Originally Posted by T4Rscott
It’s a 99 3.4l
I got this from Tacoma world.
The P1135 code is the heated portion of the front O2 sensor(s) malfunction... either shorted or open circuit. The ECM provides the ground and it monitors the voltage that is required to operate the heater portion of the front O2 sensor(s). If a 4 cyl, one front o2 sensor, V6, 2 front o2 sensors duh... anyway, there is a resistance spec for this and it is usually a pretty narrow range of a few ohms, check this first. Then check for 12v at the harness, you are going to have to get a wiring diagram to ID the correct wire(s). The next step is to disconnect the battery and let her sit for some 5 minutes to bleed down any capacitors in the ECM. Locate the ECM and disconnect the plug. The pins/connectors are pretty delicate so dont go poking around with screwdrivers and distort anything. Locate and ID each wire that goes to the O2 sensor you are checking and check for continuity, and shorts... you might have to exercise the harness to see if there are any breaks in the harness that you cant see. If all checks out OK I would check for how good the grounds are for the ECM and follow them to where they actually connect... Check the ground off of the battery to the block, the little ground off of the battery to the chassis, right by the battery and the ground from the firewall to the back of the head/block. The next test requires a decent volt/ohm meter... you will need to check the voltage drop from the ECM ground(s) to the battery... If there is a high voltage drop the ECM gets electronic noise, clutter, confused. This can be eliminated by a new ground wire from the ECM ground point to the negative post of the battery.
So I cant give you a yes or no answer on the high idle.
Build Thread:
https://www.toyota-4runner.org/3rd-g...os-builds.html
Brillo's Bucket Fluid Ex changer:
https://www.toyota-4runner.org/3rd-g...ml#post3358086
Sparks Plugs Wire and Coil Information:
https://www.toyota-4runner.org/3rd-g...on-5vz-fe.html
