Old 10-16-2019, 10:58 PM #1
smerhej smerhej is offline
smerhej is on a distinguished road
Front hard brake line into caliper leaking - please help!
Hey all,
So I was changing my pads and replacing some studs on the front passenger side, and after bolting the caliper back on, the hard brake line going from the caliper to the bracket started leaking.
I've heard from a lot of other T4R Canadians that these OEM S-shaped lines are either not being made any more or take weeks to get which is frankly not-desirable.
The part stores sell these:
H. Paulin CN351 Copper Nickel Brake Line, Standard, 51 x 3/16-in — Partsource
Is this the right kind of line? I know 3/16 is correct (and there's various sizes for sale) but it doesn't list the fitting (just that it's Japanese). I was planning on picking up a line bender and a couple 12" just in case.
Anything else I'd need just in case? Thanks in advance
smerhej is offline   Reply With QuoteReply With Quote
Old 10-17-2019, 05:49 AM #2
The Cold War Kid's Avatar
The Cold War Kid The Cold War Kid is offline
The Cold War Kid is on a distinguished road
I'm confused. A hard line can not come from the caliper. The wheels move so a hose is needed/used. The hose begins at the bracket you describe...
The Cold War Kid is offline   Reply With QuoteReply With Quote
Old 10-17-2019, 07:01 AM #3
R Marra R Marra is offline
R Marra is on a distinguished road
Brake lines
Hello, the brake lines are still available. I did not have any luck finding them on a parts diagram but a quick call to Conicelli Toyota and I had them in five days. I don't know about shipping to you but it might be worth a call.
R Marra is offline   Reply With QuoteReply With Quote
Old 10-17-2019, 07:47 AM #4
dogtail's Avatar
dogtail dogtail is offline
Real Name: Keith
dogtail has a spectacular aura about dogtail has a spectacular aura about
dogtail's Avatar
Real Name: Keith
I was doing my last brake job and flustered a bad front hard line. Was late on a Saturday and I was able to get a temporary generic straight line from Oreillys, I just bent to fit. Be aware, both sides are different, one side is beveled, the other is straight. I was able to get the OEM lines from a dealer with next day delivery when they opened that Monday.
*1999 3.4L, 4wd/5spd, swapped motor and trans, heavy use DD, seasonal rust proofing using WD-40 only
*2000 3.4L, 4wd/5spd, parts rig, picking the carcass
dogtail is offline   Reply With QuoteReply With Quote
Old 10-17-2019, 08:13 AM #5
tvpierce's Avatar
tvpierce tvpierce is offline
tvpierce will become famous soon enough
tvpierce's Avatar
There's a short hard line after the soft line.
tvpierce is offline   Reply With QuoteReply With Quote
Old 10-17-2019, 08:48 AM #6
brillo_76's Avatar
Real Name: Jon
brillo_76's Avatar
Real Name: Jon
The caliper small hardline is 3/16 with Japanese ends. I was in the same boat when my caliper piston pushed out too far and I had to replace the front calipers on my Tetanus 1 [1998 4 runner] so I bought remfg from napa and put the shortest ni cu line napa had 6 or 8 inch I believe.
Like other posters suggested the OEM brake lines are still available for purchase and that is what I would have normally used.
If you pull the clip that holds the rubber line union to its bracket you can use the rubber line as it flexes some so you dont damage the mini metal line while changing pads or rotors.
Old 10-17-2019, 10:21 AM #7
Thanks for the help everyone - I'll try the dealer then the part store for the Japanese line like suggested.
Old 10-17-2019, 11:36 AM #8
deves2 deves2 is offline
deves2 is on a distinguished road
You can go to NAPA, Advance etc and get the replacement line. You must bend it but its not really a big deal to do. The price is WAY cheaper than a Toyota dealer price. I just did mine a few months ago and its super easy. good luck
deves2 is offline   Reply With QuoteReply With Quote
Old 10-17-2019, 03:03 PM #9
When you got the replacement is it just the pre-flared/fitted Japanese line?
Old 10-17-2019, 09:27 PM #10
MaineRunna's Avatar
MaineRunna MaineRunna is offline
MaineRunna will become famous soon enough MaineRunna will become famous soon enough
MaineRunna's Avatar
All you need is an 8" piece of brake line from any parts store that is 3/16"X 10mm-1.0 inverted flare. It's just a 3/16" brake line with metric thread AKA Japanese style brake line. Euro would be 10mm-1.0 bubble flare, SAE is 3/8-24 inverted flare.
98 SR5 4X4 5spd, desert dune metallic, Toytech Eibach 3" lift, 1" body lift, RAD Rubber Designs splash guards, 4XInnovations bumpers, Doug Thorely Headers, Magna-flow converter, JBA muffler & tail pipe, RCI skid plate, SPC UCA's & rear LCA's, front sway bar links on rear, gen II rear links on front, Tundra brakes, '02 headlights, tail lights & sidemarkers, BFG 255/85R16 Mud Terrain T/A's 241,000 miles.
MaineRunna is offline   Reply With QuoteReply With Quote
Old 10-18-2019, 07:39 AM #11
brillo_76's Avatar
Real Name: Jon
brillo_76's Avatar
Real Name: Jon
Yup that is exactly what I purchased. I didn't have the length written in my notes but it's the 3×16 10mm -1.0 inverted flare. As mainerunner explained. :]
Old 10-19-2019, 06:48 AM #12
tvpierce's Avatar
tvpierce's Avatar
FYI: They're quite affordable from the dealer. I just ordered the equivalent lines for my 2000 Tundra and they were $6.58 each... pre-bent perfect fit.
Toyota calls them Front Brake Tubes. Given the interchangable parts between the Tundra and 4Runner, it wouldn't surprise me a bit if they were the same part number.
Edit: If you're going to roll your own, it's not a bad idea to have a tubing bender. It's not absolutely necessary, but but for $10, you'll get better bends, and you won't have to worry about kinks. Plus, you'll have a new tool!
I have one similar to this one from Harbor Freight and it works well:
Old 10-19-2019, 08:11 PM #13
yes,
Old 10-19-2019, 09:16 PM #14
schwipt schwipt is offline
schwipt is on a distinguished road
For my 2000 SR5 4WD I just got new hard lines.
I got the ones from the caliper to the flex hose and the ones directly after the flex hose for both sides.
Part numbers are:
47314-35330 Tube Front Brake No.4
47316-35250 Tube Front Brake No.6
47315-35320 Tube Front Brake No.5
47313-3D050 Tube Front Brake No.3
They were the correct parts I was looking for. However, I dont remember which ones were the lines going to the caliper. 6.56$ each.
schwipt is offline   Reply With QuoteReply With Quote
Old 09-11-2023, 12:17 PM #15
Possum Willy Possum Willy is offline
Possum Willy is on a distinguished road
Thanks, what I needed to know as well. Wonky brake line on my 98 4runner, passenger side too
Possum Willy is offline   Reply With QuoteReply With Quote
brake , caliper , case , front , line
front brake hard line OEM part number or equivalent DK327 3rd gen T4Rs 22 04-29-2019 09:55 PM
HELP NEEDED: Front Brake Hard Line? BamaDrewski 3rd gen T4Rs 3 05-05-2015 10:21 PM
Braided brake line going into caliper? chisel 3rd gen T4Rs 9 11-15-2011 01:28 PM
caliper leaking brake fluid Dirty Shirt Maintenance/Detailing 1 09-17-2006 11:32 AM
