Old 11-07-2019, 07:07 AM #1
The Cold War Kid's Avatar
The Cold War Kid The Cold War Kid is offline
The Cold War Kid is on a distinguished road
Amazing...
I find that I can buy a JDM engine for about what I will have to pay to get my valves set. A Toyota stealership is the only place I can find that will even set the valves. I've nearly begged for help on that issue but nobody has responded...
It would seem that the age of these vehicles would preclude the concept of JDM - a vehicle in Japan being, in our perception, prematurely retired and parted out. Yet there are engines for sale.
Any thoughts on this matter?
2001 Sr5 V6 2WD
"...The closer you get, to the meaning, the sooner you know, that you're DREAMING..." (Black Sabbath - HEAVEN AND HELL)
The Cold War Kid is offline   Reply With QuoteReply With Quote
Old 11-07-2019, 07:38 AM #2
dogtail's Avatar
dogtail dogtail is offline
Real Name: Keith
dogtail has a spectacular aura about dogtail has a spectacular aura about
dogtail's Avatar
Real Name: Keith
Why do you need to mess with your valves? 300K is walk in the park for these motors with mere simple tuneup maintenance stuff.
*1999 3.4L, 4wd/5spd, swapped motor and trans, heavy use DD, seasonal rust proofing using WD-40 only
*2000 3.4L, 4wd/5spd, parts rig, picking the carcass
dogtail is offline   Reply With QuoteReply With Quote
Old 11-07-2019, 08:31 AM #3
brillo_76's Avatar
Real Name: Jon
brillo_76's Avatar
Real Name: Jon
I haven't adjusted valves since the 1990s on 1980s 22r engines and the last time I did it I didn't have to adjust much.
So like Dogtail asked. Why are you wanting to adjust them?
We dont have a screw driver and nut adjustment anymore like the early 80s 22R did. It all has to be done by shims.
This would be an extremely time consuming process to complete. I can see anyone that would do it have to charge significantly to complete the task.
Also, the participation on this forum is extremely high on all threads. Sometimes nobody has came across a particular issue or nobody does it in the parameters you set.
So stating you begged for help and nobody responded on 1 of your many threads that lots of users contributed on isnt very accurate.
You specifically asked if anyone did it a mile parameter that you selected and the answer was no because nobody activity involved on this forum responded. ;)
Easy wild tiger. We all try through our own experiences to help others on their 3rd gen repairs and maintenance.
Old 11-07-2019, 09:41 AM #4
Bad Luck Bad Luck is offline
Real Name: Patrick
Real Name: Patrick
What I find amazing is the volume of threads you start. You'll start a thread for diagnosis help, then you'll start another thread for the repair, then it seems like there's another thread for results. I usually avoid clicking on any thread you start now, but today is slow so here I am to complain.
Old 11-07-2019, 11:40 AM #5
mtbtim's Avatar
mtbtim mtbtim is offline
Real Name: Tim
mtbtim's Avatar
Real Name: Tim
The 5VZ-FE engines aren't known to need regular valve adjustment checks like the 3RZ-FE requires. But, if you wanted to know how to do it, we have a video of doing it on a 3RZ motor which would be the same technique as the 5VZ. You just have more valves to check on the 5VZ. To get to the point of having the valve covers off, you can use our valve cover gasket video.
This is a time consuming and tedious job, and like you found out, a dealership with their high labor rates will rape you on this. So, I suggest you take up wrenching or forget about it altogether because any shop is going to charge you quite a bit to do this. You may as well buy all the necessary parts to do the valve cover gasket job because it's all the same labor to get in there.
Old 11-07-2019, 12:38 PM #6
4Runner4Leon's Avatar
4Runner4Leon 4Runner4Leon is offline
Real Name: Leon
4Runner4Leon is a name known to all 4Runner4Leon is a name known to all 4Runner4Leon is a name known to all 4Runner4Leon is a name known to all 4Runner4Leon is a name known to all 4Runner4Leon is a name known to all
Real Name: Leon
And all with useless titles that make it hard to figure out the issue at hand. Makes for great click bait, but is also somewhat annoying.
1997 4Runner Limited 4WD E-Locker ~200k | Falken Wildpeak A/T3W 265/75/16 | Pro Comp 69 16x8 | OME 2906 | B&M 70264
Addicted Offroad Front Bumper | Spiker Engineering High-Lift Hood Struts and Ultragauge Mount
4Runner4Leon is offline   Reply With QuoteReply With Quote
Old 11-07-2019, 12:51 PM #7
Real Name: Patrick
Real Name: Patrick
How could I forget about that?
Old 11-07-2019, 01:04 PM #8
The passenger side you can check with minimal work to gain access. And depending what you find you can use it to help you make a decision.
There is a tool (I have one and have used it 3 times now) that will allow you to remove the shims without removing cams.
3 engines and I only ever had to adjust the exhaust cams.
Old 11-07-2019, 03:03 PM #9
I have never adjusted the valves on a Toyota direct-actuation (cam on shim/bucket) engine, ever. That includes about 1 million total miles over multiple vehicles that I have been 'in charge' of...
Unless you are building an engine (err, heads), it just shouldn't need to be done. Easy enough to check clearances with a feeler gauge while doing valve cover gaskets though... Changing the shims is a different story.
'17 Chevy Volt Premier
'16 Honda Odyssey Elite
Old 11-07-2019, 03:19 PM #10
mtbtim's Avatar
Real Name: Tim
mtbtim's Avatar
Real Name: Tim
@JZiggy and others that have checked valve lash on their 3RZ motors have noticed the need to make adjustments. I'm guessing the Toyota engines you've owned weren't prone to needing an adjustment.
Old 11-07-2019, 04:45 PM #11
Yeah. 3s-fe, 3s-gte, 5vz-fe, and I suppose you could count the 1gr-fe in my dad's 4th gen...
Old 11-07-2019, 04:50 PM #12
Chichi98 Chichi98 is offline
Chichi98 is on a distinguished road
They are solid on millage! mine is 98 at 367 km been owner for 3 years now and am crossing my fingers for many more to come!
Chichi98 is offline   Reply With QuoteReply With Quote
Old 11-07-2019, 05:37 PM #13
T4R2014's Avatar
T4R2014 T4R2014 is offline
T4R2014 is a splendid one to behold T4R2014 is a splendid one to behold T4R2014 is a splendid one to behold T4R2014 is a splendid one to behold T4R2014 is a splendid one to behold T4R2014 is a splendid one to behold
T4R2014's Avatar
Ok, then replace the engine. I dare ya.
Old 11-07-2019, 05:51 PM #14
I replaced my 93 ZX7 engine with a 94 ZX9 engine because my 750’s clutch was starting to slipAmazing...
Old 11-07-2019, 06:23 PM #15
T4R2014's Avatar
T4R2014's Avatar
I know a guy who replaced a transmission and front differential in a Suzuki Vitara because he didn't realize what manual locking hubs are.
find , japan , jdm , set , valves
so much amazing richiegrich Classic T4Rs 8 04-08-2015 03:20 PM
Who's 4Runner is this? Amazing! masphx 3rd gen T4Rs 0 11-05-2014 05:53 PM
Amazing deal or WHAT?!! James Perez 3rd gen T4Rs 1 11-01-2011 09:30 PM
Amazing.. Supra725 General Discussions 5 07-22-2011 09:19 PM
What an amazing car hayk 4th Gen T4Rs 4 01-02-2009 03:03 PM
