Old 10-22-2019, 06:24 AM #1
The Cold War Kid's Avatar
The Cold War Kid The Cold War Kid is offline
The Cold War Kid is on a distinguished road
headlights come on with key - grrrr
How can I stop the lights from coming on with the key please?
The Cold War Kid is offline   Reply With QuoteReply With Quote
Old 10-22-2019, 07:58 AM #2
tvpierce's Avatar
tvpierce tvpierce is offline
tvpierce will become famous soon enough
tvpierce's Avatar
Disable Daytime Running Lights:
How to: Disable DRL on your 3rd gen. (earlier models) - Toyota 4Runner Forum - Largest 4Runner Forum
tvpierce is offline   Reply With QuoteReply With Quote
Old 10-22-2019, 09:08 PM #3
Originally Posted by tvpierce View Post
Thanks. That thread has info BUT, as usual, the images are gone.
What is the DRL module? Where is the DRL module?
Old 10-22-2019, 10:02 PM #4
BoomerBob's Avatar
BoomerBob BoomerBob is offline
BoomerBob will become famous soon enough BoomerBob will become famous soon enough
BoomerBob's Avatar
DRL = Daytime Running Lights. The module in the pictures (I can see them) show it to be between the battery and the sheet metal of the engine bay. There's a gray coupling. Disconnect it. Done.
2001 2wd - Daily Driver
BoomerBob is offline   Reply With QuoteReply With Quote
Old 10-23-2019, 06:04 AM #5
The way I read it, 01 and up are different?
Old 10-23-2019, 06:11 AM #6
BoomerBob's Avatar
BoomerBob's Avatar
Okay. This is something I'd like to do too so I'm glad I'm following this thread. I don't know why you weren't able to see the pics though.
The pics in the other forum are gone. Are those the ones you can't see?
Have you looked under the dash by the gas pedal like someone said?
Old 10-23-2019, 08:34 AM #7
Bad Luck Bad Luck is offline
Real Name: Patrick
Real Name: Patrick
First link available in the search shows the DRL module. Just pull the connector and voila! https://www.google.com/search?newwin...4dUDCAs&uact=5
Old 10-23-2019, 09:14 AM #8
thennen's Avatar
thennen thennen is offline
thennen is a splendid one to behold thennen is a splendid one to behold thennen is a splendid one to behold thennen is a splendid one to behold thennen is a splendid one to behold thennen is a splendid one to behold thennen is a splendid one to behold thennen is a splendid one to behold
thennen's Avatar
If you want to start the truck with the DRLs off, but don't mind them coming on when you begin driving, just pull the parking brake before turning the key.
thennen is offline   Reply With QuoteReply With Quote
Old 10-23-2019, 02:18 PM #9
You should be using the parking brake regularly anyway! It is how the rear brakes are auto-adjusted.
'17 Chevy Volt Premier
'16 Honda Odyssey Elite
Old 10-23-2019, 03:04 PM #10
thennen's Avatar
thennen's Avatar
Guilty - but I'm sure there are millions just like me. You're right, though, and it also keeps drum brakes from binding up over time. Just thought maybe OP wasn't aware of the e-brake connection to the DRLs.
Old 10-23-2019, 03:12 PM #11
96RedRunner's Avatar
Real Name: Mark
Real Name: Mark
I rotate tires every 6k miles, check brakes then. Hardly ever use E-brake shoes always needed a bit of adjustment.
Would do the hold button in pump handle back to 7 clicks to set brake when I thought about it.
6k miles ago started using E-brake pretty much always, is a habit now. Rotated tires past Saturday good to go.
For 19 yr brake wear has been 2:1, 2 sets of pads to 1 set of shoes using E-brake seldom if ever.
Could it go to 1:1 with longer life with four corners working correctly all the time, time will tell.
What you think ?
Old 10-23-2019, 05:20 PM #12
clearock clearock is offline
clearock is just really nice clearock is just really nice clearock is just really nice clearock is just really nice clearock is just really nice
just unplug the DRL resistor, then no more DRL...
clearock is offline   Reply With QuoteReply With Quote
Old 10-23-2019, 10:10 PM #13
BoomerBob's Avatar
BoomerBob's Avatar
Got a picture of that for 01-02 T4R's? Where is it located?
Old 10-24-2019, 02:18 PM #14
I am not as familiar with the 01-02 but from what i can find on alldata for the 01-02 they are calling it diode (daytime running light NO.1) D12. With that said I have never just unpluged said on a 01-02 to make sure its as simple as the 96-00 that use a resistor... The diode is located up behind the passenger air bag from what the pic shows.
headlights come on with key - grrrr-20191024_114615-2-jpg
FYI another member on here said it was located under the steering wheel but i have no 1st hand knowledge.
Old 10-24-2019, 05:06 PM #15
BoomerBob's Avatar
BoomerBob's Avatar
Thanks. That alldata site looks pretty cool. Too bad it's a pay site.
grrrr , headlights , key , lights , stop
Grrrr 🙁 Sworkscrux 4th Gen T4Rs 1 07-04-2019 08:02 AM
Sciatica. GRRRR!! hikenbike Off Topic 33 09-27-2018 09:54 AM
grrrr... thieving bas****s! insurance totaled my 4r denverunner 3rd gen T4Rs 48 08-20-2018 09:49 PM
Sqeeeeeeky suspension grrrr kolelt 3rd gen T4Rs 13 06-18-2016 11:21 AM
No Heat- Grrrr! claydoctor 4th Gen T4Rs 1 10-13-2013 12:51 AM
