Old 11-08-2019, 08:33 PM #16
nail bender nail bender is offline
nail bender is on a distinguished road
Thanks tor all the info, swaped out the EFI fuze no difference. sprayed a shot of starting fluid in the intake and it will start and run a few seconds. so I will be testing the fuel pump but I think that is the problem. i did not buy this new so I don't know if it has been replaced, i doubt it has. just want to be sure before I rip in to it and replace stuff that is not bad.
nail bender is offline   Reply With QuoteReply With Quote
Old 11-08-2019, 08:48 PM #17
gamefreakgc's Avatar
Real Name: Jerod
Real Name: Jerod
Don't jump straight to a fuel pump even though that could be the issue. Fuel pump failure is very rare and the pump is in the tank and difficult to access.
Most likely you have a sensor that's sending a faulty signal and the ECU cutting out the fuel. MAF's are known culprits for doing this. Have you checked the ECU for codes already?
326WHP 347TQ
Old 11-08-2019, 10:13 PM #18
Js'00imited4runner's Avatar
Js'00imited4runner Js'00imited4runner is offline
Js'00imited4runner will become famous soon enough
Anytime dude! I did everything exactly as you did. Replaced fuel filter, Cleaned all the way up to the throttle body including the throttle body, MAF sensor, disconnected battery for 3 hrs. and cleared codes (which their weren't any) replaced EFI relays And It didn't change a damn thing. Here is the link of what I was experiencing and what the culprit was. Dropping the tank is not that difficult. The hardest part is dealing with rusted fasteners long as you hit em a couple times with some penetrating oil a few days before, and getting the fuel out which the way I accomplished that was to take my air compressor and set it to 20lbs of psi, shove a hose down the filler neck put the compressor nozzle in it and push the fuel out through the fuel filter/fuel line and drain it into a gas can. Also have another thread on how to check fuel pressure easier. Here they are. Good luck!
Fixed thread:
Trying to figure this out *Solved*
Fuel pressure test thread:
Easier way to check fuel pressure
2000 Limited 4wd Millenium Silver Metallic, E rear locker, KYB Monomax All around, '99 tall coils up front with daystar 1" spacer, OME 890's in back, Weathertech Floor and cargo Mats, Track decal shackle Brackets, Satoshi grill mod (wahoo), Diff breather mod, 200k+ and still going strong!
Js'00imited4runner is offline   Reply With QuoteReply With Quote
Old 11-09-2019, 03:55 PM #19
Originally Posted by RandyBobandy View Post
http://www.teamtoyota4x4.org/archivi...fuepum/ovi.pdf
That link might help with testing the pump, at the very end it shows how to check resistance, you can eliminate a spark issue if you can get it started with starting fluid
Update I checked the pump per these instructions. it ohm reading is .15 so it is below the .2-.3 where this info says it should be. I also could not get the pump to run by powering it from the battery like this info shows to do. I have determined that power is getting to the pump when it is called for. any thoughts on quality of aftermarket pumps or OEM? I am leaning towards OEM I know it is more money but you often get what you pay for. is there anything else needed when replacing the pump? thanks for the help
Old 11-09-2019, 04:54 PM #20
RandyBobandy's Avatar
RandyBobandy RandyBobandy is offline
RandyBobandy is just really nice RandyBobandy is just really nice RandyBobandy is just really nice RandyBobandy is just really nice RandyBobandy is just really nice
I bought a denso pump from rock auto, which I believe is the same as oem, it wasn’t very expensive and works well. Dropping the tank wasn’t hard, I did it out in the driveway with about 6” of snow on the ground because the 4Runner wouldn’t start up to go into the garage
RandyBobandy is offline   Reply With QuoteReply With Quote
Old 11-09-2019, 04:54 PM #21
That stinks. At least you were able to determine it is the fuel pump that has gone bad. Rockauto has a denso fuel pump kit with the fuel pump, pickup screen, and hoses/clamps for $74 I put it up next to the OEM one I removed from my fuel tank were exactly the same pump. I would consider doing your fuel filter too if your gonna bother doing the fuel system on it. The part # for that kit is DENSO 9500100. Their shouldn't be anything else needed when replacing it besides maybe cleaning the tank out real good and cleaning the rust/crud off the outside of the tank and giving it a fresh coat of paint. Might as well while you have it down. Maybe check the shape of your frame rail too and see whats their for rust. I wire brushed primed/painted mine while I had the tank out of it. Good luck with it!
Old 11-09-2019, 05:04 PM #22
spartacus's Avatar
spartacus's Avatar
I ordered the following from amazon 2 years ago and so far so good
4Runner died-screenshot_2019-11-09-14-08-14-png
Old 11-09-2019, 06:48 PM #23
brillo_76's Avatar
brillo_76 brillo_76 is online now
Real Name: Jon
brillo_76's Avatar
Real Name: Jon
My one buddy owns a mom and pop automotive garage. he always says it's not ever worth using aftermarket fuel pumps. So if it where me I use an OEM one or a OEM mfg one. That is unless you want to have to change the fuel pump a few times.
I am not sure if your in the rust belts. However, I have pulled and repaired 3 4 runner tanks so far.
Here is a few tips.
1] disconnect the fuel return line and pump your tank dry if at all possible before you pull it down.
2) pull the skid plate [ if it has one and all your lines off the front and rear of the tank.
3] disconnect the fuel tank wiring thsts under a plate on the rear passenger seat.
4] Be very careful bringing this tank down. As it has little vent hoses on the top of the tank you need to disconnect. [ busted a breather line on one tank once as I let the tank down too fast
5) if not in rust belt at least change all the gaskets while you have the tank down. If in the rust belt change all the bolts and screws.
Being I am in the rust belt. When i drop a tank and super clean it and give it 2 coats of Rustoleum paint before fluid filming it and putting it back in.
Take your time and be careful. It should go in and out very easily.
brillo_76 is online now   Reply With QuoteReply With Quote
Old 11-17-2019, 01:02 PM #24
Update. I got my fuel pump and related parts on friday. i went with OEM parts and took a few days for shipping. put it all back together on saturday. turned the key and after cranking about twice as long as normal it started. after that it starts very quickly. when I had the pump out i looked in the tank with a flashlight,i couldnt find any matches. it was clean no grit or anything in it which was good to see. it was not a bad job to do with the help on here and links provided. thanks to all
Old 11-17-2019, 01:25 PM #25
brillo_76's Avatar
Real Name: Jon
brillo_76's Avatar
Real Name: Jon
Glad your rolling down the road. Thank you for letting us know your fixed.
Old 11-17-2019, 03:03 PM #26
negusm negusm is offline
negusm will become famous soon enough
You can do that with a flashlight? Good to know!
negusm is offline   Reply With QuoteReply With Quote
Old 11-17-2019, 06:53 PM #27
BoomerBob's Avatar
BoomerBob BoomerBob is offline
BoomerBob will become famous soon enough BoomerBob will become famous soon enough
BoomerBob's Avatar
Fixed thread:
Have you been able to find the Union with adapter to check the fuel pressure? I see you have a workaround but I was hoping this adapter is available somewhere to make it a bit easier. Also; anyone know what SST stands for?
SST 09268-45014
4Runner died-screenshot_2019-11-17-document-ovi-pdf-png
2001 2wd - Daily Driver
BoomerBob is offline   Reply With QuoteReply With Quote
Old 11-17-2019, 07:25 PM #28
Piney's Avatar
Piney Piney is offline
Location: Off grid in the middle of the middle of nowhere
Real Name: Phineas
Piney is on a distinguished road
Piney's Avatar
Real Name: Phineas
Special service tool, or some such.
1997 Limited
And an otherwise mean barn cat that likes to ride in it.
(And Vanwagons, but we keep that quiet around here).
Piney is offline   Reply With QuoteReply With Quote
Old 11-17-2019, 08:02 PM #29
rightyouareken's Avatar
rightyouareken rightyouareken is offline
rightyouareken has a spectacular aura about rightyouareken has a spectacular aura about rightyouareken has a spectacular aura about
That SST looks like a pretty standard banjo bolt. Bet you could find something that works at a local auto parts store.
2020 4Runner Venture
2002 4Runner SR5 4WD (sold)
1998 BMW M3/4/5
rightyouareken is offline   Reply With QuoteReply With Quote
Old 11-17-2019, 08:04 PM #30
https://www.amazon.com/YUAN-Pressure...a-838189977781
Can't you just use this? Just remove that bolt entirely and replace it with one of those fittings that goes to the gauge?
died , filter , fine , miles , start
Need help! 4Runner died HustleHard 4th Gen T4Rs 13 02-03-2017 09:42 PM
Another 4runner died.... blazingshadow 5th gen T4Rs 42 01-22-2015 11:18 PM
4Runner died...just now h7009 Classic T4Rs 5 09-01-2009 06:13 PM
my 94 4runner died! what do i do now?!?! pyrodork Classic T4Rs 3 04-14-2008 11:33 AM
My 97 4runner died. 4x4toyz Problems & Warranty Issues 12 07-05-2007 08:34 AM
