Old 10-24-2019, 12:36 AM #1
mkzg mkzg is offline
mkzg is on a distinguished road
170 degree thermostat - no toyota OEM one...will this KUZEH one work?
So...we all know that OEM or genuine Toyota is typically the best
I am in the process of installing my TRD supercharger...and Its time i change my thermostat to a colder one before I refill my cooling system.
Toyota didnt make a 170 thermostat for our 3.4L trucks. Only a TRD 160 one, which I dont really want...many have gone to stant or motorad...well...Kuzeh is the OEM manufacturer, and they make one for the corollas/matrix in 170
Based on my research, it will fit...correct me if I am wrong?
this is what i found as the "OEM" thermostat - W0133-1629493-KUZ
Kuzeh(R) W0133-1629493-KUZ - Engine Coolant Thermostat
fits
Corolla 1998-1999, 2009-2013
Matrix 2009-2013
which I cross referenced with these part numbers - 90916-03129, 90916-03084, 90916-A3003
which fit 1MZFE, 2AZFE, 3MZFE, 1ZZFE; 1ZZFE; ZZW30, 2ARFE
Which...URD sells one for the 1MZFE and 5VZFE
170 Degree Performance Thermo for 5VZ-FE 3.4L and 1MZ-FE 3.0L V6 - Underdog Racing Development
so...by process of deduction...can I assume based on the Kuzeh listing that it fits the 1ZZFE, 2ZRFE in the Matrix and Corolla, and that the cross reference of the Toyota Part number fits the same vehicles, PLUS the 1MZFE, and based on URD, the 1MZFE and 5VZFE Thermostats are interchangeable so the 1MZFE fitting Kuzeh 170 thermostat will fit and work in the 5vzfe application? No more need for the aftermarket Stant/Motorad ones...we can go to the OE manufacturer for our 170 degree needs?
And it uses this seal
16325-62010 - Genuine Toyota GASKET, WATER INLET HOUSING
which fits all the thermostats
mkzg is offline   Reply With QuoteReply With Quote
Old 10-24-2019, 08:42 AM #2
Bad Luck Bad Luck is offline
Real Name: Patrick
Real Name: Patrick
Why not just use a Stant 14077? That's a 170 degree thermostat that several supercharged folks use.
Old 10-24-2019, 11:17 AM #3
Because I am after as close to oem as possible, hence my search for the Kuzeh one. This is always an option, to go with Stant, just prefer as close to Oem as possible
Old 10-24-2019, 11:48 AM #4
Real Name: Patrick
Real Name: Patrick
Have you thought about emailing them and asking? Good luck with your search.
Old 10-24-2019, 08:07 PM #5
I decided to just order it and see how it works. If it fits, then awesome! If not, then...up for sale it would go. Will keep updated once it gets installed!
Old 01-30-2020, 09:53 PM #6
Bdnewyork's Avatar
Bdnewyork Bdnewyork is offline
Real Name: Robert
Bdnewyork is on a distinguished road
Bdnewyork's Avatar
Real Name: Robert
Any update? I'm in the market for same.
Bdnewyork is offline   Reply With QuoteReply With Quote
Old 01-31-2020, 12:44 AM #7
Dieselchessy Dieselchessy is offline
Dieselchessy has a spectacular aura about Dieselchessy has a spectacular aura about Dieselchessy has a spectacular aura about
Toyota OEM 170 that fits. From a Carola. 90916-03107
Owned 82, 83, 87 pickup, 98, 99 SR5 4runner
Currently own a 98 SR5, 5spd, 4x4, e-locker, no sunroof. 2012 LTD with the normal options.
Dieselchessy is offline   Reply With QuoteReply With Quote
1mzfe , kuzeh , oem , thermostat , toyota
170 degree Thermostat? 4.7l V8 fulltimervexplorer 4th Gen T4Rs 4 10-05-2019 05:40 PM
3.4L Toyota thermostat and gasket $20 shipped (Opelika, AL) cj80cruiser For Sale: T4R Items 8 12-30-2015 10:59 PM
93 v6 timing degree? Beau4runner Classic T4Rs 11 12-18-2013 12:36 PM
Degree advice? Dous General Discussions 24 11-17-2012 08:50 PM
