Old 11-07-2019, 07:21 PM #1
The Cold War Kid's Avatar
The Cold War Kid The Cold War Kid is offline
The Cold War Kid is on a distinguished road
It went NUTS!
Sorry to start yet another thread. I have no idea what to call this one.
Started it this morning and heard a little squeaky-squeaky noise. I've heard that a couple times. Thought it was fan belts.
Usually there is a quiet hissing noise that runs for 10 seconds or so and is terminated by a pop (sounds like a relay) coming from the passenger foot well. Didn't hear that today. It's difficult 'cause the fan makes so much noise when it's started in the morning.
The quiet hissing noise runs again for a few seconds when I use the brake the first couple-three times, then it goes away.
Today the squeaky noise lasted about fifteen seconds then WHAM - it turned on the ABS light, the check engine light, both traction control lights and began screaming at me! I thought I had lost my brakes but they still worked fine.
Pulled it over. Shut it off. Counted to twenty and restarted it. The lights stayed on for about thirty seconds then all was normal again.
What is under the dash and makes that hissing noise? Maybe it needs some blaster squirted into it?
Any help appreciated
2001 Sr5 V6 2WD
"...The closer you get, to the meaning, the sooner you know, that you're DREAMING..." (Black Sabbath - HEAVEN AND HELL)
The Cold War Kid is offline   Reply With QuoteReply With Quote
Old 11-07-2019, 08:13 PM #2
Dezert4Runner's Avatar
Dezert4Runner Dezert4Runner is offline
Real Name: Evan
Dezert4Runner will become famous soon enough Dezert4Runner will become famous soon enough
Real Name: Evan
Sure sounds like the brake booster losing vacuum but ‘01-‘02 have an electronic booster so I don’t know if they tend to make that noise under normal operating conditions. The Christmas tree lights on the dash isn’t normal of course. The electronic brake boosters are big money, so hopefully that’s not your issue. Hopefully someone with the same year range can chime in and confirm.
2000 Black Sport 4WD 5spd-2.5" SAW • Toytec Superflex/ 5th gen Bilstein 5100/ Wheelers Superbumps • 285/75/17 BFG KO2 on 5th gen SR5 wheels • 231mm TBU / Wheelers SS lines • MStudt extended quick disco links • Satoshi • Weathertechs • K&N FIPK w/ AFE dry filter • Spidertrax • Stubbs HD-SKO sliders • Ellis Precision shift knobs • Uniden PRO 520XL & 3' Firefly on custom mount• Paranoid Fab switch panel with Ram mounts • Extended rear diff breather • 01-02 tail lights • Borla Pro XS • Any 7 fab gas tank skid
Dezert4Runner is offline   Reply With QuoteReply With Quote
Old 11-07-2019, 09:52 PM #3
alumarine alumarine is offline
alumarine is on a distinguished road
Maybe it's possessed?
1991 4runner 4wd Auto V6
1990 4runner 4wd Auto V6
alumarine is offline   Reply With QuoteReply With Quote
Old 11-07-2019, 11:36 PM #4
Sparky 97Runner Sparky 97Runner is offline
Real Name: Martin
Sparky 97Runner is on a distinguished road
Real Name: Martin
I knew this was coming. It sounds to me like your 4Runner finally went nuts.
1997 Toyota 4Runner
Sparky 97Runner is offline   Reply With QuoteReply With Quote
Old 11-08-2019, 06:21 AM #5
Well, now that you mention it, my last three schrinks committed suicide within 30 days of taking me on....
2001 Sr5 V6 2WD
Old 11-08-2019, 08:38 AM #6
jgue467's Avatar
jgue467 jgue467 is online now
jgue467 will become famous soon enough
jgue467's Avatar
Originally Posted by Dezert4Runner View Post
but ‘01-‘02 have an electronic booster so I don’t know if they tend to make that noise under normal operating conditions. ..
01-02s don't.
My 01 with Original everything is quite as a kitten purring, ahhh, drad those 01s they're the shits huh??
Oh yeah Go Horns!!
2001 Limited 4WD - 319K - SunfireRed\Thunder Cloud; - 265/75/16 Michelin A/T2s - Fat Pat's 1.5" BL
StopTech slotted rotors - Magnefine trans filter - In series trans cooler, Original: paint, engine, 4wd, trans, mstr cyl & brake system, rear axle seals, A/C, steering pump, steering rack, front/center/rear diffs, all electric motors, seat heaters and on and on. WooHoo!!
jgue467 is online now   Reply With QuoteReply With Quote
Old 11-08-2019, 09:36 AM #7
brillo_76's Avatar
brillo_76 brillo_76 is online now
Real Name: Jon
brillo_76 has a spectacular aura about brillo_76 has a spectacular aura about
MY GARAGE
brillo_76's Avatar
Real Name: Jon
MY GARAGE
Need to check for cracked hoses and vacuum leaks. Then go from there.
1997 4X4 V6 5 Speed Sr5 4 Runner (97 5 speed )
1997 4X4 V6 Red limited 4 Runner (97 Limited)
1998 4X4 V6 Sr5 Red 4 Runner (98 Tetanus1 )
1998 4X4 V6 Sr5 Silver 4 Runner (98 Tetanus2)
2001 4X4 V6 Sport Green 4 Runner (01 Green Sport)
brillo_76 is online now   Reply With QuoteReply With Quote
Old 11-08-2019, 10:41 AM #8
Outrider Outrider is offline
Outrider is on a distinguished road
It probably is. It might be about to go all Christine on him.
OP - do you have another vehicle? If so, your T4R might be jealous of it. I bought a Mazda3 as a daily driver, about a month ago. My T4R got booted out of the garage and sits outside, under a loving car cover (I still try to treat her right). When I removed the cover yesterday to take my dog for a hike, my T4R bucked and snorted when I cranked her. Then she ran fine. She was just letting me know that she didn't appreciate me putting her out to pasture. Oh, and her brake light on the dash now comes on intermittently, despite the brake fluid reservoir being full. She is probably just being passive/aggressive with me, as many women tend to do when they get jealous or feel scorned (or maybe I actually have a failing master cylinder or caliper).
'99 SR5 2WD / Deckplate Mod
Outrider is offline   Reply With QuoteReply With Quote
Old 11-08-2019, 11:07 AM #9
spartacus's Avatar
spartacus spartacus is online now
spartacus will become famous soon enough spartacus will become famous soon enough
spartacus's Avatar
Video it next time.
spartacus is online now   Reply With QuoteReply With Quote
Old 11-08-2019, 04:28 PM #10
brillo_76's Avatar
Real Name: Jon
MY GARAGE
brillo_76's Avatar
Real Name: Jon
MY GARAGE
The 2 questions I have for the OP.
1] Is anything getting fixed ? I have seen a pile of threads without any feedback or end results on any of them. They just seem to be abandoned.
2] Also please create titles to the issue at hand. For example: Its going nuts isnt very descriptive.
ABS, CEL and both Traction lights came on
Would be so much more descriptive.:]
Old 11-08-2019, 04:31 PM #11
gamefreakgc's Avatar
Real Name: Jerod
gamefreakgc is just really nice gamefreakgc is just really nice gamefreakgc is just really nice gamefreakgc is just really nice
Real Name: Jerod
For 2001's & 2002's all the lights turn on when you get a check engine light. Just check the codes at a parts store (the actual codes, not their amateur analysis) and post them back on here.
'98 4Runner SR5 - 4x4 5VZ-FE Supercharged - 222k miles, JDM engine @ 221k
AEM F/IC 6 Piggyback, 2.1" pulley at 11 PSI, Go-Fast Parts
Old 11-08-2019, 04:35 PM #12
brillo_76's Avatar
Real Name: Jon
MY GARAGE
brillo_76's Avatar
Real Name: Jon
MY GARAGE
Yup that is what is does on my 01 runner. If the CEL trips the ABS and Traction Control do as well.
Agree 100% with Gamefreakgc need the actual codes being thrown to even think about finding solutions.
If no codes are present, you not going to find anything. :-(
Old 11-08-2019, 09:49 PM #13
Everything, so far, has gotten fixed, yes.
Thanks to all for the info
2001 Sr5 V6 2WD
Old 11-08-2019, 09:50 PM #14
There are no codes. The CEL is now beautifully dark...
2001 Sr5 V6 2WD
Old 11-09-2019, 10:20 AM #15
brillo_76's Avatar
Real Name: Jon
MY GARAGE
brillo_76's Avatar
Real Name: Jon
MY GARAGE
Great thanks for letting us know. Like others stated the cel kicks on the VSC and abs will disable and light up. :]
fan , hissing , noise , quiet , seconds
Conical Lug Nuts vs Extended (ET) Conical Lug Nuts luke87gt 4th Gen T4Rs 4 10-11-2016 12:06 AM
WTB Lug Nuts Smbl7 Want to Buy/Trade 1 05-01-2015 07:27 PM
FS: 1 Set of OEM lug nuts and 1 non OEM $30 - CA Roguestatus1688 For Sale: Suspension/Wheels/Tires 0 07-14-2014 02:19 PM
looking for nuts! apache67 3rd gen T4Rs 11 05-27-2013 07:46 AM
WTT Lockiing Lug Nuts for Lug Nuts!! bgmac Classifieds - buy & sell (no commercial ads please) 0 06-21-2009 09:16 AM
Copyright ©2000 - 2019, vBulletin Solutions Inc.
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2019 DragonByte Technologies Ltd.
Feedback Buttons provided by Advanced Post Thanks / Like (Lite) - vBulletin Mods & Addons Copyright © 2019 DragonByte Technologies Ltd.
User Alert System provided by Advanced User Tagging (Lite) - vBulletin Mods & Addons Copyright © 2019 DragonByte Technologies Ltd.
Copyright © 2019
