Old 10-24-2019, 04:11 PM #1
RumHam26 RumHam26 is offline
RumHam26 is on a distinguished road
Can I bleed only the rear brakes?
Just finishing up replacing all brake lines and hoses from master cylinder to the rear wheels (PITA in the rust belt!!) - can I bleed just the rears? Or do I need to do the fronts as well? I am aware of the proper sequence, but I am under the impression that the fronts and rears are separated in some way as a safety measure in case you lose a brake line. I've bleed only the fronts before, and that was no problem. Any input is appreciated. Thanks!
RumHam26 is offline   Reply With QuoteReply With Quote
Old 10-24-2019, 04:19 PM #2
brillo_76's Avatar
Real Name: Jon
brillo_76's Avatar
Real Name: Jon
I would bleed all 4 brakes. Do you have 2 lines going to the rear or just one?
Tip:
Best when in the rust belt, when replacing the rusted lines to cut the lines and put a 6 point socket on the head of the brake line. Super soak it with penetrating oil and mostly they will come loose.
However, you can do as you wish..;-)
Old 10-24-2019, 07:41 PM #3
BoomerBob's Avatar
BoomerBob BoomerBob is offline
BoomerBob will become famous soon enough BoomerBob will become famous soon enough
BoomerBob's Avatar
Can't see why not. It would be like just doing the rear brakes on a brake fluid flush. Not really a big deal.
I just did a brake fluid flush on my 01 yesterday when I also installed Speed Bleeders so I could do it by myself. The vacuum method also works when doing this with one person.
I think most people know brake fluid is quite hygroscopic (sometimes spelled hydroscopic) so it's a good idea to flush the system every few years or so just to get the water and any coagulation out. More important in wet climates than dry.
2001 2wd - Daily Driver
BoomerBob is offline   Reply With QuoteReply With Quote
Old 10-25-2019, 12:40 AM #4
HiLife HiLife is offline
I don't see why not also. The rear is on a separate brake circuit from the fronts.
Hope you were careful in not letting any air travel up the lines and into the abs pump during your lines change out. You need to activate the pump to bleed out the air bubbles trapped inside if it did.
Good idea to keep the fluid fresh and dry, so I just get a quart of brake fluid and bleed the back and front brakes, your already under there.
bleed , brake , fronts , rear , rears
How to bleed brakes 24poepoe 5th gen T4Rs 28 04-15-2019 09:49 AM
Can't get rear brakes to bleed? thegipper 3rd gen T4Rs 12 07-15-2017 05:45 PM
No fluid coming from rear brakes when I try to bleed! ShannanC 3rd gen T4Rs 21 09-27-2015 01:57 PM
URGENT: Rear Brakes Won't Bleed- Need Help!!! BlairB 4th Gen T4Rs 4 06-14-2009 07:27 PM
power bleed or vacuum bleed brakes schan1w Maintenance/Detailing 4 08-13-2007 07:19 PM
