Old 11-30-2019, 02:50 PM #16
brillo_76's Avatar
brillo_76 brillo_76 is online now
Real Name: Jon
brillo_76's Avatar
Real Name: Jon
Originally Posted by MountainBiker View Post
I had a similar issue, but when it was hot. After lots of investigating, never finding a leak (even using the UV dye),a buddy suggested that I replace the fuel cap: problem solved!
This was after paying a shop to look for the source! I was pretty sure that the smell was coming from the charcoal evap unit, so that was a clue. Never a single obdII code either.
Hope this helps someone some day.
Very possible the gas cap isnt sealing. I am just surprised it wouldn't throw an evap code if the cap is bad.
brillo_76 is online now   Reply With QuoteReply With Quote
Old 11-30-2019, 03:16 PM #17
brillo_76's Avatar
Real Name: Jon
brillo_76's Avatar
Real Name: Jon
I am also wondering what years these rigs are? I could see the older federal evap systems not having too much in the way of codes on the evap.
The later ones have that evap box by the spare tire. I could see the later ones throwing the evap code were the older ones probably dont have much there as they are so much a simpler system.
Old 11-30-2019, 06:53 PM #18
HiLife HiLife is offline
My cap went bad on my 00. Never threw a code, no gas smell.
It was found out bad during the yearly emissions check.
Old 11-30-2019, 08:19 PM #19
brillo_76's Avatar
Real Name: Jon
brillo_76's Avatar
Real Name: Jon
I always listen for the hissing when the tank is about empty. That's a dead giveaway of an evap issue if you dont have it.
Old 11-30-2019, 11:30 PM #20
brillo_76's Avatar
Real Name: Jon
brillo_76's Avatar
Real Name: Jon
Also, if your rigs live in the rust belt. I be checking your lines in the evap system and that charcoal canister in the front driver side. Lots of rubber lines and steel lines there that can be cracked or rotted.
Old 10-08-2023, 04:45 PM #21
AsukaAkita AsukaAkita is offline
Real Name: Adrian C.
AsukaAkita is on a distinguished road
Originally Posted by giovannie23 View Post
I have the same exact problem . when its cold outside i leak gas for about 15 min untill i reach operating temps. I finally was able to see it as it would drip down the steering rack. And its def coming from the fpr or the injectors on the driver side rear.
Im going to replace the o rings on the driver side injectors and on the fpr and hopefully it goes away
Will keep this thread updated
Same issue, if my 4runner runs normally and has no start up, idling, or misfire issues, and if the fuel smell only happens randomly (1 out of 6 startups), do you think this is more of an o-ring issue?
AsukaAkita is offline   Reply With QuoteReply With Quote
gas , hood , problem , replicate , smell
Mind the Gap! - Fixed gap between hood and body - 2014 TE boyfester Maintenance/Detailing 8 11-16-2015 06:24 PM
Strong fuel smell from under hood and blower vents, see no leak. 89FourRunner Classic T4Rs 18 11-24-2014 09:08 PM
Fixed gas smell 2001 4 Runner Philter 3rd gen T4Rs 2 07-12-2014 03:44 PM
Burning rubber smell after 'hot brake' smell westwind77 5th gen T4Rs 7 02-11-2013 01:26 PM
Light burning smell from under hood (driver's side) IdahoAngler 3rd gen T4Rs 8 03-01-2012 10:17 PM
