Old 11-17-2019, 08:09 PM #31
Js'00imited4runner's Avatar
Js'00imited4runner Js'00imited4runner is offline
Js'00imited4runner will become famous soon enough
Originally Posted by BoomerBob View Post
Have you been able to find the Union with adapter to check the fuel pressure? I see you have a workaround but I was hoping this adapter is available somewhere to make it a bit easier. Also; anyone know what SST stands for?
SST 09268-45014
No I haven't. I did a lot of research and you have to make a custom fitting banjo bolt or buy another fuel rail and tap a schrader valve into it. But at the moment I couldn't beat $3 bucks from the junkyard for the fittings/hose to make my own. I just rented the fuel pressure gauge from autozone and the readings were as accurate as can be. It's not really a work around it's just a easier way then custom making a banjo bolt. Apparently only the dealers have the fittings to check fuel pressure. Plus their is absolutely no room to do anything off the front of the fuel rails if you drop a nut or bolt good luck finding it. I wouldn't recommend it if it didn't work.
2000 Limited 4wd Millenium Silver Metallic, E rear locker, KYB Monomax All around, '99 tall coils up front with daystar 1" spacer, OME 890's in back, Weathertech Floor and cargo Mats, Track decal shackle Brackets, Satoshi grill mod (wahoo), Diff breather mod, 200k+ and still going strong!
Js'00imited4runner is offline   Reply With QuoteReply With Quote
Old 11-17-2019, 08:23 PM #32
BoomerBob's Avatar
BoomerBob BoomerBob is offline
BoomerBob will become famous soon enough BoomerBob will become famous soon enough
BoomerBob's Avatar
Thanks. I'll message you about your offer to make more.
2001 2wd - Daily Driver
BoomerBob is offline   Reply With QuoteReply With Quote
Old 11-18-2019, 10:09 AM #33
dhracer3 dhracer3 is offline
dhracer3 is on a distinguished road
Try checking connectors first. I had this very same issue happen and it ended up being just a bit of corrosion on the ignition control module connector.
Older vehicles will eventually get small amounts of corrosion in the connectors. Get some dielectric grease and reseat all your connectors.
The ignition control module is located right near the cruise control module I believe
I think everyone has a right to their own opinion.. I'm just here to tell you that you are wrong.!!
dhracer3 is offline   Reply With QuoteReply With Quote
Old 11-19-2019, 12:48 AM #34
levee-11's Avatar
levee-11 levee-11 is offline
Real Name: Levi
levee-11 is on a distinguished road
levee-11's Avatar
Real Name: Levi
When were spark plugs replaced? Probably not the issue, but worth checking.
levee-11 is offline   Reply With QuoteReply With Quote
Old 11-19-2019, 11:55 PM #35
BoomerBob's Avatar
BoomerBob's Avatar
Originally Posted by negusm View Post
Sorry! Something went wrong!
Can't you just use this? Just remove that bolt entirely and replace it with one of those fittings that goes to the gauge?
That is an excellent question. Anyone know? If the threads are the right size it sure seems like it would.
@Js'00imited4runner
died , filter , fine , miles , start
Need help! 4Runner died HustleHard 4th Gen T4Rs 13 02-03-2017 09:42 PM
Another 4runner died.... blazingshadow 5th gen T4Rs 42 01-22-2015 11:18 PM
4Runner died...just now h7009 Classic T4Rs 5 09-01-2009 06:13 PM
my 94 4runner died! what do i do now?!?! pyrodork Classic T4Rs 3 04-14-2008 11:33 AM
My 97 4runner died. 4x4toyz Problems & Warranty Issues 12 07-05-2007 08:34 AM
