Old 11-09-2019, 05:45 PM #1
Rock_Toy Rock_Toy is offline
Rock_Toy is on a distinguished road
Power for light bar & heated seats
I am about to install an LED light bar and upgrade to heated seats in my 4Runner. Where is everyone pulling power from?Are you running a fused wire into the cab and then using a distribution block or simply tapping into an existing keyed hot? Please school me. And pictures always help!!!
Rock_Toy is offline   Reply With QuoteReply With Quote
Old 11-09-2019, 06:27 PM #2
Angrywelder Angrywelder is offline
Angrywelder is on a distinguished road
Generally when I need to pull power for a high amp draw device, such as the power seat and light bar, I run a switch to a relay that runs the device. I don't like running high amp devices off of a switch unless you use the switch to break a ground instead of the power line.
Angrywelder is offline   Reply With QuoteReply With Quote
Old 11-10-2019, 10:57 AM #3
sleepydad's Avatar
Real Name: Andy ಠ_ಠ
sleepydad's Avatar
Real Name: Andy ಠ_ಠ
not sure how much experience you have doing DC wiring? I have done heated seats a couple of times in 3rd gens so I can tell you what I ended up doing.
you might want to pickup one of these if you don't have one, makes testing DC V very easy.
for the seat heaters you can use a tap a fuse
grab 2x that uses the same mini style fuses as toyota. you can use the spare ACC socket in the drivers side block.
I did exactly this same job back in 2017 give this a watch and maybe it will help you for the seat heaters. you want to use an ACC fused contact so the seat heaters can't drain your battery if you left them on... came back next morning and your battery is dead.
as for the light bar. you need to know the power requirements for the light bar? @Angrywelder is 100% correct you will want to run a circuit with a relay.
if you not familiar with automotive relays? tons of vids out on you tube detailing how that works. Lots of options for switching and fuse protection but your probably going to have to roll you own solution for the light bar because Toyota really did not provide a plug and play solution for light bars.
bar , heated , light , power , seats
Heated Seats? skeeterpaul 3rd gen T4Rs 19 11-30-2017 12:09 AM
4th gen Limted front leather heated power seats FS bxc13 For Sale: T4R Items 6 02-22-2012 04:07 PM
Heated Seats toybox 4th Gen T4Rs 1 12-15-2011 01:57 AM
T4R's with Heated Seats coinball 3rd gen T4Rs 0 05-26-2011 10:18 PM
Heated Seats BROOKLYN 4th Gen T4Rs 3 11-29-2005 09:06 AM
