Old 11-10-2019, 10:12 AM #1
RandyBobandy's Avatar
RandyBobandy RandyBobandy is offline
RandyBobandy is on a distinguished road
A few 5 speed swap questions
Iíve been considering doing a manual swap on my 97 recently and have a few questions for those that have done it
Iíd really like to get an entire donor vehicle but finding a junk 5 speed within a reasonable distance seems almost impossible, so is there any source where I can buy the engine wiring harness and ecu? And do they have to be from a 97 or would a 96 or 98 harness work? How about from a Tacoma? I understand the ecu plugs are different between the years but would that still be a problem if I am using the matching wiring harness?
Another thing I wanted to know, could I use a Tacoma as a donor vehicle, they seem to be more plentiful, but would things like the pedals and drive shafts work?
And finally will this be drivable with my Aussie locker or should I consider going to a selectable, I really like the lunchbox locker and the street manners are excellent but Iíve heard it can be harder keep from chirping tires with the manual
Thanks for any advice, Iím just trying to determine if I should keep looking for an appropriate donor vehicle or just piece together components from junk yards as they become available
RandyBobandy is offline   Reply With QuoteReply With Quote
Old 11-10-2019, 11:38 AM #2
MaineRunna's Avatar
MaineRunna MaineRunna is offline
MaineRunna will become famous soon enough MaineRunna will become famous soon enough
MY GARAGE
MaineRunna's Avatar
MY GARAGE
I would recommend finding a donor vehicle. That way you will have every part you would ever need for the swap. You would probably want a 96 or 97 as they changed a lot of the wiring in 98. You can swap the whole ECU and engine and dash wiring harnesses or change the ECU connectors and repin them. Either way is quite time consuming. Swapping the whole harness means taking the dash out, but guaranties that everything works, because everything just plugs in. You should be able to find some rusty gold in PA for a few hundred bucks.
98 SR5 4X4 5spd, desert dune metallic, Toytech Eibach 3" lift, 1" body lift, 4XInnovations bumpers, Doug Thorely Headers, Magna-flow converter, RCI skid plate, SPC UCA's & rear LCA's, Tundra brakes, BFG 255/85R16 Mud Terrain T/A's 225,000 miles
MaineRunna is offline   Reply With QuoteReply With Quote
Old 11-10-2019, 01:05 PM #3
brillo_76's Avatar
brillo_76 brillo_76 is online now
Real Name: Jon
brillo_76 has a spectacular aura about brillo_76 has a spectacular aura about
MY GARAGE
brillo_76's Avatar
Real Name: Jon
MY GARAGE
The rusty gold is disappearing around the state.. I seen quite a few people doing 5 speed swaps. It's a shame Toyota removed manuals as an option in their 4 runner lines. :[
1997 4X4 V6 5 Speed Sr5 4 Runner (97 5 speed )
1997 4X4 V6 Red limited 4 Runner (97 Limited)
1998 4X4 V6 Sr5 Red 4 Runner (98 Tetanus1 )
1998 4X4 V6 Sr5 Silver 4 Runner (98 Tetanus2)
2001 4X4 V6 Sport Green 4 Runner (01 Green Sport)
brillo_76 is online now   Reply With QuoteReply With Quote
Old 11-10-2019, 07:51 PM #4
this is true, while junk 4runners are out there manuals are super rare, which is why i was interested in using a tacoma as a donor since they are more common. I check craigslist and facebook daily, and I'm willing to travel a fair distance
I agree about being disappointed that toyota doesn't offer a manual in the new ones, if there was a bare bones manual model offered i would go and get a new one, but until then I prefer the older ones
Old 11-10-2019, 08:04 PM #5
UnderFire's Avatar
UnderFire UnderFire is online now
UnderFire will become famous soon enough UnderFire will become famous soon enough
UnderFire's Avatar
Off of a Tacoma you can use:
Pedals
Clutch hydraulics
Bellhousing
Transmission
Transfer case (as long as it's the right one you want or a j shift)
Shifters
Clutch / flywheel
Front driveshaft
Floor boot plate
Possibly wiring harness/ecu if you match it up
You'll still be missing
Rear driveshaft
Interior trim piece
Sent from my JSN-L23 using Tapatalk
'97 3RZ 5 Speed "FrankenRunner" (Build Thread) - Tundra TRD/5100's/LC 8 Wraps Lift | 1" BL | 4.88's F/R | 35x15 Toyo M/T on 15x10 AR23's | 4WD Conversion | Manual Hub Conversion | NWTI Front Bumper | Tan Interior Conversion | Infiniti QX4 Seat Swap | 99+ Upgrades | OTRATTW Switches| Yakima rack setup | 42" LED Bars F/R | 2x Lightforce Genesis 210 HID's
UnderFire is online now   Reply With QuoteReply With Quote
Old 11-10-2019, 08:20 PM #6
brillo_76's Avatar
Real Name: Jon
MY GARAGE
brillo_76's Avatar
Real Name: Jon
MY GARAGE
Part of the reason for being more rare is because only 2 to 3% of the last years up to 2000 were manuals sold in the United states. :[
Keep us posted. Why not create a build thread for your conversation? That way you have a timeline for yourself. :]
Old 11-10-2019, 08:39 PM #7
Thank you for the help everyone, I will definitely start a build thread when I start this project, I probably should have started one already but I havenít taken any pictures of the stuff Iíve done and my 4runner is really a rusty old jalopy compared to a lot here, but the good news is it drives and runs amazingly since I have way more than itís worth into it so I might as well swap in a manual since Iíll be keeping it for a long time
donor , harness , junk , tacoma , vehicle
5 speed swap help! DLM_2002 3rd gen T4Rs 12 05-01-2018 08:06 PM
WTB: 5 Speed Swap mattt4r Want to Buy/Trade 0 03-15-2018 05:49 PM
2001 4runner tranny questions possible swap questions. Did search samario1984 3rd gen T4Rs 5 06-09-2017 01:27 PM
5 speed swap ? 808T4R 3rd gen T4Rs 1 06-08-2016 02:18 AM
99 LTD 5 Speed Swap PNWRunner 3rd gen T4Rs 45 02-04-2016 06:19 PM
Copyright ©2000 - 2019, vBulletin Solutions Inc.
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2019 DragonByte Technologies Ltd.
Feedback Buttons provided by Advanced Post Thanks / Like (Lite) - vBulletin Mods & Addons Copyright © 2019 DragonByte Technologies Ltd.
User Alert System provided by Advanced User Tagging (Lite) - vBulletin Mods & Addons Copyright © 2019 DragonByte Technologies Ltd.
Copyright © 2019
