Old 11-11-2019, 09:28 AM #16
brillo_76's Avatar
brillo_76 brillo_76 is online now
Real Name: Jon
brillo_76 is a splendid one to behold brillo_76 is a splendid one to behold brillo_76 is a splendid one to behold brillo_76 is a splendid one to behold brillo_76 is a splendid one to behold brillo_76 is a splendid one to behold
brillo_76's Avatar
Real Name: Jon
If you have a smart phone, you can get an app called torque pro and a bluetooth adapter. This will let you set limits on the voltage so not only will you have a gauge. It will alert you. :] Just a thought.Battery upgrade!-screenshot_20191111-082659_torque-jpg
1997 4X4 V6 5 Speed Sr5 4 Runner (97 5 speed )
1997 4X4 V6 Red limited 4 Runner (97 Limited)
1998 4X4 V6 Sr5 Red 4 Runner (98 Tetanus1 )
1998 4X4 V6 Sr5 Silver 4 Runner (98 Tetanus2)
2001 4X4 V6 Sport Green 4 Runner (01 Green Sport)
brillo_76 is online now   Reply With QuoteReply With Quote
Old 11-11-2019, 10:23 AM #17
jross20's Avatar
jross20 jross20 is offline
jross20 will become famous soon enough jross20 will become famous soon enough
jross20's Avatar
Originally Posted by brillo_76 View Post
If you have a smart phone, you can get an app called torque pro and a bluetooth adapter. This will let you set limits on the voltage so not only will you have a gauge. It will alert you. :] Just a thought.Attachment 348108
I do have one other recently I've been unable to find my damn adapter...
But I mean, I was planning on adding other gauges already. So I might as well add a voltometer
Old 11-11-2019, 10:46 AM #18
brillo_76's Avatar
Real Name: Jon
brillo_76's Avatar
Real Name: Jon
Ok. I dont blame you. We used to have a voltage gauge and oil pressure gauges in sr5 Trucks in the 80s. But they went to idiot lights. I dont blame you I love gauges too..
Old 11-11-2019, 11:33 AM #19
calimobber's Avatar
calimobber calimobber is offline
calimobber is on a distinguished road
calimobber's Avatar
Well did you get everything installed? It should have been a quick install. I ran 2 optima in my 4runner for almost 8 years before replacing.
My 2002 4runner Build : http://www.toyota-4runner.org/3rd-ge...r-project.html
calimobber is offline   Reply With QuoteReply With Quote
Old 11-11-2019, 11:44 AM #20
brillo_76's Avatar
Real Name: Jon
brillo_76's Avatar
Real Name: Jon
How about this for a volt meter? Can have your 2 usb charging ports plus a voltmeter in one..
https://www.amazon.com/Revive-Diagno...s%2C170&sr=8-5
Old 11-11-2019, 03:10 PM #21
19963.4lsr5 19963.4lsr5 is online now
19963.4lsr5 is just really nice 19963.4lsr5 is just really nice 19963.4lsr5 is just really nice 19963.4lsr5 is just really nice 19963.4lsr5 is just really nice
That’s what I use to use in the 4Runner. Now that the ScanGauge is in it reports system voltage at the OBD port which is directly off the battery. The cig lighter is switched with the ignition and sometimes it .2 or more bolts lower than post voltage unless you rewire it strait to the battery.
19963.4lsr5 is online now   Reply With QuoteReply With Quote
Old 11-12-2019, 02:56 AM #22
pluton's Avatar
pluton pluton is offline
Real Name: Keith
pluton will become famous soon enough pluton will become famous soon enough
pluton's Avatar
Real Name: Keith
When your say add a charger, are you talking about like a mod to the truck?
I was thinking of adding a voltometer since I read that agm's are sensitive to overcharge, so I felt it may be good to monitor it
I meant adding a plug in the wall charger to top off the battery on weekends, etc. My Odyssey PC1500 size 34R takes about 3 hours to fully recharge after a week of around-town driving, using a CTEK Multi US 25000 charger.
There are cheap/OK voltmeters, also a Scangauge has a voltmeter function.
pluton is offline   Reply With QuoteReply With Quote
Old 11-12-2019, 09:23 AM #23
jross20's Avatar
jross20's Avatar
Actually I was going to ask what kind of charger you guys recommend is, I see the genius and Ctek but they also have a tremendous amount of really scary reviews!
Also, I found out after calling the manufacturer that the battery's posts are actually made of brass and not lead. So I've ordered a set of brass connectors and we'll install those when they come in.
I'm also deciding on getting that 3 gauge pillar thing, does anyone have one of those? Also, has anyone used vdo gauges?
Old 11-12-2019, 11:37 AM #24
calimobber's Avatar
calimobber's Avatar
For the battery charger it kinda all depends on what you want out of it. If you just want a good enough charge to start the car most will be just fine. I love the optima chargers as they actully have 4 stages of charging and will raise the voltage high enough for a good charge.
https://www.amazon.com/Optima-Digita...70&sr=8-4&th=1
If you just want somethig cheap to get the car started any high review battery should be fine. The car will properly charge it once its running.
Old 11-12-2019, 01:40 PM #25
jross20's Avatar
jross20's Avatar
Honestly I'm just nervous as just about every one of them I've read about, I see a massive slew of bad reviews and photographs of burned and exploded chargers... I didn't think a battery charger was a hard thing to build these days...
Old 11-12-2019, 02:37 PM #26
Battery upgrade!
I have a Schumacher speed charger 2-8-12a that has settings for flooded and agm/gell, I’ve had it for all but 15 years now and other than it’s cooling fan squealing when it’s below freezing it works great.
For my Cummins I have a 8a deltran that’s as old as the Speed Charger. It’s doing great as well. The deltran is waterproof. I was going to mount it in the engine bay but never did.
I also have a few Schumacher 2a tenders for motorcycles.
battery , brand , made , military , style
Battery Upgrade Opinions: 31 vs 34 jawkdna 5th gen T4Rs 72 01-07-2020 12:30 PM
Odyssey Battery a worthy upgrade Battle Born Offroad 5th gen T4Rs 0 07-03-2019 01:39 PM
Solar Upgrade for 2nd Battery Bumbo 5th gen T4Rs 0 01-31-2018 09:35 PM
Battery and Housing Upgrade tmcintosh3 4th Gen T4Rs 15 03-26-2016 12:11 PM
Battery Upgrade Suggestions Stellar 4th Gen T4Rs 16 01-21-2016 04:10 PM
Feedback Buttons provided by Advanced Post Thanks / Like (Lite) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
