Originally Posted by hallj22
Hi all,
Hopefully, someone can steer me in the right direction. I did a few searches, but searching for clutches brings back a massive amount of manual clutch results and not many air compressor results. I've got a noise coming from the air compressor. I know very little in this arena. I'm not running the AC at all at this point since "Winter is here". If it's still making noise what would be more likely the clutch, pulley, or the actual AC motor itself? It doesn't seem like I can replace just the pulley as I haven't found that part for purchase. ANy help would be appreciated.
Thanks,
Jeremy
you can rebuild the AC clutch/stator
https://www.toyota-4runner.org/2858245-post21.html
if your not planning on using the AC for the winter? my advise would be just to cut the AC belt. yes you will have to get a new AC belt but they are only like $20. if you don't feel like fixing it until spring cutting the belt is lazy but easy.
the best course of action is really to replace the AC compressor and at the very least the A/C drier assembly.
