Old 10-28-2019, 06:06 PM #16
mesooohoppy mesooohoppy is offline
mesooohoppy has a spectacular aura about mesooohoppy has a spectacular aura about mesooohoppy has a spectacular aura about
i do, but i work very slowly. i will have to do this as im assuming the clunk i hear is this issue.
im assuming no, but is there anyway this can be tacked in while the shaft is still in the car? its hard to see on that one thread as the pics are super small.
thank you!
99 4runner limited; imperial jade mica
IG: mesooohoppy
mesooohoppy is offline   Reply With QuoteReply With Quote
Old 10-28-2019, 06:09 PM #17
mtbtim's Avatar
mtbtim mtbtim is offline
Real Name: Tim
mtbtim has much to be proud of mtbtim has much to be proud of mtbtim has much to be proud of mtbtim has much to be proud of mtbtim has much to be proud of mtbtim has much to be proud of mtbtim has much to be proud of mtbtim has much to be proud of mtbtim has much to be proud of
mtbtim's Avatar
Real Name: Tim
Originally Posted by mesooohoppy View Post
thank you. although i do not see that being done in 30 minutes without having done it before. i noticed a clunk in my steering shaft yesterday when putting in an aftermarket steering wheel. my room mate and i couldnt figure out where it was coming from. safe to assume its this shaft?
It could also be the u-joint in the shaft below has developed play. This video will show you how to do the tack weld fix and tilt wheel ball fix.
Old 10-28-2019, 06:42 PM #18
thank you, i will look into all of this
IG: mesooohoppy
Old 10-28-2019, 11:53 PM #19
Thebeastlives Thebeastlives is offline
Thebeastlives will become famous soon enough Thebeastlives will become famous soon enough
Suspension
To be safe take it to your nearest offroad shop preferably one that works on toyotas and have them look over your entire suspension and give you an estimate. Most do that for free
Thebeastlives is offline   Reply With QuoteReply With Quote
Old 10-29-2019, 10:25 AM #20
absalom's Avatar
absalom absalom is offline
Real Name: Jordan
absalom will become famous soon enough absalom will become famous soon enough
absalom's Avatar
Real Name: Jordan
If you're near Denver, I can do this for you. @ OP
absalom is offline   Reply With QuoteReply With Quote
Old 10-29-2019, 05:52 PM #21
wtfemery wtfemery is offline
wtfemery is on a distinguished road
i had some time today, so i went and got my tires balanced and rotated. they are still basically brand new, and had the little balancing weights in them, it turns out the last shop just did a really bad job. smooth as butter now. I made sure to go to a shop with the road-force balancing machine. (discount tire near me)
LBJs are still on their way and i’ll do them during the next dry weekend when i don’t have an exam to study for. (hopefully this weekend) lol
1997 4x4 SR5 3" Lift on 32's @248,000 miles
https://i.imgur.com/saVyn4L.jpg
wtfemery is offline   Reply With QuoteReply With Quote
Old 10-29-2019, 06:13 PM #22
I’ll keep you in mind when i tackle the 4000mi round trip out to colorado springs and back that i’m planning this december. in case something breaks while i’m out there lol
That’s why i’m trying to get the basics done now before i go. LBJs, Radiator, fluids, etc
Old 10-31-2019, 04:47 PM #23
Got my LBJs from amazon today, one was in a box and one of them was just put in a paper bag with no other protection... TF??
The bag is all torn up and has holes in it and i can’t really tell if the parts are damaged or not. they’re all sticky and it looks like some grease leaked out on both of them, is that normal? also, it takes a good bit of force to get them to move around.
pics: Imgur: The magic of the Internet
Old 10-31-2019, 09:29 PM #24
photoleif photoleif is offline
Real Name: Leif
photoleif is on a distinguished road
Real Name: Leif
the finish on them is a bit sticky on the ones i *just* ordered from amazon, but the boots don't look happy with yours. the rubber should be all clean. it's possible it squished out a little in the ones sent to you, but the boots themselves are undamaged. if you're in a hurry, carefully inspect to see if the boots are at all damaged. if not, you may be able to obtain some grease and inject it in there. but for peace of mind so your repair doesn't actually hurt your rig when those BJs go kaputt, i'd send those right the heck back and get new ones.
'99 4R SR5 5VZ-FE | Manual transmission | mostly-LED lighting | TBU | 265-75R17 Duratrac stuffed after some pinch-weld convincing
'95 Xtra cab 5VZ-FE swap | 33x10.50-15 BFG AT/KOs | 4" Superlift | ARB rear locker | OME torsion bars | Total Chaos idler arm and uniball conversion | Rancho steering stabilizer | Smittybilt front & rear tube bumpers | Sportsman topper | Aisin hubs | Dual Optimas | Extended diff breathers | Custom center console and jumpseat conversion | Bilstein 5100s | De-striped | Hella pencil-beams
photoleif is offline   Reply With QuoteReply With Quote
Old 11-01-2019, 01:53 AM #25
well, one was in a box and the other was in a bag and they both look pretty much the same. both boots are fine. just oozing grease. don't know if new ones would be any different. Is it possible to add too much grease in em? lol
Old 11-01-2019, 02:50 AM #26
Real Name: Leif
Real Name: Leif
i don't think it's at all likely that they could be (could have been) overfilled. if you watch timmy's (mtbtim's) vid on replacing the uppers, you'll see how those get stuffed with two types of grease and then locked in place. i imagine the lowers are similar but it's done at the factory. grease leaks from any boot are likely to result in premature failure, which is why i'm suggesting you reorder and return these. do ask around though and post up what you find. fwiw, the amazon sellers that supplied mine are JP-CARPARTS and Amazing Parts Warehouse (split order).
edit: had a closer look at mine, and they look very similar to yours in terms of the little bit of grease on top.
Old 11-01-2019, 08:45 AM #27
Bad Luck Bad Luck is offline
Real Name: Patrick
Bad Luck is a glorious beacon of light Bad Luck is a glorious beacon of light Bad Luck is a glorious beacon of light Bad Luck is a glorious beacon of light Bad Luck is a glorious beacon of light
Real Name: Patrick
They look fine to me. Doesn't look like much grease came out. When you install them the boot gets smushed down and seals tight. I'd use them as long as you don't find any holes or tears in the boots. Stiff joints are a good thing.
2000 Limited V6 Auto E-Locker
Old 11-01-2019, 11:11 AM #28
Real Name: Leif
Real Name: Leif
good advice. i had a second look at mine and they both have that same small ring of grease at the top. the main part of the boots are intact, and i don't see any cracks or slits.
Old 11-01-2019, 02:35 PM #29
LOL Amazing Parts Warehouse was the one that shipped mine horribly! Did yours arrive in a crappy bag too?
(The other one was direct through the "TOYOTA" Amazon store)
Old 11-01-2019, 10:51 PM #30
Real Name: Leif
Real Name: Leif
it was in that crappy bag, but because i had several things in the order, that was also in a larger box. the other LBJ was in the plastic bag in its own nice padded box. today my UBJs arrived and they were in plastic baggies, in a box with lots of bubblewrap. the 'TOYOTA' seller i saw when i ordered, turned out to be that other JP parts place.
ball , i’m , joints , steering , wheel
Lower ball joints atran27 4th Gen T4Rs 15 12-08-2020 04:26 PM
lower ball joints bubba 10 4th Gen T4Rs 46 04-25-2017 11:07 PM
---I will buy your old lower ball joints--- Z-4runner 3rd gen T4Rs 8 04-29-2016 10:56 PM
Lower Ball Joints bikerjosh 3rd gen T4Rs 22 07-15-2011 06:03 PM
Where to buy OEM Lower Ball Joints?! live4thrillz Maintenance/Detailing 3 06-13-2011 06:01 PM
Feedback Buttons provided by Advanced Post Thanks / Like (Lite) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
