Old 11-10-2019, 03:29 PM #1
hallj22 hallj22 is offline
hallj22 is on a distinguished road
97 sr5 Air compressor noise
Hi all,
Hopefully, someone can steer me in the right direction. I did a few searches, but searching for clutches brings back a massive amount of manual clutch results and not many air compressor results. I've got a noise coming from the air compressor. I know very little in this arena. I'm not running the AC at all at this point since "Winter is here". If it's still making noise what would be more likely the clutch, pulley, or the actual AC motor itself? It doesn't seem like I can replace just the pulley as I haven't found that part for purchase. ANy help would be appreciated.
Thanks,
Jeremy
hallj22 is offline   Reply With QuoteReply With Quote
Old 11-10-2019, 04:14 PM #2
Riceye Riceye is offline
Riceye is on a distinguished road
The a/c compressor engages when your climate control is in either of the defrost modes. This can be disabled by disconnecting the plug with the blue wires on the back of the climate control console. Disassembly of the dash is necessary to achieve this mod.
Often compressor pulley bearing noise occurs when the compressor clutch is not engaged, as the belt is turning the pulley but not the compressor itself. The bearing now spins, whereas when the a/c is engaged the bearing is not spinning.
Edit: your search results will be better if you refer to the assembly as a/c compressor clutch, not just compressor or clutch.
_________
2000 SR5 five speed. Everything works, even the antenna. No special mods; It's my canoe, kayak and dog hauler/winter beater.
I find that things usually go well right up until the moment they don't.
Riceye is offline   Reply With QuoteReply With Quote
Old 11-11-2019, 09:50 AM #3
sleepydad's Avatar
Real Name: Andy ಠ_ಠ
sleepydad is a jewel in the rough sleepydad is a jewel in the rough sleepydad is a jewel in the rough
sleepydad's Avatar
Real Name: Andy ಠ_ಠ
Originally Posted by hallj22 View Post
Hi all,
Thanks,
Jeremy
you can rebuild the AC clutch/stator
https://www.toyota-4runner.org/2858245-post21.html
if your not planning on using the AC for the winter? my advise would be just to cut the AC belt. yes you will have to get a new AC belt but they are only like $20. if you don't feel like fixing it until spring cutting the belt is lazy but easy.
the best course of action is really to replace the AC compressor and at the very least the A/C drier assembly.
Old 11-15-2019, 11:58 PM #4
I cut the belt for now. Problem solved. Thanks for the advice!!
air , compressor , noise , pulley , results
AC compressor noise dave4242 4th Gen T4Rs 2 07-12-2015 07:45 PM
AC Compressor noise??? Toymaker General Discussions 4 06-10-2015 12:49 PM
Ac compressor noise hec983 3rd gen T4Rs 6 01-28-2014 09:27 PM
AC Compressor or Idler Pulley Noise Diesel_Dog 3rd gen T4Rs 4 09-02-2013 02:17 AM
New A/C compressor, now terrible squeling noise rshields85 4th Gen T4Rs 2 08-09-2011 02:20 PM
Copyright ©2000 - 2019, vBulletin Solutions Inc.
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2019 DragonByte Technologies Ltd.
Feedback Buttons provided by Advanced Post Thanks / Like (Lite) - vBulletin Mods & Addons Copyright © 2019 DragonByte Technologies Ltd.
User Alert System provided by Advanced User Tagging (Lite) - vBulletin Mods & Addons Copyright © 2019 DragonByte Technologies Ltd.
Copyright © 2019
