03-06-2020, 07:51 PM
#46
so now that I have everything wired up and working decently, I have a couple issues, first of all the 4x4 indicator light does not come on, 4wd works but the light on the dash does not, it worked when I had the auto harness in with the 5 speed but no longer works after my harness swap, I have one unused plug on the tcase but from what I have read that is only used with the auto.
my second issue is I have a rough idle now, either in gear with the clutch in or in neutral, doesn't make a difference, felt like it was going to die at a stop light today but has plenty of power while driving, no cel or codes in the system and I let it idle in the driveway for a while and it was still slightly rough but didn't dip way down like while I was on the road. I looked everywhere for a vacuum leak and can't find any. anyone have an idea as to why this might be happening?
03-07-2020, 12:26 AM
#47
Repinning an auto harness for use with a manual ECM
Sounds like you might not have everything plugged in or maybe something isn’t sitting correctly. Check engine light ?? I repinned my auto harness. Been 0 issues since.
97 3.4 JDM/5 Speed swap/eLocker Swap/ICON CDC all around/+more.....
03-07-2020, 08:07 AM
#48
I’m thinking that might be the case with the 4wd light so I’ll have to recheck my plugs, I only repinned the one because I used the engine harness
I have no check engine light or codes, I’m thinking I must have a vacuum leak somewhere because I removed the intake plenum, and I can’t seem to do that without introducing some hard to track down leak
03-09-2020, 02:38 PM
#49
The ground for the 4WD light (ADD indicator switch) goes through the engine harness, so that is likely the problem. Check for that wire, and/or make sure the ADD indicator switch is plugged in, down below the driver's side exhaust manifold.
'17 Chevy Volt Premier
'16 Honda Odyssey Elite
03-12-2020, 03:02 PM
#50
So I fixed my vacuum leak, examined the wiring, everything looks good, I tested 4wd again and the light comes on but only in 4lo, any ideas why that might happen?
03-12-2020, 06:14 PM
#51
Are you using the transfer case off your auto trans or the one that came with the manual trans? The auto trans transfer case has 3 position switches, the manual transmission case has 1 switch only...
So, maybe you have your 4WD indicator plug connected to the 4LO switch?
03-12-2020, 08:41 PM
#52
Yep I’m using the auto tcase, I looked at the wiring diagram and I’m sure that’s the problem, I’ll mess with it later and update, thanks
04-16-2020, 03:24 PM
#53
I haven’t been very good at updating this thread but everything works as it should now with no warning lights on the dash
In other news I managed to find a Tacoma with manual hubs at the junk yard and got the whole assembly for $70
Here they are installed on my 4runner
04-17-2020, 03:50 PM
#54
I am watching this one...
Find me at thespwilson on IG
04-18-2020, 09:44 PM
#56
Originally Posted by St Runner
Its a lot of work but so much more fun to drive it as a 5 speed!
I have a 97 3.4 with a manual, I didnt realize they were rare. Normally avid four wheelers prefer autos, is the gen 3 auto that much of a dog?
04-18-2020, 09:46 PM
#57
That's pretty cool, I wondered if that was possible on a 4 runner. Did you notice any difference driving with it unlocked. I could on my old jeep.
04-18-2020, 10:48 PM
#58
Aren’t the axles in this set up slightly thinner ?
04-19-2020, 05:31 PM
#59
I've really only driven it like half a mile since doing the conversion, some people say they notice better mpg with the manual hubs and some say it doesn't change
the 3rd gen auto is perfectly fine, I just really like driving a manual and I've heard something like 3% of 3rd gens came with the manual so I decided to do the swap instead of hunting down a vehicle with one already in it, learned a lot in the process as well which is an added bonus
The thickness of the axle shaft looks the same to me, I have heard that the part that connects to the hub is weaker on the manual hub axles but I don't do anything too extreme with mine so I doubt I'll ever have to worry about breaking one
