Old 11-04-2019, 01:14 PM #16
calnhob's Avatar
calnhob calnhob is offline
calnhob is on a distinguished road
calnhob's Avatar
Hope this helps, tested the time on my parts collection.
OEM might be the original one on the truck with 214k when I replaced it. BS 5100 for 3rd gen has less than 2 years on it.
Also my LCA moved the same way on both sides when I was adjusting the perch on the 5100 so it doesn't seem out of whack.
"Small Front Lift" question #785-img_0026-jpg
97 SR5 w/ elocker, 250K | BS 5100 adjustable front 5th gen coils, 5100 rear LC springs | KO2 285/70R17 on '15 Trail Rims | TBU | X-Bull 12K Winch | TG Sliders | front & rear NWTI bumper kit
calnhob is offline   Reply With QuoteReply With Quote
Old 11-04-2019, 01:44 PM #17
Originally Posted by 4Runner4Leon View Post
So again, a 3/8" spacer should be fine based on this. Right?
On that shock, you could use a full 1/2" spacer (~1 inch lift). You will need extended studs for the top plate/mount.
'17 Chevy Volt Premier
'16 Honda Odyssey Elite
Old 11-04-2019, 02:41 PM #18
4Runner4Leon's Avatar
4Runner4Leon 4Runner4Leon is offline
Real Name: Leon
4Runner4Leon is a name known to all 4Runner4Leon is a name known to all 4Runner4Leon is a name known to all 4Runner4Leon is a name known to all 4Runner4Leon is a name known to all 4Runner4Leon is a name known to all
Real Name: Leon
Wow, that's way faster than mine. Time for new shocks I guess!
Good to know, that's a relief. Thanks Wei!
1997 4Runner Limited 4WD E-Locker ~200k | Falken Wildpeak A/T3W 265/75/16 | Pro Comp 69 16x8 | OME 2906 | B&M 70264
Addicted Offroad Front Bumper | Spiker Engineering High-Lift Hood Struts and Ultragauge Mount
4Runner4Leon is offline   Reply With QuoteReply With Quote
Old 11-04-2019, 02:42 PM #19
Real Name: Leon
Real Name: Leon
Thanks for confirming Charlie! I went ahead and ordered the 1/2" spacers, but will check this again since I also ordered new shocks.
Old 11-10-2019, 07:49 PM #20
Real Name: Leon
Real Name: Leon
Put in the 1/2" top plate spacers today, along with new shocks.
I went with KYB KG9025 Gas-a-Just shocks, basic OEM replacement. Here they are side by side:
The new shocks extend much faster than my old ones did, for what it's worth.
To install the top spacers, I replaced the original top plate studs with longer studs:
Here is the shock assembly with the spacer on top:
I double checked droop and full compression, and found that I have margin at each end of travel.
After driving around the block, I rechecked the hub to flare distance - it went from 21.25" to about 22.75", a bit more than I planned for. Hopefully it'll settle in a bit after driving some more (otherwise I'm going to have to raise the rear to make it level, not sure how my wife is going to like that). Here's a comp photo:
Old 11-11-2019, 11:26 AM #21
calnhob's Avatar
calnhob's Avatar
Where do you get those extended studs?
Do you have a full side shot showing both front and rear?
You know now that you have a front lift you'll have to get a rear one...then sliders...then steel bumpers...the list gets long and the wallet gets thin.
Old 11-11-2019, 11:58 AM #22
Real Name: Leon
Real Name: Leon
I got the studs here - 2" Top Plate Stud, Set of 6
They are a bit overkill for the 1/2" spacers, but the original studs were going to be too short.
Here is the truck in its full glory, front end pointing upwards . Maybe it'll settle.
Old 11-11-2019, 03:58 PM #23
I'm surprised it lifted the front end that much too! I don't expect it to settle, as they are your original springs, right? Maybe some smaller spacers are in your future...
And you can see the difference in the extended length of the new shocks there, compared to stock...
Old 11-11-2019, 08:15 PM #24
Real Name: Leon
Real Name: Leon
Yup, original springs, not much settling to be expected there for sure. One area where it might settle a tiny bit is that there was a permanent indentation in the rubber spring isolator under the mount from the spring end. I rotated the isolator so that a undented portion was now under the spring end, but the indentation was no more than about 1/8". So not much to be gained there.
Good news is that if/when I decide to use a smaller spacer, I won't have to undo the spring from the shock, just drop the whole assembly and slide in a new spacer. I can almost do that with my eyes closed now.
Old 11-12-2019, 10:57 PM #25
snydmax's Avatar
snydmax snydmax is offline
Real Name: Matt
snydmax will become famous soon enough
snydmax's Avatar
Real Name: Matt
Dumb question, can you swap those studs without disassembling the strut/coil?
'98 4WD Limited, Warm Grey, 172k, Factory E-Locker, Ride-Rites, 265/75-16 Wildpeak AT3s
snydmax is offline   Reply With QuoteReply With Quote
Old 11-13-2019, 12:46 AM #26
Real Name: Leon
Real Name: Leon
Unfortunately not. So you'd want to do this at the same time as swapping shocks or springs, unless you enjoy using the spring compressor over and over .
bring , front , lift , moogs , springs
Bilstein 6112 2.5" Front Lift, 2" Toytec Rear Springs with either FOX or ICONs..?? fromLRtoT4R 4th Gen T4Rs 13 05-17-2019 05:02 PM
FS: 4th Gen 1" Toytec Body lift, 1" leveling front spacer lift mcwalke2 For Sale: Suspension/Wheels/Tires 6 02-05-2016 12:59 PM
1.25" front spacer lift question delloro 5th gen T4Rs 1 12-31-2015 02:30 AM
"New" 1991 4runner with small lift kit woodenkayaker New Members 3 07-23-2012 10:25 PM
cornfed 3" front / 2" rear lift for 2003+ 4Runner minghi Classifieds - buy & sell (no commercial ads please) 13 08-24-2007 09:45 AM
