Old 03-06-2020, 07:51 PM #46
RandyBobandy's Avatar
RandyBobandy RandyBobandy is offline
RandyBobandy is just really nice RandyBobandy is just really nice RandyBobandy is just really nice RandyBobandy is just really nice RandyBobandy is just really nice
so now that I have everything wired up and working decently, I have a couple issues, first of all the 4x4 indicator light does not come on, 4wd works but the light on the dash does not, it worked when I had the auto harness in with the 5 speed but no longer works after my harness swap, I have one unused plug on the tcase but from what I have read that is only used with the auto.
my second issue is I have a rough idle now, either in gear with the clutch in or in neutral, doesn't make a difference, felt like it was going to die at a stop light today but has plenty of power while driving, no cel or codes in the system and I let it idle in the driveway for a while and it was still slightly rough but didn't dip way down like while I was on the road. I looked everywhere for a vacuum leak and can't find any. anyone have an idea as to why this might be happening?
RandyBobandy is offline   Reply With QuoteReply With Quote
Old 03-07-2020, 12:26 AM #47
kolelt kolelt is offline
kolelt will become famous soon enough kolelt will become famous soon enough
Repinning an auto harness for use with a manual ECM
Sounds like you might not have everything plugged in or maybe something isn’t sitting correctly. Check engine light ?? I repinned my auto harness. Been 0 issues since.
97 3.4 JDM/5 Speed swap/eLocker Swap/ICON CDC all around/+more.....
kolelt is offline   Reply With QuoteReply With Quote
Old 03-07-2020, 08:07 AM #48
I’m thinking that might be the case with the 4wd light so I’ll have to recheck my plugs, I only repinned the one because I used the engine harness
I have no check engine light or codes, I’m thinking I must have a vacuum leak somewhere because I removed the intake plenum, and I can’t seem to do that without introducing some hard to track down leak
Old 03-09-2020, 02:38 PM #49
The ground for the 4WD light (ADD indicator switch) goes through the engine harness, so that is likely the problem. Check for that wire, and/or make sure the ADD indicator switch is plugged in, down below the driver's side exhaust manifold.
'17 Chevy Volt Premier
'16 Honda Odyssey Elite
Old 03-12-2020, 03:02 PM #50
Smile
So I fixed my vacuum leak, examined the wiring, everything looks good, I tested 4wd again and the light comes on but only in 4lo, any ideas why that might happen?
Old 03-12-2020, 06:14 PM #51
Are you using the transfer case off your auto trans or the one that came with the manual trans? The auto trans transfer case has 3 position switches, the manual transmission case has 1 switch only...
So, maybe you have your 4WD indicator plug connected to the 4LO switch?
Old 03-12-2020, 08:41 PM #52
Yep I’m using the auto tcase, I looked at the wiring diagram and I’m sure that’s the problem, I’ll mess with it later and update, thanks
Old 04-16-2020, 03:24 PM #53
I haven’t been very good at updating this thread but everything works as it should now with no warning lights on the dash
In other news I managed to find a Tacoma with manual hubs at the junk yard and got the whole assembly for $70
Here they are installed on my 4runner
Old 04-17-2020, 03:50 PM #54
thespwilson thespwilson is offline
thespwilson is on a distinguished road
I am watching this one...
Find me at thespwilson on IG
thespwilson is offline   Reply With QuoteReply With Quote
Old 04-18-2020, 07:13 PM #55
brillo_76's Avatar
Real Name: Jon
brillo_76's Avatar
Real Name: Jon
Yes the OP is a good person. Learning alm kinds of new skills.
Old 04-18-2020, 09:44 PM #56
GetitOffroad GetitOffroad is offline
GetitOffroad is on a distinguished road
Originally Posted by St Runner View Post
Its a lot of work but so much more fun to drive it as a 5 speed!
I have a 97 3.4 with a manual, I didnt realize they were rare. Normally avid four wheelers prefer autos, is the gen 3 auto that much of a dog?
GetitOffroad is offline   Reply With QuoteReply With Quote
Old 04-18-2020, 09:46 PM #57
That's pretty cool, I wondered if that was possible on a 4 runner. Did you notice any difference driving with it unlocked. I could on my old jeep.
Old 04-18-2020, 10:48 PM #58
Aren’t the axles in this set up slightly thinner ?
Old 04-19-2020, 05:31 PM #59
I've really only driven it like half a mile since doing the conversion, some people say they notice better mpg with the manual hubs and some say it doesn't change
the 3rd gen auto is perfectly fine, I just really like driving a manual and I've heard something like 3% of 3rd gens came with the manual so I decided to do the swap instead of hunting down a vehicle with one already in it, learned a lot in the process as well which is an added bonus
The thickness of the axle shaft looks the same to me, I have heard that the part that connects to the hub is weaker on the manual hub axles but I don't do anything too extreme with mine so I doubt I'll ever have to worry about breaking one
donor , harness , junk , tacoma , vehicle
99 LTD 5 Speed Swap PNWRunner 3rd gen T4Rs 53 12-14-2021 02:16 AM
5 speed swap help! DLM_2002 3rd gen T4Rs 12 05-01-2018 08:06 PM
WTB: 5 Speed Swap mattt4r Want to Buy/Trade 0 03-15-2018 05:49 PM
2001 4runner tranny questions possible swap questions. Did search samario1984 3rd gen T4Rs 5 06-09-2017 01:27 PM
5 speed swap ? 808T4R 3rd gen T4Rs 1 06-08-2016 02:18 AM
