Originally Posted by Jwpete
For what it's worth, during the clutch swap I pulled the TOB fork out and cleaned it up with a wire wheel because it was covered in old grease and clutch gunk. I think I would have noticed any major cracks, bends, or damage on the fork while i was cleaning it up, though to be fair, I wasn't looking for them at the time. In hindsight I wish i had gotten a replacement fork just to rule out another issue. Really hoping to not drop the trans again but it may have to happen.
To address the pressure plate comment, I did not use a torque wrench on the flex plate bolts like I know I should have, as mine does not go as low as the 14 ft. lbs required by the FSM. Shouldn't make a huge difference though right as it is simply snugging up to the flywheel? All the research I have done makes me believe that bolt torque should have no effect on clutch plate engagement or disengagement. But if any of you know better, please correct me.
One thing i'm beginning to suspect is just shoddy parts? All major clutch and hydraulic parts were O'Reilly "Power Torque" brand. I don't know if any of you have had any positive or negative experience with the quality of these parts. Perhaps the master cylinder rod or the slave cylinder are just not quite the right length? or the fingers on the pressure plate weren't quite right? Still more questions than answers.
Thanks to all of you for input!
Did you take any photos of the installation. I have seen a truck where the pressure plate was over torqued because they didn't use a wrench. (Harbour freight torque wrenches are actually really accurate so go grab some) and they couldn't disengage the clutch.
The forks should be nice and level when properly torqued.
Sent from my moto g(6) using Tapatalk
97 5spd with elocker
Build Thread
https://www.toyota-4runner.org/3rd-g...st-bucket.html
2 inch Lift (Bilstein 5100 F&R, 99 Talls F, OME R), 33 Inch Tires
Rebuilt Engine, Doug Thorley Headers, Gibson Catback
