Back from the dead. I put a 3/4inchb spacer on the driveshaft.
Here is what it was before the spacer
This is the driveshaft shoved all the way in with no spacer. This one was trick because I had to take the picture while holding the driveshaft
This is when I have the 3/4inch spacer in
The main noise is gone more or less. I do think the u joint will kick the dust shield causing some random audible noises.
And I got a feeling it may over compress at times but it's whatever.....I think a 3/8inch or 1/2 inch spacers would have done the trick but I could only find 3/4inch as the smallest offered.
Now the only noise I have is driveline vibration which is probably a combo of bad pinion angle and a driveshaft. For some reason I think the coupling that separates the inner and outer shaft is bad at the very center of it. The sleeve looks to be in good condition when I peer down the the tail end of it.
But anyways....it's not worth my time anymore lol I more or less fixed the main issue. The radio can cancel out the rest lol
Sent from my Pixel 3 XL using Tapatalk
