Originally Posted by Bucket81
The crank doesn't move at all.
About 175,000, so not enough.
It's only sat for a couple of months.
The fluid doesn't smell burnt.
I had it stall on me once at a red light might have slipped once or twice, no noises.
And yes starter, plugs, timing belt have been pulled. It doesn't turn.
I could pull the pan on the transmission and see what that looks like.
I am suspecting Complete failure of the Torque converter. That is not very many miles on the clock.
The Torque Converter is what lets it sit in Drive with the brake on. Its the Clutch that lets that happen. Not only does it do that, it also regulates the flow of tranny fuild to your transmission pump as well.
Unless the engine didn't have any oil in it or it milkshaked.
What does the engine oil look like clean? { I am suspecting it looks normal}
A complete flush and new transmission filter would do nothing if the TC or Transmission itself is severely damaged.
Lets see what other forum members are thinking. Its extremely rare to have crankshaft seized.
If you put the transfer case in Neutral and the Transmission in Neutral what does it do?
Build Thread:
https://www.toyota-4runner.org/3rd-g...os-builds.html
Brillo's Bucket Fluid Ex changer:
https://www.toyota-4runner.org/3rd-g...ml#post3358086
Sparks Plugs Wire and Coil Information:
https://www.toyota-4runner.org/3rd-g...on-5vz-fe.html
