Old 11-10-2019, 12:50 AM #1
TheShowtime TheShowtime is offline
TheShowtime is on a distinguished road
Flooring to redline
Hey guys was just wondering when I floor my 4Runner on Drive the rpm goes all the way to redline before switching gear, is this normal? Thought the transmission would switch gears sooner.
TheShowtime is offline   Reply With QuoteReply With Quote
Old 11-10-2019, 01:18 AM #2
nissanh nissanh is offline
ETC on?
Old 11-10-2019, 01:50 AM #3
Ect on normal not power.
Old 11-10-2019, 03:46 AM #4
UnderFire's Avatar
UnderFire UnderFire is offline
UnderFire has a spectacular aura about UnderFire has a spectacular aura about UnderFire has a spectacular aura about
UnderFire's Avatar
Normal. You're telling it you want all the power, so it's giving you all the power.
Sent from my JSN-L23 using Tapatalk
'97 3RZ 5 Speed "FrankenRunner" (Build Thread) - Dormant
The "shitmobile" 500$ 3RZ Auto 4Runner - (Saved from the Scrapyard: Resurrecting a 500$ 3rd Gen
02 Tacoma Double Cab, mid-travel, locked, armored, supercharged and riced. (Longbed and 5 speed in the works)
UnderFire is offline   Reply With QuoteReply With Quote
Old 11-10-2019, 09:23 PM #5
BostonJon BostonJon is offline
BostonJon will become famous soon enough
Sounds like your transmission kick down cable needs and adjustment
BostonJon is offline   Reply With QuoteReply With Quote
Old 11-11-2019, 11:32 AM #6
Bad Luck Bad Luck is offline
Real Name: Patrick
Real Name: Patrick
That cable controls line pressure in the transmission and affects how firm the transmission shifts. The transmission controls shift points electronically based on throttle position among other things.
Old 11-11-2019, 11:33 AM #7
Real Name: Patrick
Real Name: Patrick
Mine only does that with the ECT on. Normally it will shift between 3500-4000 depending on gear and temp.
Old 11-11-2019, 05:24 PM #8
2000se 2000se is offline
2000se is on a distinguished road
I'm sorry, I'm not trying to be difficult, but is this a serious question?
I don't think I've ever in my life driven a car that when you hold the gas pedal all the way down it won't go to redline every time before switching gears. Maybe I'm confused on your question...
2000se is offline   Reply With QuoteReply With Quote
Old 11-11-2019, 05:39 PM #9
Lol yes it is, I’m the biggest newb with cars hence why I joined this forum to ask even the basic questions. I’m also ocd with stuff so I wanted to make sure nothing was wrong with my transmission but I think it’s good. Thanks for all the responses guys!
Old 11-11-2019, 05:54 PM #10
jgue467's Avatar
jgue467 jgue467 is offline
jgue467's Avatar
... I’m the biggest newb...
Newb, you've got an approximately 20+ year old vehicle, don't dog it! Why??? ? It's not the way to test any old vehicle. You are only inviting breakdowns prematurely. Any old machine doesn't need any more stress than would normally come its way, who floors it regularly or even at all??? But yeah do Enjoy the Runner!
Old 11-11-2019, 06:05 PM #11
No worries..and as said below, take it easy. No need in redlining this car. The only reason to do so would be if you have to. Or, you just don't care.
I'm at 300k right now. I can't even remember the last time this truck has seen redline. Honestly, I can't remember..
Old 11-11-2019, 07:18 PM #12
Your mind will really be blown if you drive a manual transmission vehicle. You can often go PAST redline before the ECU will cut fuel and/or spark...
'17 Chevy Volt Premier
'16 Honda Odyssey Elite
Old 11-11-2019, 09:15 PM #13
theesotericone's Avatar
theesotericone theesotericone is offline
theesotericone is just really nice theesotericone is just really nice theesotericone is just really nice theesotericone is just really nice
It's not just manuals bro. I bounce my rig off it's rev limiter all the time snow wheeling. 4wd lo in 3rd locked front and rear will only do about 25 MPH before it rev limits. 5500 RPM is where that limit is on my rig. lol
Only two things are infinite, the universe and human stupidity, and I'm not sure about the former. --Albert Einstein
theesotericone is offline   Reply With QuoteReply With Quote
Old 11-11-2019, 09:21 PM #14
2016 4Runner SR5's Avatar
2016 4Runner SR5 2016 4Runner SR5 is offline
Real Name: Chris
2016 4Runner SR5 is a splendid one to behold 2016 4Runner SR5 is a splendid one to behold 2016 4Runner SR5 is a splendid one to behold 2016 4Runner SR5 is a splendid one to behold 2016 4Runner SR5 is a splendid one to behold 2016 4Runner SR5 is a splendid one to behold 2016 4Runner SR5 is a splendid one to behold
Real Name: Chris
If it's bouncing off the rev limiter and you have to let off the gas so it shifts, there is a problem. If it just taps redline and shifts with no issues at all, that's totally normal. This is definitely not something you want to do regularly though, especially on an old and likely worn engine. Since you're new to vehicles in general, do yourself and having the timing belt and water pump changed unless you know the history of the vehicle and you know without a doubt that it's been recently done. I believe Toyota says every 85,000 miles but I may be wrong on that.
2016 4Runner SR5 is offline   Reply With QuoteReply With Quote
Old 11-11-2019, 10:04 PM #15
twitchee2's Avatar
twitchee2 twitchee2 is offline
twitchee2 is on a distinguished road
twitchee2's Avatar
Redline a day, keeps the carbon away... at least thats what I tell myself. Honestly, my truck sees 5krpm daily, you try merging on the freeways in CA without getting run off the road. I have 300k miles and its running as strong as ever (good Maintenance is key). You will not hurt anything by doing this. If you are bouncing the rev-limiter then yes you will eventually have problems.
To answer your question, if you stomp on it, yes it will rev up to ~5,000-5,200rpm and shift. Where it shifts is not actually redline, rather a high rpm shift point. Redline is the rev limiter and you will know when you hit that.
A good rule of thumb is 1st gets you to 40mph, 2nd gets you to 70mph and 3rd gets you way faster than you should be going in a 4runner anyway...
2002 SR5 4WD
deckplate + ISR, Airlift 1000, OME 881/890, Goodyear Wrangler Duratrac 265/75/16C
Tundra 231mm Brakes - yes they DO fit the stock 5 spoke rims - Stubbs Welding HD-SKO sliders.
twitchee2 is offline   Reply With QuoteReply With Quote
flooring , gear , redline , switching , thought
Epoxy flooring dawudih Off Topic 21 05-29-2020 04:33 PM
Garage flooring dta1984 Off Topic 0 09-29-2015 06:46 PM
Flooring Talk swapmeet Off Topic 9 01-30-2015 05:57 PM
Vinyl Flooring Pictures 97 _SR5 3rd gen T4Rs 3 02-26-2014 03:01 PM
? about replacing carpet with rubber flooring Kmvreter Maintenance/Detailing 0 03-20-2009 01:08 PM
