Old 11-07-2019, 09:55 AM #16
bdjcl bdjcl is offline
bdjcl is on a distinguished road
Originally Posted by Bad Luck View Post
When you filled your coolant did you use a spill free funnel and elevate the front end?
yep, I guess I could hook it back up and try to burp it some more
bdjcl is offline   Reply With QuoteReply With Quote
Old 11-07-2019, 10:01 AM #17
Bad Luck Bad Luck is offline
Real Name: Patrick
Real Name: Patrick
It's worth a shot. You probably already know this but make sure the vehicle gets hot enough to open the thermostat, and the front and rear heat are on. I ended up raising my 4Runner a couple feet in the front to get an air pocket out.
Old 11-07-2019, 11:59 AM #18
T4R2014's Avatar
T4R2014 T4R2014 is offline
T4R2014 is a splendid one to behold T4R2014 is a splendid one to behold T4R2014 is a splendid one to behold T4R2014 is a splendid one to behold T4R2014 is a splendid one to behold T4R2014 is a splendid one to behold
T4R2014's Avatar
Originally Posted by pluton View Post
Could it be the normal self-test performed by the ABS device under the hood? On mine it happens at about 5 seconds after I turn the ignition on, whether I immediately start the engine or not. It's probably not loud enough to hear once the engine is running, though.
On 96-97 it runs about 5 seconds after switching the ignition to the "on" position. But on my 1998 Limited the test runs after the starting it and driving off a few feet. I think this is what OP is experiencing.
Old 11-07-2019, 12:11 PM #19
yes, that's exactly when I hear the sound, after starting it and driving off a few feet. Is the liquid I think I'm hearing likely brake fluid?
Old 11-07-2019, 12:15 PM #20
T4R2014's Avatar
T4R2014's Avatar
Possibly, all I know is that it is the ABS pump, which is cycling brake fluid.
Old 11-07-2019, 12:29 PM #21
ah yes, I think you're on to something! Is the ABS pump the device on the passenger side that has a number of hard lines coming out of the top?
Old 11-07-2019, 12:54 PM #22
Real Name: Patrick
Real Name: Patrick
Yes. That's it.
Old 11-07-2019, 12:58 PM #23
Yes. That's it.
thought so...I'm having an unnatural amount of trouble finding it on any of the parts sites...
Old 11-07-2019, 03:08 PM #24
Yeah, its the ABS pump doing a test cycle/pump. Normal, don't worry about it.
It actually makes the sound a few seconds after you remove your foot from the brakes. For me, the sound comes after I have backed out of the driveway (a bit downhill, so brakes are on) and shift into drive on the way down the street.
'17 Chevy Volt Premier
'16 Honda Odyssey Elite
Old 11-07-2019, 04:15 PM #25
cool, I'm gonna do some testing when I get home but I'm about 90% certain this is what it is. thanks everybody!
Old 11-07-2019, 04:50 PM #26
T4R2014's Avatar
T4R2014's Avatar
Exactly how it cycles on my 1998. My guess is that it is the same cycling routine for 98-00.
Old 11-07-2019, 09:51 PM #27
Mr. Goodkat's Avatar
Mr. Goodkat Mr. Goodkat is offline
Mr. Goodkat is on a distinguished road
My 2000 4R and our 01 Camry do the brake check as others have said. As yours makes that sound, if it is the brake check, you should also feel a faint pulse or vibration in the brake pedal with the sound. In both of our Toyotas they do it as in the first 15 feet or so as we're backing out of the driveway and I feel the brake check in the pedal since my foot is applying slight pressure on the pedal.
2000 Limited natural white w/rear locker 204,xxx
Eibach Pro-Truck lift kit, Geolandar AT 275/70R16, debadged
2001 Camry LE V6 113,000 antique sage metallic, runs like new
Mr. Goodkat is offline   Reply With QuoteReply With Quote
4runner , liquid , start , system , times
17` TRD Premium Rear "clank/clunk" noise fireforeffect 5th gen T4Rs 28 04-21-2019 08:08 PM
dies shortly after start technodrive 3rd gen T4Rs 20 11-28-2014 03:34 PM
Front End "Clunk" and (separate) Steering Noise thirstyturtle 3rd gen T4Rs 10 06-01-2014 06:28 PM
Loud "Clunk" with slight left hand turn? STRRAYNGE 3rd gen T4Rs 38 04-24-2012 01:48 PM
Liquid Sound then "Ka-thunk" Noise from Engine 4Runner_Steve Problems & Warranty Issues 3 02-03-2006 08:31 AM
