Old 11-12-2019, 05:09 AM #16
TheShowtime TheShowtime is offline
TheShowtime is on a distinguished road
No I was actually flooring it to make sure my transmission was shifting properly. I was driving and I felt or thought my transmission was slipping. It was actually my first time ever doing that in my 4Runner. But itís all good now transmission shifts just fine. Thank you all for your replies!
TheShowtime is offline   Reply With QuoteReply With Quote
Old 11-12-2019, 09:44 AM #17
Bad Luck Bad Luck is offline
Real Name: Patrick
Bad Luck has a spectacular aura about Bad Luck has a spectacular aura about
Real Name: Patrick
Mine shifts at 3000-3500 at full throttle unless I have the ECT button pressed, then it shifts at close to redline.
2000 Limited V6 Auto E-Locker
Old 11-12-2019, 01:22 PM #18
phattyduck is a glorious beacon of light phattyduck is a glorious beacon of light phattyduck is a glorious beacon of light phattyduck is a glorious beacon of light phattyduck is a glorious beacon of light
Originally Posted by twitchee2 View Post
Redline a day, keeps the carbon away... at least thats what I tell myself. Honestly, my truck sees 5krpm daily, you try merging on the freeways in CA without getting run off the road. I have 300k miles and its running as strong as ever (good Maintenance is key). You will not hurt anything by doing this. If you are bouncing the rev-limiter then yes you will eventually have problems.
To put a finer point on it - using the engine up to redline is perfectly safe. If you want your engine to last, make sure it is fully warm when you do it. That doesn't mean the temp needle is at the middle, fully warm takes about 10 miles or minutes of driving, at least (more in winter, of course). It takes a while for the oil to get up to operating temp...
'16 Honda Odyssey
Old 11-12-2019, 01:24 PM #19
Check your throttle cable... you may not actually be getting full throttle. It should be quite easy to get to 3500 rpm, even with ECT in the normal position.
'16 Honda Odyssey
Old 11-12-2019, 02:40 PM #20
19963.4lsr5 will become famous soon enough 19963.4lsr5 will become famous soon enough
If you 2000 has a TV cable going to the trans check that as well.
Old 11-12-2019, 03:04 PM #21
twitchee2's Avatar
twitchee2 twitchee2 is offline
twitchee2 is on a distinguished road
twitchee2's Avatar
I agree 100% with this. I know my 4runner will not let it rev above 3krpm-ish until it warms up a bit. It is for this very reason.
2002 SR5 4WD
deckplate + ISR, Airlift 1000, OME 881/890, Goodyear Wrangler Duratrac 265/75/16C
Tundra 231mm Brakes - yes they DO fit the stock 5 spoke rims - Stubbs Welding HD-SKO sliders.
twitchee2 is offline   Reply With QuoteReply With Quote
Old 11-12-2019, 03:51 PM #22
Real Name: Patrick
Real Name: Patrick
Throttle cable is tight. I removed the intake tube and verified the throttle opens all the way when pressing the gas pedal down. ECT on and it shifts a couple hundred rpm before redline.
I thought that might be the culprit when I first bought it. I adjusted it and got jarringly firm shifts but no change in shift points. I'm not sure about earlier years of 4Runners but 99-00 the cable only adjusts line pressure.
EDIT: I went on a test drive yesterday. Reached engine operating temperature in 5 minutes then proceeded to try full throttle pulls. Vehicle was still shifting between 3000-3500 rpms with ECT off and close to redline with ECT on. After about 15 minutes of this (20 minutes into test drive) it finally started shifting during full throttle pulls at around 5000 rpm's with ECT off. My assumption is since my commute is 10 minutes if I hit every stop light that I never met all the transmission fail safe requirements to allow higher rpm shifting with ECT off. I feel pretty stupid for not testing this out before.
flooring , gear , redline , switching , thought
Epoxy flooring dawudih Off Topic 22 09-25-2019 07:47 AM
Garage flooring dta1984 Off Topic 0 09-29-2015 06:46 PM
Flooring Talk swapmeet Off Topic 9 01-30-2015 05:57 PM
Vinyl Flooring Pictures 97 _SR5 3rd gen T4Rs 3 02-26-2014 03:01 PM
? about replacing carpet with rubber flooring Kmvreter Maintenance/Detailing 0 03-20-2009 01:08 PM
Copyright ©2000 - 2019, vBulletin Solutions Inc.
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2019 DragonByte Technologies Ltd.
Feedback Buttons provided by Advanced Post Thanks / Like (Lite) - vBulletin Mods & Addons Copyright © 2019 DragonByte Technologies Ltd.
User Alert System provided by Advanced User Tagging (Lite) - vBulletin Mods & Addons Copyright © 2019 DragonByte Technologies Ltd.
Copyright © 2019
