Old 11-03-2019, 03:55 AM #1
Cvett95 Cvett95 is offline
Cvett95 is on a distinguished road
Anybody Running Airlift 1000s with a 3 lift? (Superflex)
I’ve recently built a 17ft car trailer to haul all the crap out of my driveway (cars, washing machines, etc.) and was gifted a new set of Airlift 1000 load leveling springs #60743 designed for stock springs. My problem is I don’t have stock springs. Currently running Superflex’s. When I had the springs out I put the bags in and started wondering... wondering if I need to get different bags. I opted not to install them and seek a little help. I contacted Airlift last Wednesday but have not gotten a response.
Is anybody out there running these bags with a 3” lift?
Any help is greatly appreciated.
97 SR5 2x4 177k | Front: Bilstein 5100+toytec 600# /Rear: Fox 2.0 Performance Series Struts+SuperFlex coils, JBA UCA, Whiteline LCA bushings, OEM Ball Joints, Tie Rods, and Front Links, 2nd Gen Rear Links, T-Belt, T-Stat, Water Pump, B&M 70268, 295/70/17 Nitto Trail Grappler Wrapped GX470 wheels, UltraGauge, Trans Temp Gauge, HID Retrofits, Recycled Barn-Door Cargo Drawers, Home-made Doggy Divider, Satoshi Inspired Grille, Max-life ATF, Toyota Red Coolant, 5w-30 Pennzoil Ultra Platinum w/20% HD Hyper-Lube, eBay Window Visors, Tint, $20 Walmart Keyless Entry, Cheap Alpine H/U and Speakers, Bed Linerd frame, and a whole bunch of fishing gear.
Cvett95 is offline   Reply With QuoteReply With Quote
Old 11-03-2019, 12:09 PM #2
RotaryDreamz's Avatar
RotaryDreamz RotaryDreamz is offline
Real Name: Sean
RotaryDreamz is on a distinguished road
Real Name: Sean
I run them on my OME 891's in the rear. I have a rear bumper with tire carrier and am loaded up when i go hunting. No issues whatsoever. I keep 10 psi when not loaded, 35-40 psi depending what I'm hauling. Sorry no pic on my phone right now, but I can snap a pic for you if it will help.
RotaryDreamz is offline   Reply With QuoteReply With Quote
Old 11-03-2019, 09:02 PM #3
brookester brookester is offline
brookester is on a distinguished road
I would be interested in that pic. My 891s are starting to sag .
brookester is offline   Reply With QuoteReply With Quote
Old 11-03-2019, 09:32 PM #4
UnderFire's Avatar
UnderFire UnderFire is offline
UnderFire has a spectacular aura about UnderFire has a spectacular aura about
UnderFire's Avatar
Might be smart to look into 4th gen 4runner/FJ ones for a lifted application if theyre actually any different.
Sent from my JSN-L23 using Tapatalk
'97 3RZ 5 Speed "FrankenRunner" (Build Thread) - Dormant
The "shitmobile" 500$ 3RZ Auto 4Runner - (Saved from the Scrapyard: Resurrecting a 500$ 3rd Gen
02 Tacoma Double Cab, mid-travel, locked, armored, supercharged and riced. (Longbed and 5 speed in the works)
UnderFire is offline   Reply With QuoteReply With Quote
Old 11-04-2019, 12:29 AM #5
@RotaryDreamz I would love it if you could snap a couple pics for me. Im beyond embarrassed to say it but Im somewhat stumped.
Old 11-04-2019, 04:08 AM #6
JD914's Avatar
JD914 JD914 is offline
JD914 is on a distinguished road
JD914's Avatar
Not a 3rd gen, but Ive been running airbags (stock size) in my 4Runner with a 3 lift for years. No problems at all, as long as you keep 5lbs in them at all times, as recommended.
04 V8 Limited
Lifted, lit, locked, protected
Coffee machine and crock pot equipped
JD914 is offline   Reply With QuoteReply With Quote
Old 11-04-2019, 03:10 PM #7
Thanks JD914!
Old 11-04-2019, 03:35 PM #8
Toy2play Toy2play is offline
Toy2play is on a distinguished road
Originally Posted by Cvett95 View Post
Ive recently built a 17ft car trailer to haul all the crap out of my driveway (cars, washing machines, etc.) and was gifted a new set of Airlift 1000 load leveling springs #60743 designed for stock springs. My problem is I dont have stock springs. Currently running Superflexs. When I had the springs out I put the bags in and started wondering... wondering if I need to get different bags. I opted not to install them and seek a little help. I contacted Airlift last Wednesday but have not gotten a response.
Is anybody out there running these bags with a 3 lift?
I run the airbags in my OME 906 springs with two trim packers(almost 3" lift) on top of the coil for years now. Only issue I had was the valve core leaked when I first installed them. Took me forever to figure out it was that. I've towed roughly 3k lbs pop up, and done thousands of miles offroad travel with them. Held up just fine. When not weighted down you want to make sure you keep roughly 8-10 psi in them. I usually run 30 psi when I have a heavy load. Offroad flex hasn't been an issue for me, but I'm not doing anything too crazy.
97 Charged, lifted, armored, geared, locked SR5.
Toy2play is offline   Reply With QuoteReply With Quote
Old 11-05-2019, 01:22 AM #9
Real Name: Sean
Real Name: Sean
Sorry if pics aren't very clear. I put the nipple on the bottom and ran the line that way. I cut the coil cone as well. Please dont mind my bad panhard bracket welding. Haha.
Sent from my SM-N960U using Tapatalk
airlift , bags , running , springs , wondering
Airlift 1000 question big44g 5th gen T4Rs 2 08-07-2017 05:17 PM
FJ Springs and Airlift 1000 Morphyne 4th Gen T4Rs 2 11-10-2013 11:17 PM
Airlift 1000 and 2wd? Mbiker_101 4th Gen T4Rs 1 11-09-2012 09:12 AM
WTS: 96-02 3rd gen Airlift 1000 awpsome Classifieds - buy & sell (no commercial ads please) 16 05-15-2011 07:40 PM
Copyright © 2019
