Old 11-04-2019, 08:19 AM #1
eurasiaoverland eurasiaoverland is offline
eurasiaoverland is on a distinguished road
Turn signal does not cancel when turning one direction
Hi guys
The turn signal auto-cancel does not work in one direction on my truck (can't remeber which) - in other words the turn signal does not switch off after I've made the turn and return the steering wheel to the straight ahead position.
Has anyone had this? What was the solution?
I can see it either being the stalk switch (for lights / turn signal) which is cheap to replace, or the whole steering wheel assembly which is not.
Thanks
EO
(Sorry for the grievous typo in the title)
1993 Hilux 2L diesel manual - in storage.
1996 Hilux Surf 3RZ-FE manual - overland vehicle (and rolling restoration).
1989 Landcruiser BJ60 - undergoing full restoration and engine transplant.
Over 250,000 kilometres around Eurasia in Toyota trucks: http://eurasiaoverland.com/
eurasiaoverland is offline   Reply With QuoteReply With Quote
Old 11-04-2019, 10:23 AM #2
brillo_76's Avatar
Real Name: Jon
brillo_76's Avatar
Real Name: Jon
My contacts in my turn signal wore out. So I bought an aftermarket turn signal. Well it wouldn't latch or disengage after the turn was made. So what I did was take the contacts out of the China after market one and put them in my OEM. Been a year now good as new
Old 11-04-2019, 10:26 AM #3
Bad Luck Bad Luck is offline
Real Name: Patrick
Real Name: Patrick
Since it turns off in one direction and not the other I would lean towards it being the turn signal stalk
Old 11-04-2019, 10:28 AM #4
So your turn signals stopped working? Mine work fine, they just don't switch off automatically when turning in one direction. If my signals are working, I don't think it can be a contact causing the problem - surely it's a mechanical process to switch the turn signal off again?
Old 11-04-2019, 11:04 AM #5
brillo_76's Avatar
Real Name: Jon
brillo_76's Avatar
Real Name: Jon
My contacts literally warn out. Nothing was left. So they couldn't make contact. When I priced OEM I said no way. So I found a A/M replacement. Worked except It wouldnt stay engaged at all. So I just replaced the contacts in my OEM one eiry the chineses contacts and solved my issue. If the will not stay engaged until the turn is complete that sounds exactly like my chinese replacement did.
Old 11-04-2019, 01:10 PM #6
3bears 3bears is offline
Real Name: 3 Bears
Real Name: 3 Bears
in most cases its the switch
Old 11-04-2019, 01:19 PM #7
mtbtim's Avatar
mtbtim mtbtim is offline
Real Name: Tim
mtbtim's Avatar
Real Name: Tim
I'm guessing since you're in the Netherlands, finding a used turn signal stock on a wrecked 3rd Gen 4runner might be difficult. Maybe a seller of a used one on Ebay would ship one to you. Also, I bet there's someone on this forum that has one they'd be willing to sell you. Lots of guys on this forum visit PicknPulls and other wrecking yards to grab parts that they need.
You could use this video to learn how to access it and replace it:
direction , signal , steering , switch , turn
2015 SR5P Turn Signal not turning off after turning aperture_vision 5th gen T4Rs 10 05-08-2015 05:50 PM
Which direction does the Power Steering Pump pulley turn on the 5VZFE (3.4)? xcmountain80 3rd gen T4Rs 2 08-18-2014 07:58 AM
Turning signal xoalvinox 4th Gen T4Rs 4 04-20-2009 06:08 PM
Turning Signal/drl xoalvinox 4th Gen T4Rs 13 05-07-2004 04:45 PM
