10-27-2019, 02:38 PM
'98 ECU pinouts
Hi everyone,
I'm about to start my 5-speed swap on my '98 auto and I need help finding the ECU pins for both the auto and 5-speed ECU's.
I have a '98 5-speed ECU but some say it won't work with my auto harness, while others say it's plug n play. I don't want to burn anything up so I'm trying to get confirmation.
Thanks!
Jim
10-27-2019, 04:56 PM
It will plug in because in 98 Toyota standardized the connectors on the ECM so manual and autos were the same. The problem is that you can't plug any of that harness into your 5spd. You may be able to plug it in with no harm to the ECM and just a few non functioning items, but you are going to have to de-pin the harness or replace it with a manual one from a donor to have back up lights, clutch safety switch, cruise control, speedo, etc. I have all the wiring diagrams and pin outs printed out, but they are at work so I can't access them right now
98 SR5 4X4 5spd, desert dune metallic, Toytech Eibach 3" lift, 1" body lift, RAD Rubber Designs splash guards, 4XInnovations bumpers, Doug Thorely Headers, Magna-flow converter, JBA muffler & tail pipe, RCI skid plate, SPC UCA's & rear LCA's, front sway bar links on rear, gen II rear links on front, Tundra brakes, '02 headlights, tail lights & sidemarkers, BFG 255/85R16 Mud Terrain T/A's 241,000 miles.
10-27-2019, 06:16 PM
Thanks! I have all of the harnesses from the '99 donor as well as the '98 M/T ECU and I think I'd much rather re-pin my '98 harness than swap all those damn harnesses.
11-01-2019, 12:49 AM
I did a 5 speed swap in my 98 2 years ago - I used all factory auto connectors except I did swap the engine harness to the 5 speed one and it all worked fine.
11-01-2019, 01:02 AM
Real Name: Jerod
Real Name: Jerod
Here's part of the equation on the Auto side of things:
1998 ECU Wiring Diagram? TIS site gone...
11-01-2019, 09:05 AM
Nice, I'm seriously considering going this route.
11-01-2019, 09:06 AM
Originally Posted by gamefreakgc
Awesome, thank you! I just now need to find the matching pinouts for the 5-speed.
11-01-2019, 01:12 PM
Real Name: Jerod
Real Name: Jerod
Message the guy who helped me in that thread. He might still have access to the rest of the diagrams.
