Old 10-29-2019, 06:24 AM #1
The Cold War Kid's Avatar
The Cold War Kid The Cold War Kid is offline
The Cold War Kid is on a distinguished road
aftermarket cat?
I replaced both o2 sensors. Last night the !@#$%^&*()(!! check engine light came on again, of course. I haven't had this truck very long but so far I notice it cuts me no slack... Maybe I'll sell it, and cut my losses. It's really starting to **** me off!
I'm scrambling to get this thing going for winter. Days are getting way too cold to be working on it. I ordered a $5 spacer for the rear o2 sensor. Maybe that will spare me looking at those glaring lights all winter. If not, maybe a hammer will work.
Has anyone tried aftermarket cats? When spring comes I guess I'll change it IF I don't have to buy one from a stealership. (I'm sure they want $9,000 for the part.) I dunno why - this state does not do smog inspections. I just tend to do things right. After many years I have found you can't bull**** a machine... Just can't do it.
So, if someone will share their experience, I would appreciate it?
The Cold War Kid is offline   Reply With QuoteReply With Quote
Old 10-29-2019, 08:04 AM #2
JRZEE2000TR4LTD's Avatar
JRZEE2000TR4LTD JRZEE2000TR4LTD is offline
Real Name: John
JRZEE2000TR4LTD will become famous soon enough JRZEE2000TR4LTD will become famous soon enough
Real Name: John
What code are you getting? I assume you used Denso sensors. I'll also assume you have a Cali system (2 cats). What is the spacer for in the rear?
As far as replacements converters go, they really are cost prohibitive ($2000+ for both). And for the record, if you want to talk frustration, if you have any rust factor, the 3 flange bolts that mount the front cat to the crossover pipe will provide plenty more.
SILVER 2000 4runner Limited TOTALED
WHITE/SILVER 1999 4runner Limited l Rear Locker l Tundra/890 coils | 5100 Bilsteins all around | Sonoran Steel Bumpstops l 199 mm Tundra brake upgrade | SCS Matte Gray Ray10 Rims | 275 70 17 BFG KO2 tires | LR UCAs | EIMKEITH panhard brackets | LED interior upgrade l Rear LED tailights l Pioneer AVH-X5700BHS Alpine Type "R" speakers NVX JAD800.4 Class D Amp Kenwood Under seat Subwoofer l Front window tint 20% l Weathertech window visors and floormats l OutGear Solutions Full Length roofrack l Morimoto 40" LED lightbar
JRZEE2000TR4LTD is offline   Reply With QuoteReply With Quote
Old 10-29-2019, 08:57 AM #3
AntleredRuin AntleredRuin is offline
Real Name: Daniel
AntleredRuin will become famous soon enough
Real Name: Daniel
I have the single cat setup ('99 non cali) and I used the Walker 53287 with success. I'd assume the 2 cat setup from Walker would be of equal quality, but I don't have the part number(s).
And yes, those flange bolts are a PITA, specifically one of them. 2 came off easy for me (no rust in Texas) but the 3rd wasn't accessible with a breaker bar with extensions or with any useful length of box end wrench. I wound up having to sawzall the cat off to get the pipe out of the way.
I don't own any swivel sockets, but I'd bet that would make it a lot easier. FYI
AntleredRuin is offline   Reply With QuoteReply With Quote
Old 10-29-2019, 09:40 AM #4
brillo_76's Avatar
Real Name: Jon
brillo_76's Avatar
Real Name: Jon
I ended up cutting a notch in the Sway bar bracket to get that flange nut on my 97 5 speed. I even have the swivel impact sockets.
OEM Cats are very pricey. However, if you have Toyota do it. They will lifetime warranty your exhaust. You will spend some serious $$ to do that though. Last time I priced an OEM exhaust for a 3rd gen 4 Runner. I think the cost was going to be 3K from the header all the way to the tailpipe. :-(
It would probably be best to heat those nuts up to red hot and hit them with penetrating oil a few times. I also believe those are supposed to be replaced every time you take them off as they are special nuts that grip the stud to hold the flange tight.
On my 97, they came right off. Which is surprising as I and the truck spent our lives in the rust belt. I was thankful.
Old 10-29-2019, 11:24 AM #5
Are you noticing any antifreeze loss?
Antifreeze in the CAT is one thing that will cause the dreaded P0420 code.
Old 10-29-2019, 06:46 PM #6
gamefreakgc's Avatar
Real Name: Jerod
Real Name: Jerod
There's a few 49 state options out there. Last I checked Toyota charges $1,200 for a replacement rear cat, that's just for the part.
Magnaflow sells a high-flow cat that's around $250.
326WHP 347TQ
Old 10-29-2019, 06:57 PM #7
brillo_76's Avatar
Real Name: Jon
brillo_76's Avatar
Real Name: Jon
If Antifreeze is getting into the exhaust don't we mostly see the white cloud smoke coming out the tailpipe? Well that what I had when the head gasket leaked on one.
Old 10-29-2019, 08:44 PM #8
Ed_C's Avatar
Ed_C Ed_C is offline
Real Name: Ed
Ed_C's Avatar
Real Name: Ed
What year and does it have a single or dual cat system? Mine has the dual cat system, replaced both spring 2015 with Walker OEM replacements and so far so good.
Old 10-29-2019, 09:04 PM #9
brillo_76's Avatar
Real Name: Jon
brillo_76's Avatar
Real Name: Jon
The early years 96 -98 federal ones have one cat with 2 sensors. Front sensor is air/ fuel sensor. The back is the o2 sensor. I believe 99 -02 are all 2 cat systems.
It's an old trick to put a few gaskets under the 02 sensor to basically fake the ecu out that a cat is burned out. I have a 02 Camry with a burned out cat. I just check the cel light from time to time to make sure there isnt anymore codes . ;)
Old 10-29-2019, 09:46 PM #10
2ndhandyotaman's Avatar
2ndhandyotaman 2ndhandyotaman is offline
2ndhandyotaman will become famous soon enough
I used Bosal cats on my '99 about 2 years ago, they have worked well and cured the constant P0420 codes that I was getting. The truck just passed it's 2nd emissions test since I've owned it.
'99 Limited, 225K miles, 3.4/automatic, multi-mode, e-locker, broken sunroof, no DRL's. 265-75-16 Hankook Dynapro ATM. New Moog rear springs, KYB Monomax F&R.
2ndhandyotaman is offline   Reply With QuoteReply With Quote
Old 10-29-2019, 10:01 PM #11
pluton's Avatar
pluton pluton is offline
Real Name: Keith
pluton has a spectacular aura about pluton has a spectacular aura about pluton has a spectacular aura about
pluton's Avatar
Real Name: Keith
It would be helpful to all if everyone on this forum created a signature that lists the 4Runner(s) that they own: year, 2WD/4WD, Engine, Trans, major mods, etc.
pluton is offline   Reply With QuoteReply With Quote
Old 10-29-2019, 11:08 PM #12
This is my specific scenario. My engine form the 96 I put in the 97,engine bay. It had issues since the accident. It ended up being a bad liner.
Old 10-30-2019, 01:21 AM #13
Ed_C's Avatar
Real Name: Ed
Ed_C's Avatar
Real Name: Ed
The question was meant for the OP ;)
I hope your Camry's converter isn't actually damaged to the point where the core has broken apart...probably not since it would've caused poor drivability.
Old 10-30-2019, 05:38 AM #14
Sorry - mine is an 01, v-6 2wd.
I'll check into the walker parts - thanks. If the spacer works maybe that's all I will do. #3,000 it will not be - that's for sure!
Thanks for the replies
Old 10-30-2019, 06:20 AM #15
HiLife HiLife is offline
A scum bag stole the OP's cat while he owned it. An aftermarket cat was already there when I purchased it 5 years ago. So far so good.
I agree with you, my rig fights me all the way while I'm wrenching on it. And the good side is it's has been rock solid reliabile afterwards.
aftermarket , buy , sensors , stealership , winter
FREE!! Wiring harness for aftermarket radio with aftermarket amp fblainen11 3rd gen T4Rs 4 01-30-2019 05:16 PM
Aftermarket?? Smitty777 Engines / Suspension / Wheels / Tires / Audio / Accessories 1 04-26-2016 05:37 AM
Aftermarket? jca21 5th gen T4Rs 16 01-22-2010 06:52 PM
aftermarket ac rico55 General Discussions 3 08-03-2008 03:29 PM
Which aftermarket DVD? linvillegorge Engines / Suspension / Wheels / Tires / Audio / Accessories 8 03-20-2005 04:57 PM
