Old 10-30-2019, 09:11 AM #16
AntleredRuin AntleredRuin is offline
Real Name: Daniel
AntleredRuin will become famous soon enough
Real Name: Daniel
Originally Posted by brillo_76 View Post
The early years 96 -98 federal ones have one cat with 2 sensors. Front sensor is air/ fuel sensor. The back is the o2 sensor. I believe 99 -02 are all 2 cat systems.
It's an old trick to put a few gaskets under the 02 sensor to basically fake the ecu out that a cat is burned out. I have a 02 Camry with a burned out cat. I just check the cel light from time to time to make sure there isnt anymore codes . ;)
Nope 1996-2000 Federal was a 1 cat system. Cali was always 2 cats, regardless of year.
In 2001, Federal adopted the 2 cat setup, and there was no more specific 'cali style'. Everyone had 2 cats then.
AntleredRuin is offline   Reply With QuoteReply With Quote
Old 10-30-2019, 11:21 AM #17
brillo_76's Avatar
Real Name: Jon
brillo_76's Avatar
Real Name: Jon
Oh so its 2000 instead of 1999. Alright. my mistake. :-D
Old 10-30-2019, 12:15 PM #18
clearock clearock is offline
clearock is just really nice clearock is just really nice clearock is just really nice clearock is just really nice clearock is just really nice
I have removed the upper cat on a few cali systems and haven't had any issues (no codes). U have to move the mount point of the 02 sensor 1 (up steam) to down in front of the lower cat. I have also replaced cats in the 3rd gen with ones i've pulled from other vehicles (makes/models) and ran them without issue, along with any # of aftermarket brands (just make sure to use something that will not restrict flow). There is nothing magical about cat composition between other gas vehicles.
clearock is offline   Reply With QuoteReply With Quote
Old 10-30-2019, 02:25 PM #19
TheDurk's Avatar
TheDurk TheDurk is offline
TheDurk is a glorious beacon of light TheDurk is a glorious beacon of light TheDurk is a glorious beacon of light TheDurk is a glorious beacon of light TheDurk is a glorious beacon of light TheDurk is a glorious beacon of light
TheDurk's Avatar
Nope 1996-2000 Federal was a 1 cat system Cali was always 2 cats, regardless of year.
The bolded is incorrect. 1999 and 2000 were transition years and 2-Cat systems were sold in California and several other (mainly Eastern) states, while the rest of the country got the old 1-cat system. 2001 was when the Cali. 2-Cat went 50-state. Prior to 1999, even the Cali. trucks had the 1-Cat "Federal' system.
My New Jersey 1999 came new with a Cali. 2-cat system.
Also, the 1 cat system has O2 sensors front and rear. Only the Cali. 2-Cat has the wideband air/fuel sensor in front.
My Backyard Frame Swap
Old 10-30-2019, 02:49 PM #20
brillo_76's Avatar
Real Name: Jon
brillo_76's Avatar
Real Name: Jon
That's why i said I believe... I wasn't 100% sure. Thanks for the correction TheDurk.
My 2001 is a 2 cat system. (I don't have a 1999 or 2000 one) My 97 and 98 ones are 1 cat system.
Good to know. :-)
So to be 100% accurate 1996- 1998 federals are all one cat systems. While the 1999-2000 Federals could be one cat or 2 cats. Then by 2001-2002 all Federal are 2 cat system.
Old 10-30-2019, 04:56 PM #21
Real Name: Daniel
Real Name: Daniel
I stand corrected. I've been under the impression that what I stated was true for a few years now, and I think some other people (I forget who) believe the same thing. I've seen other people say what I said in multiple other threads, or at least I understood it that way.
I guess all that really matters in terms of actual part numbers is 1 cat vs 2.
Old 10-30-2019, 08:25 PM #22
The Cold War Kid's Avatar
The Cold War Kid The Cold War Kid is offline
The Cold War Kid is on a distinguished road
So there IS an advantage to having the dual setup!
It would seem that all I need to do is cut out both old cats and weld in a new one where they were...
Yes?
The Cold War Kid is offline   Reply With QuoteReply With Quote
Old 10-30-2019, 08:47 PM #23
TheDurk's Avatar
TheDurk's Avatar
I haven't seen that, or I would have corrected it. I think you may have misunderstood.
Old 10-30-2019, 08:55 PM #24
TheDurk's Avatar
TheDurk's Avatar
Yes?
If your objective is to turn the light out on a 2001, one cat in where two were used originally won't do the job. It will set a P0420 right away, or quickly. The 2-cat system operates to stricter parameters and NEEDS both cats to meet them.
You might consider the URD sim:
URD Rear O2 Simulator, 5VZ-FE 3.4L V6 - Underdog Racing Development
If you search, you can find how to build your own for $5.
Old 10-30-2019, 09:27 PM #25
brillo_76's Avatar
Real Name: Jon
brillo_76's Avatar
Real Name: Jon
Originally Posted by Ed_C View Post
The question was meant for the OP ;)
I hope your Camry's converter isn't actually damaged to the point where the core has broken apart...probably not since it would've caused poor drivability.
Ah. Not a big deal with the front Cat. Gives me the two high air registered in the 2nd downstream. The exhaust isn't leaking and the 2nd cat was replaced with Walker when I had the exhaust replaced 4 years ago. Kinda off topic anyways. One of these years I will replace it. I hate check engine lights. My brother drives that rig and dosent mind it.
Old 10-30-2019, 10:15 PM #26
jbtvt's Avatar
jbtvt jbtvt is offline
jbtvt has a spectacular aura about jbtvt has a spectacular aura about
jbtvt's Avatar
I used eastern catalytic on my GF's Lexus recently and was impressed with build quality, and price. Took care of her code also, of course.
You can also bypass downstream O2 with a capacitor and resistor. Schematics are out there somewhere on the www, don't have in front of me here.
'85 4Runner, 22re 5spd; '90 4Runner, 5spd, 3.4 swap
'98 GS400 1uz; '07 GX470 2uz
jbtvt is offline   Reply With QuoteReply With Quote
aftermarket , buy , sensors , stealership , winter
FREE!! Wiring harness for aftermarket radio with aftermarket amp fblainen11 3rd gen T4Rs 4 01-30-2019 05:16 PM
Aftermarket?? Smitty777 Engines / Suspension / Wheels / Tires / Audio / Accessories 1 04-26-2016 05:37 AM
Aftermarket? jca21 5th gen T4Rs 16 01-22-2010 06:52 PM
aftermarket ac rico55 General Discussions 3 08-03-2008 03:29 PM
Which aftermarket DVD? linvillegorge Engines / Suspension / Wheels / Tires / Audio / Accessories 8 03-20-2005 04:57 PM
