Old 11-06-2019, 05:04 PM #16
brillo_76's Avatar
Real Name: Jon
brillo_76's Avatar
Real Name: Jon
Mostly the TPS throw a CEL when they start going. I agree with the others. Do a service manual test on that TPS. That is jumping all over the place like it doesn't know what to do.. It wouldn't be the first time a TPS is bad and the CEL isn't being thrown on.
Old 11-06-2019, 06:10 PM #17
rich dog rich dog is offline
rich dog is on a distinguished road
Originally Posted by phattyduck View Post
Based on what I'm seeing there, the truck is in 3rd gear, then when you floor it, it shifts to 4th and oscillates between locked and unlocked torque converter.
First try driving with OD turned off, which will lock out the trans from 4th gear.
My crazy thought is that you have a bad TPS, which is confusing the ECU as to what gear it should be in...
with o/d off truck is running fine.
rich dog is offline   Reply With QuoteReply With Quote
Old 11-06-2019, 06:11 PM #18
gonna order a new tps tonight. pretty sure its got the original on there
Old 11-06-2019, 06:12 PM #19
Originally Posted by Bad Luck View Post
It sounds and looks like a tps issue. What year and trim is your 4Runner?
2000 highlander sr5.
Old 11-06-2019, 06:19 PM #20
Bad Luck Bad Luck is offline
Real Name: Patrick
Real Name: Patrick
Lucky for you the tps can be replaced separately from the throttle body for your vehicle. Part number is 89452-35020 for a new throttle position sensor.
Edit: If you need to replace it or decide to throw a part at it.
Old 11-06-2019, 06:45 PM #21
It would be best to TEST the TPS before just throwing parts at it. Sometimes aftermarket parts will cause more problems than they solve. Also, you need a multimeter to adjust the new TPS after install, I believe...
'17 Chevy Volt Premier
'16 Honda Odyssey Elite
Old 11-06-2019, 07:04 PM #22
brillo_76's Avatar
Real Name: Jon
brillo_76's Avatar
Real Name: Jon
Like Charlie said TEST the TPS sensor. I said best to Test the TPS sensor as it may not be the problem and you be throwing money out of the window.
Old 11-09-2019, 05:27 PM #23
update: swapped in an oreilly tps sensor and seems to have fixed the rpm drop. Thanks for all the help and suggestions!you guys are great!
Old 11-09-2019, 05:53 PM #24
MaineRunna's Avatar
MaineRunna MaineRunna is offline
MaineRunna will become famous soon enough MaineRunna will become famous soon enough
MaineRunna's Avatar
Do you have a kick down cable and is it hooked up? TPS, TCC & park/neutral switch seem like possibilities as well.
98 SR5 4X4 5spd, desert dune metallic, Toytech Eibach 3" lift, 1" body lift, RAD Rubber Designs splash guards, 4XInnovations bumpers, Doug Thorely Headers, Magna-flow converter, JBA muffler & tail pipe, RCI skid plate, SPC UCA's & rear LCA's, front sway bar links on rear, gen II rear links on front, Tundra brakes, '02 headlights, tail lights & sidemarkers, BFG 255/85R16 Mud Terrain T/A's 241,000 miles.
MaineRunna is offline   Reply With QuoteReply With Quote
jump , question , times , transmission , truck
Transmission question Vols77 3rd gen T4Rs 6 08-13-2018 06:08 PM
Transmission Question 1998Yota4Runner 3rd gen T4Rs 4 01-15-2015 01:55 AM
Transmission question blakjack23 4th Gen T4Rs 10 10-21-2013 10:58 AM
Transmission question Doc2012 3rd gen T4Rs 2 11-05-2012 02:12 AM
V6 transmission question 4Runner168 4th Gen T4Rs 11 08-24-2007 08:12 AM
