Old 11-10-2019, 04:22 PM #1
Elesage Elesage is offline
Real Name: Eric
Elesage is on a distinguished road
Real Name: Eric
Cool Need New front Bearing which one to choose ?
Hi everyone Il need new front bearing André dont know which on to choose,
Some Will tell me Toyota only at 400$each. I found Some koyo at 200$ for a set of 2 with thé seal, an auto part near where I live tell me that skf si thé Way to go at 95$ each and there is Timken that did à great job on my last truck,102$ on Rock auto.
What is thé best choice, if I dont have thé money for the Toyota one but I dont want to redo them next year.
Any constructive comment will help, or help will be taken in cosideration,
Thank you for all your helpfull comments
'02 4Runner
Daystar 2.5" lift spacer
255-85R16
Elesage is offline   Reply With QuoteReply With Quote
Old 11-10-2019, 04:34 PM #2
mtbtim's Avatar
mtbtim mtbtim is offline
Real Name: Tim
mtbtim's Avatar
Real Name: Tim
You could use these bearing available on Amazon: https://amzn.to/2t8rSH7
If you're interested in doing the job yourself, watch this video to know how to get the knuckle off and back on your rig. Just skip past all the stuff related to replacing the upper ball joint.
To learn how to do the required press work, watch this video:
Old 11-10-2019, 07:57 PM #3
UnderFire's Avatar
UnderFire UnderFire is offline
UnderFire has a spectacular aura about UnderFire has a spectacular aura about UnderFire has a spectacular aura about
UnderFire's Avatar
Koyo would be my go-to, but overall any of the manufacturers you listed are reputable and our trucks don't typically have front bearing issues so they should last.
Sent from my JSN-L23 using Tapatalk
'97 3RZ 5 Speed "FrankenRunner" (Build Thread) - Dormant
The "shitmobile" 500$ 3RZ Auto 4Runner - (Saved from the Scrapyard: Resurrecting a 500$ 3rd Gen
02 Tacoma Double Cab, mid-travel, locked, armored, supercharged and riced. (Longbed and 5 speed in the works)
UnderFire is offline   Reply With QuoteReply With Quote
Old 11-10-2019, 11:28 PM #4
XtremeAdventurer XtremeAdventurer is offline
XtremeAdventurer is on a distinguished road
I bought the Timken bearing off rockauto for $62 each. Was very pleasantly surprised when the bearings were stamped KOYO in a Timken box. Everything (all numbers and markings) was the same as the factory bearing that I removed.
After some research, it looks like Timken bearing are made by koyo.
XtremeAdventurer is offline   Reply With QuoteReply With Quote
Old 11-11-2019, 12:11 AM #5
HiLife HiLife is offline
Nothing is worse that driving around with bad front bearings. That rumble can drive you nuts.
You always can swap in a spindle from the recycle yard for a temp fix. It can buy you time to save up and do the job properly down the line. And on the plus side, if your doing the job yourself, it will save you on the down time by just swapping in the rebuilt spindles when your ready.
Old 11-11-2019, 12:32 AM #6
jross20's Avatar
jross20 jross20 is offline
jross20's Avatar
Man I was about to post to ask something similar.
I see this site called Blue Pit Bearing, the guy seems to be considered legit from what I can read. But I don't see a specific hub/bearing assembly for the 3rd gen 4runners, so my question was are any of them universal for toyotas? Like From the 4th gen or some of the sequoias?
https://bluepitbearings.com/products?olsPage=t%2F4x4
Seems like a good deal to just have the whole thing, this is what I did with my 2nd gen taco about a year ago. Though that was from a dude on tacoma world.
Old 11-11-2019, 01:04 AM #7
pluton's Avatar
pluton pluton is offline
Real Name: Keith
pluton has a spectacular aura about pluton has a spectacular aura about pluton has a spectacular aura about
pluton's Avatar
Real Name: Keith
Unless I'm operating the computer machine wrong, the front wheel bearings for the 2002 4Runner are $79 each at Camelback.
pluton is offline   Reply With QuoteReply With Quote
Old 11-11-2019, 01:35 AM #8
UnderFire's Avatar
UnderFire's Avatar
In the 3rd gen platform the bearings are pressed directly into the spindle itself. Overall a much better more robust design than the bolt-on hub assembly that they switch to in the newer platform. The trucks rarely have issues with wheel bearings, I've changed 2 of them, both on trucks that had over 300k miles, and to have a set ready to bolt on and go would mean sourcing a separate set of spindles, buying all parts, either pressing or having them pressed in (your typical at home shop press usually won't cut it.) easily a 600$ + endeavor for something you may never need.
Old 11-11-2019, 10:58 AM #9
jross20's Avatar
jross20's Avatar
Ah shoot. Well, is it not worth it even to do the press swap in the name of preventative maintenance? Trying to make sure my girl is good for th long haul.
Old 11-11-2019, 11:02 AM #10
BoomerBob's Avatar
BoomerBob BoomerBob is offline
BoomerBob will become famous soon enough BoomerBob will become famous soon enough
BoomerBob's Avatar
Are you saying a 20 ton press won't handle this bearing press job? I know it's a tricky setup to do but I thought the 20 ton would work when the time comes.
2001 2wd - Daily Driver
BoomerBob is offline   Reply With QuoteReply With Quote
Old 11-11-2019, 04:02 PM #11
Harbor Freight 20 ton press is what I used. Had to make a couple press plates, but it worked really well. I think it was about $150 after coupon and tax.
Old 02-17-2020, 10:55 PM #12
Luiseno Luiseno is offline
Luiseno is on a distinguished road
Hey I was wounding it there was a video or step by step tutorial for this procedure I have 2002 4runner 2 wd and I have to replace my wheel bearings and cant find anything on it.
Luiseno is offline   Reply With QuoteReply With Quote
Old 02-17-2020, 11:02 PM #13
Do u know if there is a video or step by step tutorial I have a 2002 2wd 4runner v6
auto , bearing , choose , thé , toyota
3rd gen front bearing blown 4x4 need help please 5SPD_MAN_RUNNIN 3rd gen T4Rs 3 06-25-2014 05:10 PM
Front diff bearing sawguy 3rd gen T4Rs 2 04-20-2014 08:45 AM
Please Help me choose front suspension setup,planning OME + Billies parnavaz 3rd gen T4Rs 9 09-08-2013 12:11 AM
Front bearing help....again! indy500 4th Gen T4Rs 0 11-19-2012 10:04 PM
bearing& hub assy - help me choose earthrealm 4th Gen T4Rs 2 06-07-2012 09:21 AM
