Old 03-26-2021, 02:48 PM #1
SPark SPark is offline
SPark is on a distinguished road
Air Intake Box
I bought my 4runner around 3 years ago, and the parts of the air intake box that attach to the frame of the 4runner came totally busted (besides one), so it mostly rattles around under the hood. I have consistent MAF sensor issues, and cleaning it out only fixes the issue for 3 months, and then I'm taking it out and cleaning it again(making my gas mileage terrible. I'm thinking that my box is just more exposed to dirt and contaminants because it's not correctly attached to the car, which causes the sensor to get dirty a lot faster. Does that sound possible to you guys?
I want to just replace the stupid thing, but you can't find those boxes anywhere for any sort of reasonable amount. Does anyone know where I could pick up a used one at a decent price? If not, does anyone have any suggestions on how to approach this issue? I'm not super mechanically inclined, as changing oil and cleaning this MAF sensor about top off my experience...
SPark is offline   Reply With QuoteReply With Quote
Old 03-26-2021, 03:04 PM #2
sleepydad's Avatar
Real Name: Andy ಠ_ಠ
sleepydad's Avatar
Real Name: Andy ಠ_ಠ
you should be able to find one in junk yard or people parting out another 4runner on craigs list.
just keep in mind there are 2 different styles thru the 3rd gen years.
1. 96-98 have the same MAF design
2. 99-2002 have another MAF design
you should be able to pull one including the MAF and replace your broken one. you can also re-pin the plug to trick the 96-98 and use a 99-2002 air box, but you will also need to swap over the entire intake pipe and resonator. I have a vid of how that is done if your interested?
I'm sure somebody on this board has an air intake laying around you could have for pretty cheap... I just tossed 2 x of these intakes for 96-98 years last fall into the recycle bin, sorry.
Old 03-26-2021, 03:08 PM #3
Kanoe's Avatar
Kanoe Kanoe is offline
Kanoe is just really nice Kanoe is just really nice Kanoe is just really nice Kanoe is just really nice
Kanoe's Avatar
I would head for the nearest junk yard for that. It's not a part that typically gets picked so you should be able to find one if the yard has any 3rd gens. That assembly would cost a bundle at the dealer I would guess.
Probably just order a new MAF if you want one too. Or you could run the junkyard one and see how it works for you. Might get lucky.
If you are getting dirt on the MAF you are getting dirt in your engine too. Is your filter not sealing correctly? Or are you running an oil type filter that's known for fouling MAFs?
-1993 Corolla Wagon 7AFE
-2001 Echo D.D.
Kanoe is offline   Reply With QuoteReply With Quote
Old 03-26-2021, 03:24 PM #4
davidch davidch is offline
davidch will become famous soon enough
In addition to the model year changes mentioned above, the 4-cylinder air boxes differ from the 6-cylinder models. However, it seems all 96-2000 4-cylinder 4Runners use the same air box.
davidch is offline   Reply With QuoteReply With Quote
Old 03-26-2021, 03:56 PM #5
FD7683 FD7683 is offline
FD7683 will become famous soon enough FD7683 will become famous soon enough
I would go to a junkyard and find one from there. I think a brand new OEM unit would be too expensive anyways.
2000 4Runner Limited 4x4 V6
Old 03-26-2021, 05:03 PM #6
These are excellent questions...
I've checked the junkyards near me, and no 3rd gens so far, so I'll have to keep my eyes peeled.
If anyone stumbles upon this thread, has an extra box and feels sorry for me, I have a 2000 V6
Old 03-26-2021, 06:12 PM #7
sleepydad's Avatar
Real Name: Andy ಠ_ಠ
sleepydad's Avatar
Real Name: Andy ಠ_ಠ
I have used this site from time to time and had good luck finding things
Car-Part.com--Used Auto Parts Market
I used salt lake city to search and lots of 4runners... just not sure where in UT you live?
Old 03-27-2021, 09:37 AM #8
Oh I moved this last year to rural Eastern Idaho. It looks like using the site you posted there’s potential for one in Idaho Falls, so I’ll have to go check that out!
box , cleaning , issue , maf , sensor
Really gummed up intake, under the intake manifold. Advice? ShooterMcGavin 3rd gen T4Rs 109 11-24-2020 02:34 PM
FS: 3rd Gen Upper Intake Manifold Plenum & Lower Intake Runners - Cen TX; Will Ship SURF RUNNER For Sale: T4R Items 19 01-10-2016 12:22 AM
Water in intake... throttle body or intake gasket? a_young240 3rd gen T4Rs 10 08-25-2013 01:41 PM
Cold air intake with battery/intake swap on budget! Thurlo76 Classic T4Rs 13 05-24-2012 01:06 AM
Air intake crap - Kamotors Performance Carbon Fiber Filter 3" Cold Air Intake BMW VW Singtoe 3rd gen T4Rs 11 01-13-2012 06:51 PM
