
Old 10-18-2019, 01:15 PM #6
APhelps APhelps is offline
APhelps has a spectacular aura about APhelps has a spectacular aura about
I wonder if you could use something like a gauge from a 93+ Mr2 Turbo. You'd need to find out the voltage going into the cluster so you can determine where the tachometer is and go from there. Without really looking into it i believe the voltage is what determines the speed at the tach.
APhelps is offline   Reply With QuoteReply With Quote
Old 10-18-2019, 01:27 PM #7
There will be an IC on the tach driver board that converts RPM pulses (one per spark plug firing, generally) to a voltage that drives the needle. Newer vehicles than a 3rd gen will use stepper motors and microcontrollers, usually just sitting on the CAN bus (no dedicated tach wire).
Old 10-18-2019, 01:31 PM #8
gamefreakgc's Avatar
Real Name: Jerod
Real Name: Jerod
That's a tricky one. I'm not aware of any tachs that can be swapped in and chances are it'll cause a headache for the ECU with the signal. Not like 2nd Gens where the tach is literally just spun by a cable. Or maybe that was the odometer.
I'm assuming you have a standalone since that's the only way to spin that engine higher than 6K or so. Why not just use the tach output signal and just replace with a gauge pod or try any retrofit one into the existing 4Runner's gauge cluster?
326WHP 347TQ
Old 10-18-2019, 02:16 PM #9
gotcha. Yeah its certainly not going to be a trivial task and one that's going to require a good bit of leg work to do.
The CAN bus is an interesting thing, not overly complex (if you ask me) but definitely not as easy as the old school way.
Old 10-19-2019, 09:06 PM #10
3rzrunner's Avatar
3rzrunner's Avatar
in the process of building my 500hp+ turbo 3RZ. I would like to redline at 7500-8k, shift at 7k.
Old 10-19-2019, 09:10 PM #11
3rzrunner's Avatar
3rzrunner's Avatar
yeah, I haven't seen much that can be either glued overtop the stock face or swapped in. was just looking for an idea before considering more extreme options.
I have a Haltech elite 1500, I have thought about it but also want to retain some of the stock interior look, plus I want to be shifting around 7K, once in a while be able to hit 7500-8K....
as well as my double pillar pod is already going to be full with boost+AFR..
Old 10-19-2019, 11:17 PM #12
Kanoe's Avatar
Kanoe Kanoe is offline
Kanoe is just really nice Kanoe is just really nice Kanoe is just really nice Kanoe is just really nice
Kanoe's Avatar
Holy Sh!t. I hope you will be sharing some of that with us!
-1993 Corolla Wagon 7AFE
-2001 Echo D.D.
Kanoe is offline   Reply With QuoteReply With Quote
Old 10-20-2019, 01:40 AM #13
UnderFire's Avatar
UnderFire's Avatar
That's a whole lot of RPM for an RZ. Better be doing a lot of valve train work my man. Bust out the big wallet lol.
Old 10-20-2019, 11:14 AM #14
jross20's Avatar
jross20's Avatar
Isn't that the 4 cylinder?
Old 10-20-2019, 12:09 PM #15
3rzrunner's Avatar
3rzrunner's Avatar
For sure. Here is a few teaser pics for now
Higher RPM Tach gauge...-parts-jpg  Higher RPM Tach gauge...-parts2-jpg
cluster , higher , original , rpm , tach
1st gen. SR5 Gauge Cluster- finally swap in a Tach!! zidaro For Sale: T4R Items 2 07-29-2016 03:48 PM
2001 SR5 2WD - Bubbles in Tach gauge and Temp gauge tenro1 3rd gen T4Rs 7 01-01-2014 07:07 PM
Tach, Fuel Gauge, Temp Gauge, Oil Pressure Gauge, Alternator Quit Working silentrunner Classic T4Rs 3 10-05-2013 12:51 PM
Tach and Temperature Gauge not working properly kdanielp3 Problems & Warranty Issues 0 12-31-2008 11:49 AM
