Old 10-25-2019, 08:12 PM #16
eimkeith's Avatar
eimkeith eimkeith is offline
Official Vendor
eimkeith is a glorious beacon of light eimkeith is a glorious beacon of light eimkeith is a glorious beacon of light eimkeith is a glorious beacon of light eimkeith is a glorious beacon of light eimkeith is a glorious beacon of light
Official Vendor
eimkeith's Avatar
Originally Posted by jross20 View Post
Will the bottom parts interfere with an LCA skid?
I'd assume so (although I've never looked at an LCA skid)
keith
eimkeith.com
all product descriptions © eimkeith LLC 2016-2023
eimkeith is offline   Reply With QuoteReply With Quote
Old 10-25-2019, 09:43 PM #17
JZiggy's Avatar
JZiggy JZiggy is offline
JZiggy has a brilliant future JZiggy has a brilliant future JZiggy has a brilliant future JZiggy has a brilliant future JZiggy has a brilliant future JZiggy has a brilliant future JZiggy has a brilliant future JZiggy has a brilliant future JZiggy has a brilliant future JZiggy has a brilliant future JZiggy has a brilliant future
JZiggy's Avatar
Of course Anwar would be like the first guy to get this kit
JZiggy is offline   Reply With QuoteReply With Quote
Old 10-25-2019, 10:23 PM #18
UnderFire's Avatar
UnderFire UnderFire is offline
UnderFire has a spectacular aura about UnderFire has a spectacular aura about UnderFire has a spectacular aura about
UnderFire's Avatar
Sweet. I welded up all the seams and deleted the sway bar mounts off my LCAs on my Taco when I was putting the bushings. Something like this crossed my mind, but didn't end up plating it at all.
Sent from my JSN-L23 using Tapatalk
'97 3RZ 5 Speed "FrankenRunner" (Build Thread) - Dormant
The "shitmobile" 500$ 3RZ Auto 4Runner - (Saved from the Scrapyard: Resurrecting a 500$ 3rd Gen
02 Tacoma Double Cab, mid-travel, locked, armored, supercharged and riced. (Longbed and 5 speed in the works)
UnderFire is offline   Reply With QuoteReply With Quote
Old 10-26-2019, 11:29 AM #19
96RedRunner's Avatar
Real Name: Mark
Real Name: Mark
Originally Posted by eimkeith View Post
get the mount ID right the first time, plus the belief that they'll see very little wear versus the environment they are designed for..?
they can definitely be shimmed for wear as needed as time passes.
No need for the question mark after that statement, simple and it works.
If I'm thinking right scissor's and shim stock would cure any wear issues, that's cool.
Old 10-27-2019, 07:00 PM #20
eimkeith's Avatar
Official Vendor
Official Vendor
eimkeith's Avatar
- that's what I'm thinking as well. I decided not to really overengineer it for adjustable preload via a nut because the costs were getting crazy for a simple pivot.
- that said, some genius will show up with a simple solution that will blow everything else out of the water and make everyone feel stupid, I bet... lol.
keith
eimkeith.com
Old 10-28-2019, 04:20 PM #21
mesooohoppy mesooohoppy is offline
mesooohoppy has a spectacular aura about mesooohoppy has a spectacular aura about mesooohoppy has a spectacular aura about
for those who have welded these, are you applying weldable primer to the backside for corrosion?
i have done this in the past to certain parts and its worked well. just wondering if others are doing this.
thanks again keith for making these. will buy with a PCK.
99 4runner limited; imperial jade mica
IG: mesooohoppy
mesooohoppy is offline   Reply With QuoteReply With Quote
Old 10-29-2019, 12:53 PM #22
Real Name: Mark
Real Name: Mark
Originally Posted by mesooohoppy View Post
for those who have welded these, are you applying weldable primer to the backside for corrosion?.
I used it on the rear control arm reinforcement parts that overlap.
Better than nothing, Primers usually absorb moisture, 3rd coast rust not a issue.
Old 10-29-2019, 12:57 PM #23
that is good to know. i live in a climate that can be very wet/dry/dusty/snowy all in the course of a week, so i need to ensure all steel that will corrode is protected; even if i cant see it.
IG: mesooohoppy
Old 10-29-2019, 02:11 PM #24
Real Name: Mark
Real Name: Mark
For the best weld you don't what to weld through a coating, it will burn off at the point of weld and
beyond a certain distance anyway.
On the parts that have air gap between them I'd drill some holes coat after welding, allow air to dry out things clean out the dirt spray rust preventitive in. Why frames are open design.
Notice how LCA's are a open design.
Old 10-29-2019, 02:59 PM #25
while i would ususlly agree with you RE welding on paint. im talking about weldable primer. its made to be welded through so the blind material can be coated. ive used it in the past on subframe bracing with great success. you paint prior to welding anything so when you are done and paint over the weld there is 0% exposed metal.
you will never get 100% coverage if you 'drill' into your freshly braced arms. not to mention possibly weakening the part you juuuuuust stiffened up.
sure we may have 'open designed' frames/LCAs, but theyre coated.... to prevent rust.
IG: mesooohoppy
Old 10-29-2019, 03:53 PM #26
Real Name: Mark
Real Name: Mark
Just saying it's better than nothing.
Lol, coated frames yea they rust out.
Old 11-06-2019, 09:00 AM #27
owyheerat's Avatar
owyheerat owyheerat is offline
Real Name: Durwin
owyheerat will become famous soon enough
owyheerat's Avatar
Real Name: Durwin
@ eimkeith
I just placed an order for the LCAR kit and the strut tower reinforcement kit.
Thanks for making GREAT products for our GREAT 4runners.
Durwin
99 2.7l 5spd ARB locked F & R, 5.29's, dual cases, Shrockworks front bumper w/ Warn M8000s, King 25001-151EXT coilovers, OME 861/LC shocks, Stubb's sliders, Shrockworks full skids, custom built rear bumper, Kenda Klever RT 35x10.5r17 on FN FX pro 17x8's, TBU
owyheerat is offline   Reply With QuoteReply With Quote
Old 11-06-2019, 09:43 AM #28
eimkeith's Avatar
Official Vendor
Official Vendor
eimkeith's Avatar
Originally Posted by owyheerat View Post
@ eimkeith
Durwin
Thanks for the order! I'm headed in to ship it right now.
keith
eimkeith.com
Old 11-27-2019, 01:00 PM #29
thought i would add these pics to this thread to show how i dealt with rust prevention on these reinforcement kits (mostly the top where the'E' can expose the elements to the bare steel). the weldable primer i bought was by SEM and it was the non copper variant. the guy couldnt explain the difference to me, despite rattling over a bunch of other useless facts, so i just went with the regular variant.
basically i just laid down the reinforcement plates, 'traced' them with a sharpie and laid some frog tape approx 1/8" inside the line of the sharpie. i then wirewheeled the sharpie off and had my room mate weld them in. you could probably get away with doing just the top plates, but i did the bottoms as well.
no its not going to win any weldporn awards, but i can say these plates are now a part of the LCA and they arent going anywhere
IG: mesooohoppy
Old 11-27-2019, 03:01 PM #30
mtbtim's Avatar
mtbtim mtbtim is offline
Real Name: Tim
mtbtim's Avatar
Real Name: Tim
Looks like your roommate welds pretty damn good to me. But, I'm not a welder. Good roommate to have I'd say.
arm , control , lower , reinforcement , ties
3rd gen rear lower control arm deves2 3rd gen T4Rs 14 08-30-2017 09:05 AM
does anyone know if the rear spare rack reinforcements exist in a 95? gtgt_bangbang Classic T4Rs 4 02-24-2015 04:38 PM
2003 Lower Control Arm/Lower Ball Joint replacement Wahoo96 4th Gen T4Rs 5 01-30-2015 02:16 PM
Lower Control Arm atalarico 3rd gen T4Rs 8 08-17-2014 01:23 AM
Need Help - Lower Control Arm AlexJet Problems & Warranty Issues 0 08-25-2007 08:00 PM
