Old 11-01-2019, 10:41 AM #1
4Runner4Leon's Avatar
4Runner4Leon 4Runner4Leon is offline
Real Name: Leon
4Runner4Leon is a name known to all 4Runner4Leon is a name known to all 4Runner4Leon is a name known to all 4Runner4Leon is a name known to all 4Runner4Leon is a name known to all 4Runner4Leon is a name known to all
Real Name: Leon
"Small Front Lift" question #785
I've read lift threads till I'm blue in the face, but haven't found the answer I need - what would you guys suggest I do to raise my '97 4Runner's front to about 22" hub to flare?
I currently have 5th gen springs in the back, which give me the 22" distance I want. I tried Moog's "99 talls" in the front, but that raised the front from 21" to 21.2".
So what can I try to bring the front up about an inch? 5100's with OEM springs? Beefier springs? I'd really like to maintain a good ride quality, as I hardly ever go offroad.
1997 4Runner Limited 4WD E-Locker ~200k | Falken Wildpeak A/T3W 265/75/16 | Pro Comp 69 16x8 | OME 2906 | B&M 70264
Addicted Offroad Front Bumper | Spiker Engineering High-Lift Hood Struts and Ultragauge Mount
4Runner4Leon is offline   Reply With QuoteReply With Quote
Old 11-01-2019, 12:54 PM #2
If you are happy with your current ride quality and you have a bit of droop left before you are limited by your ball joints, get a 3/8" top plate spacer (and extended top plate studs). That'll add the 3/4" you are looking for and get you a bit more suspension droop. Wheeler's has that stuff for pretty cheap.
'17 Chevy Volt Premier
'16 Honda Odyssey Elite
Old 11-01-2019, 01:14 PM #3
Dezert4Runner's Avatar
Dezert4Runner Dezert4Runner is offline
Real Name: Evan
Dezert4Runner has a spectacular aura about Dezert4Runner has a spectacular aura about Dezert4Runner has a spectacular aura about
Real Name: Evan
Top plate spacer will keep the ride the same as what you have now, but if you don’t want to make your LBJ’s the new bump stop I’d suggest putting those moog springs on some Tundra 5100’s and move it up a clip or two from the bottom or middle clip on the Tacoma/ 4Runner variant. The ride would be a bit former but I other than top plate spacers or body lifts, everything else will affect the ride and make it feel firmer to some degree.
2000 Black Sport 4WD 5spd -JD Fabrication long travel/ Fox 2.5 8” RR/ Anonymous Fab lower uniball• McNeil Racing fenders • Toytec Superflex/ 5th gen Bilstein 5100/ Wheelers Superbumps • 315/70/17 BFG KO2 on Robby Gordon wheels • 231mm TBU / Wheelers SS lines • MStudt rear swaybar links • Tom Woods driveshaft • Satoshi • K&N FIPK w/ AFE dry filter • Borla Pro XS • URD short throw shifter & Ellis Precision shift knobs • Uniden PRO 520XL & 3' Firefly on custom mount• Prinsu full rack • Baja Designs Squadron Sport Sae & combo beam lights • Paranoid Fab switch panel with Ram mounts • Extended rear diff breather • 01-02 tail lights • Stubbs HD-SKO sliders • Any 7 Offroad gas tank skid • @Assburns custom tube front bumper • Nguyen Works swing out bumper • FROR rear links
Dezert4Runner is offline   Reply With QuoteReply With Quote
Old 11-01-2019, 01:54 PM #4
Real Name: Leon
Real Name: Leon
So something like this? 1/2" Thick Single Strut Top Plate Spacer, for 95-04 Tacoma, 96-02 4Runner, 99-06 Tundra
Can you elaborate a bit on "if you have a bit of droop left before you are limited by your ball joints" and "if you don’t want to make your LBJ’s the new bump stop" - how do I check for the remaining droop and avoid having LBJ's become the bump stop?
Old 11-01-2019, 02:03 PM #5
Real Name: Evan
Real Name: Evan
The stock LCA bump stops are designed to stop travel before your coilovers bottom out which in turn makes your LBJ your new bump stop. I’m not sure what the exact tolerances of a top plate spacer will allow before that happens since you can’t exactly compress the front wheel enough to to see due to the spring rate. You’d have to disassemble the coil and shock and mock up the top plate with the top plate spacer and shock and see if your bump stop is still the first thing to stop travel. Most people aren’t going to go to those lengths to check. I personally wouldn’t run them out of principle based on the above explanation, but lots of people do though so it’s your call.
Old 11-01-2019, 03:29 PM #6
Yeah, though you may want to use the 3/8" spacer (or get the 1/4, 3/8 and 1/2 all, as options...)
To check the amount of droop you have left in your ball joints, you need to loosen all the pivot bolts (top long one and each lower adjuster bolt), remove the swaybar connection and the shock lower bolt. Let the knuckle drop. The upper ball joint is the limiter on the stock arms, the lower arm or axle will be the limit on aftermarket upper arms. You will be able to see how much you can space the shock down. You want the shock to limit down travel.
For up travel, you will have to remove the spring from the coilover assembly and lift up that corner of the truck with a jack under the lower arm/ball joint. You need to make sure you have enough compression left in the shock when it is fully compressed so that the bump stops on the arm stop suspension travel before the shock bottoms out. Leave a bit of extra room there for extra bump stop compression that you can't simulate with the static vehicle weight.
I did, which is how I figured out which spacer I could get away with while running stock arms and 4Runner 5100's...
That's an assembled front shock with no spring and the truck's weight on that corner, stock a-arm bump stops in place and a 3/8" top plate spacer. That was as much spacer as I could run for droop travel, and it was safe in compression.
Old 11-01-2019, 04:05 PM #7
Real Name: Evan
Real Name: Evan
Good stuff Phattyduck. I wonder if there is any minute compression from the LCA bumps and if the extra bit of shock shaft is all usable on compression before it actually limits out. Either way, it’s good to have a visual of it all.
Old 11-01-2019, 04:50 PM #8
Real Name: Leon
Real Name: Leon
Thanks Charlie, that makes sense. Just curious, why did you go with the top spacer instead of moving up the perch on the 5100? Was it to maintain the original preload on the spring?
Old 11-01-2019, 05:24 PM #9
Real Name: Leon
Real Name: Leon
Thinking about all this some more - shouldn't the max allowable spacer size for compression and droop be the same for all stock trucks? Or are there too many subtle differences (I'm guessing I can't just use your results since my stock shock may be different from your 5100)?
Old 11-01-2019, 05:48 PM #10
I'd expect there to be some more compression of the bumps with a hard hit - though I am personally never going to try to do that! I don't have much interest in jumping my 4Runner.
I was going for max available travel. The shock itself is spec'd for 4.61" of travel, which could translate to about 9" of wheel travel if everything is perfect.
The max spacer is different for each shock design, depending on max length. The OEM shocks are something like 1" shorter than most of the aftermarket stuff. That may be enough of a reason to change to something aftermarket. The Bilstein Tundra front shocks are spec'd for 5.12" of travel, both slightly shorter collapsed (~0.1") and longer extended (~0.4")... Then if you get new upper a-arms, you get more droop... you can see the rabbit hole.
Old 11-01-2019, 07:38 PM #11
Real Name: Leon
Real Name: Leon
Thanks Charlie. I'll be making some of these measurements this weekend.
Old 11-02-2019, 01:49 PM #12
Real Name: Leon
Real Name: Leon
Here is what I came up with - with the control arms pivots loosened, and the shock upper mount still attached to the spring perch, the control arm droops about 0.7" further than the max shock extension:
So that suggests that a 3/8" spacer would still leave ~3/8" droop.
As for compression, I removed the spring and jacked the LCA until the truck lifted off the jackstand:
I then pushed down on the shock, to get it fully compressed, and there was over an inch gap between the top of the shock mount and the bottom of the spring perch (the two orange lines):
So again, a 3/8" spacer should be fine based on this. Right?
I noticed a couple of weird things when doing this: one, I could easily move the LCA up and down without loosening the lower pivot bolts at all. Two, if I compressed the shock and then let it go, it extended very slowly, maybe 10-20 seconds to extend fully. Is that normal for these trucks?
Old 11-02-2019, 06:03 PM #13
calnhob's Avatar
calnhob calnhob is offline
calnhob is on a distinguished road
calnhob's Avatar
Hey Leon,
It shouldn't take 10-20 secs for the shock to extend back..that's too long. It'll should be around 5-7sec if I remember correctly.
I had this setup and got around 22.5" 5100 on first perch with 5th gen TRD off road springs.
The 5th gen springs are about the same length as the 3rd stock ones but are thicker.
Wei
97 SR5 w/ elocker, 250K | BS 5100 adjustable front 5th gen coils, 5100 rear LC springs | KO2 285/70R17 on '15 Trail Rims | TBU | X-Bull 12K Winch | TG Sliders | front & rear NWTI bumper kit
calnhob is offline   Reply With QuoteReply With Quote
Old 11-02-2019, 09:01 PM #14
Real Name: Leon
Real Name: Leon
Originally Posted by calnhob View Post
Hey Leon,
Wei
Thanks Wei! I don't think I want to be as high as 22.5", so I might just go with the spacer and keep my original springs... and maybe get new shocks, if I need them based on the slow extension. Here's a clip of my shock extending, I was doing this one handed to it was already moving when I started filming, and still takes about 18 sec. So does that mean the shock is shot?
And what about this control arm movement? I'm moving it up and down by hand, with the pivot bolts fully tightened.
Old 11-03-2019, 09:34 PM #15
calnhob's Avatar
calnhob's Avatar
when I click on the video it says the video is private...you afraid to share with me?
bring , front , lift , moogs , springs
Bilstein 6112 2.5" Front Lift, 2" Toytec Rear Springs with either FOX or ICONs..?? fromLRtoT4R 4th Gen T4Rs 13 05-17-2019 05:02 PM
FS: 4th Gen 1" Toytec Body lift, 1" leveling front spacer lift mcwalke2 For Sale: Suspension/Wheels/Tires 6 02-05-2016 12:59 PM
1.25" front spacer lift question delloro 5th gen T4Rs 1 12-31-2015 02:30 AM
"New" 1991 4runner with small lift kit woodenkayaker New Members 3 07-23-2012 10:25 PM
cornfed 3" front / 2" rear lift for 2003+ 4Runner minghi Classifieds - buy & sell (no commercial ads please) 13 08-24-2007 09:45 AM
