10-31-2019, 02:04 PM
#16
Real Name: The Native Explorer
Originally Posted by Bad Luck
How do you upload photos directly? I'm on a Windows 10 computer using chrome if that makes a difference. I'd prefer not to get tapatalk to add photos, but I will if I must.
Picture Upload Instructions:
1. Click the orange "Reply" button at the bottom of the thread, it will redirect to the advanced reply page.
2. Scroll down below the text box to the green "Manage Attachments" button. Click that, popup opens.
3. Click "Choose file" and select your picture - note, can only do one at a time here. Once selected, hit the green "Upload" and wait for the picture title to appear below the "Choose file" button.
4. Repeat step 3 for as many (up to 5 I think) pictures as you would like. Also, the pictures must be resized to below ~1.5 Mb for this to work.
5. Click "Close This Window", type your reply in the text box if applicable, then the green "Submit Reply".
Let me know if you have any questions on the matter!
"Bumble" '17 Lim w/ 35k, IVD Stage 7, CBI/Prinsu metal, Morimoto lighting, ARB Linx : Build thread in progress...
The AventuRunner Build '07 V8 Sport w/ DO armor, Fox squish, Falken rubber, IVD UCAs, BD lights, Sherpa rack -- gonna miss the V8
The "Iceberg" Build... Natty White 3rd Gen ----gone, but not forgotten...
IG @apohl17
From ye fellow @Konkordmusk... "The 4Runner does not drive. It simply rotates the Earth to your desired position."
11-01-2019, 12:14 AM
#17
Real Name: Real Name
Originally Posted by pluton
Whether you use tapatalk or not, please post your photos directly to this forum and not using an online picture hosting service. Why? Because all online services will fail, or change terms, or start charging money. Once that happens, the photos that you took all that time to share are lost to the future users of this forum.
Oh, and if you do happen to get tapatalk, please turn off the advertisement that says 'sent using tapatalk' if you would please. Those ads do not support the forum, or you, or anybody except tapatalk.
I wish I knew how to turn off the sent by Tapatalk signature.
Sent from my XP7700 using Tapatalk
1999 Hilux Surf SSR-X, 140xxx kms, 4x4, 2.7L, AT, RHD, 17" Sequoia wheels, 10 ply Goodyear Wrangler A/T tires. Stock. Minty. Daily driven.
11-01-2019, 08:32 AM
#18
1. Click the Tapatalk Icon to open 'er up.
2. Click the person icon (floating circle above abstract shoulders) on the right side of the screen, below the plus icon.
3. Click "Settings"
4. Click the label "Signature" (third one down from the top)
5. Click the blue slider so the text and bar goes grey. Now your signature is off!
(This is for Android, not sure how different it is with iOS)
IG @apohl17
11-01-2019, 08:38 AM
#19
Change the front lower ball joints and also either change the radiator or bypass it with a external transmission cooler.
11-02-2019, 02:00 PM
#20
3. Click "Settings"
Ok cool well I think I got it. All due to your excellent directions. Thanks!
11-06-2019, 02:28 PM
#21
Well now that I have the title work done & my thread has been hijacked...
What does the dealer mean when he said I have an SR5V???
11-06-2019, 03:07 PM
#22
Probably SR5 V6. If so, trim level and engine.
'17 Chevy Volt Premier
'16 Honda Odyssey Elite
11-07-2019, 07:04 PM
#23
Has the factory hood scoop, fog lights, moon/sunroof, power everything ...
Kind of thinking it's a SPORT???
11-07-2019, 07:23 PM
#24
"Sport" was an option package available on the SR5 trim. The exact details varied with model year. "Sport" seats are a standalone option too.
05-04-2020, 03:01 AM
#25
Is the SMOD a comon issue with these?
05-04-2020, 09:32 AM
#26
Sorry, didn't sleep well. Smod?
05-04-2020, 01:24 PM
#27
Strawberry Milkshake of Death. Normally called a Pink Milkshake on here. Transmission fluid and radiator fluid mixing.... normally the death of the transmission.
05-04-2020, 01:45 PM
#28
Real Name: Angelo
Real Name: Angelo
Just picked up a 3rd gen runner yesterday too! Time to do some research and digging.
05-04-2020, 05:23 PM
#29
Ah yeah! That's why I say to swap out the radiator at the minimum, but better yet...bypass it with an external cooler.
05-05-2020, 12:22 AM
#30
Originally Posted by Big Bad Dad
I too, am new with a 3rd gen 4Runner. I have some questions, and need some helpful advice. But I am not allowed to start a new post with a question. Not sure what the reason is for that......
Anybody know what the ABS codes are? I found online how to check them, but finding the meanings of the codes is not too easy....
You need a high level scan tool to read them. Normal bluedriver type plug ins only read check engine lights. Common 3rd Gen abs codes are for bad abs wheel speed sensors though.
1999 Autumn Blaze Metallic Sr5 4x4 Bilstein 5100 Front/4th Gen Bilstein 5100 Rear OME 881/890 Sport Hood
2002 Sunfire Red Pearl Sr5 Sport 2wd
