Originally Posted by The Cold War Kid
01 SR5 2wd v-6
I installed the new plugs today. Drove it around after - ran a bit better...
Went out an hour later, started motor and it quits, right after the starter runs. Fires, then quits. Does the same if I hold it on the start position.
Any help appreciated - I have no idea...
You changed only the spark plugs and did nothing else???
What type of spark plug did you use?
Hopefully you use the daul electrode plug as they are required.
I never heard if this one. Unless something else happened right after you changed the plugs.
Why did you change the plugs to begin with they just due looked like they were extremely overdue or the engine was doing misfiring etc?
Build Thread:
https://www.toyota-4runner.org/3rd-g...os-builds.html
Brillo's Bucket Fluid Ex changer:
https://www.toyota-4runner.org/3rd-g...ml#post3358086
Sparks Plugs Wire and Coil Information:
https://www.toyota-4runner.org/3rd-g...on-5vz-fe.html
