Originally Posted by clt750
I was replacing a headlight and decided to go through a fluid check and noticed the coolant was red. I have never used red coolant only green mixed with water.
The OEM engine coolant is red! You only have a mixing problem if the coolant is a milkshake-like pink.
Reddish brown trans fluid just means it is old and worn. It will also be red when new.
While I'm at it... Your power steering fluid is also red! (standard ATF, just like the transmission) If it is anything but red, it should also be changed out to a Dexron compatible ATF.
'99 4Runner SR5 Auto -
4WD swapped
'17 Chevy Volt Premier
'16 Honda Odyssey Elite
