Old 11-10-2019, 04:13 PM #1
Moto13 Moto13 is offline
Moto13 is on a distinguished road
Likely annoying boneheaded lift question
I promise I searched and read.
I've got a crazy lean I posted about before. I had an issue with the driver rear trail arm mount at the frame. New saf t cap welded in and everything is square and perfect. The lean however persists. On a previous post some suggested that my rear suspension was in rough shape. No bump stops, etc.
Sooooo, I'm looking at my options. Right now I have 2" tall springs. I have brand new 275/75/16 MTs. The front sits perfect and has lots of new components and a good alignment. It's the rear that's bottoming out on the trail and rubbing when stressed.
The Toytec 3" is $900. It's nice but in the last two months I've done a new ARB bumper, winch, and new set of tires. Will it be a problem if put something like OME 890s and Bilsteins back there? The rear will likely be a little higher and will have a different spring rate than the front. I did build a shelf system and keep a bunch of tools and equipment back there.
TLDR: rear suspension is borked and I'm trying to be cheap.
Sent from my SM-N950U using Tapatalk
1996 Limited
Moto13 is offline   Reply With QuoteReply With Quote
Old 11-10-2019, 04:48 PM #2
Chris In Milwaukee's Avatar
Chris In Milwaukee Chris In Milwaukee is offline
Chris In Milwaukee will become famous soon enough Chris In Milwaukee will become famous soon enough
The Dobinsons springs are different sizes for each side to combat the lean. Might consider that option if everything else is square and as expected.
Dobinsons 5th Gen T4R Suspension options - lots of choices
I'm not sure about 3G options, but worth a look.
2019 MGM TRD ORP
BFG KO2 265/70-17
Dobinsons C509-302/GS59-700, C59-505/GS59-705, UCAs
Victory 4x4 Blitz Bumper w/Zeak 12000
Chris In Milwaukee is offline   Reply With QuoteReply With Quote
Old 11-10-2019, 04:53 PM #3
wtfemery's Avatar
wtfemery wtfemery is offline
wtfemery will become famous soon enough
wtfemery's Avatar
have you taken a good look under there to see if the springs are seated correctly and that you’re not missing parts?
I just put some 890s on my rig and went from 19.75” to 22.5” hub to fender in the back. already had bilstein 5100s
edit: the 890s are slightly taller on the drivers side, you could also put a 10mm spacer on top.
1997 4x4 SR5 3" Lift @254,000 miles
I welded my own bumper!
wtfemery is offline   Reply With QuoteReply With Quote
back , front , rear , suspension , trail
One more Bilstein 5100 front lift, 0 rear lift question. Hugo Stiglitz 5th gen T4Rs 31 08-07-2020 10:29 PM
Basic Lift Question - read all the lift info threads BXPhoto 3rd gen T4Rs 11 01-02-2017 09:34 PM
Anyone else think this is annoying? Brian3676 4th Gen T4Rs 28 04-22-2016 03:28 PM
Air Lift 1000 and Lift Question - Spring Seats G8RB8_12SR5 5th gen T4Rs 4 08-24-2014 11:15 PM
Annoying ads on T4R.ORG? fightman80 General Discussions 5 03-18-2014 02:09 PM
