03-24-2015, 07:36 PM
UPCOMING: Oil Cooler Gasket Replacement
I noticed a leak from my oil cooler on my 2000 T4R LTD 4WD with the 3.4L engine. (It only lasted 250K miles!) I could not seem to find a detailed write up (with pics) on changing out the o-rings on the oil cooler so I will try and document the process with pics and post on this thread. For now, I picked up the OE parts for my rig.
Large O-Ring (Mounts to between the oil cooler and engine block)
Part #: 90301-67004
Washer Seal (This is the “washer seal” that the main bolt goes through)
Part #: 90210-22001
As we all know, oil creeps everywhere so a minor drip can appear to be a major leak. If you are interested in doing this and want a detailed post with pics, please comment on this “upcoming” thread. Thanks everyone!
03-24-2015, 09:30 PM
I've always wondered if our trucks at oil coolers. May be a no brainer, but I was not sure. Where is it located?
1999 Highlander Edition, Imperial Jade Mica, Auto with e-locker, OME 906s Rear with Bilstein 5100 shocks, 5100 with OME 880 fronts, Airaid Intake, Custom cargo basket with Quickfists. Lots of mechanical 241,000+ miles
Follow the Adventure on Instagram: http://www.pictaram.com/user/twistingterrian/3486826971
03-24-2015, 09:51 PM
If you pull off the front, driver's side tire, there is a "curtain" hanging there. If you look to the right of the curtain, pull it down, you will see the oil cooler assembly. (it is located to the right of the oil filter on the engine block) It has two coolant lines running to it. There is a center bolt you have to unscrew and this allows you to pull the oil cooler unit. There are two seals; one is an O-ring and the other is a bolt-washer-seal like shown in the photos of the original thread. If you get up under the truck on the driver's side and look up towards the driver's side of the engine, you can also see where it is mounted.
03-24-2015, 09:57 PM
Real Name: John
Real Name: John
I would replace those coolant hoses also, while I was in there. OEM of course.
SILVER 2000 4runner Limited TOTALED
WHITE/SILVER 1999 4runner Limited l Rear Locker l Tundra/890 coils | 5100 Bilsteins all around | Sonoran Steel Bumpstops l 199 mm Tundra brake upgrade | SCS Matte Gray Ray10 Rims | 275 70 17 BFG KO2 tires | LR UCAs | EIMKEITH panhard brackets | LED interior upgrade l Rear LED tailights l Pioneer AVH-X5700BHS Alpine Type "R" speakers NVX JAD800.4 Class D Amp Kenwood Under seat Subwoofer l Front window tint 20% l Weathertech window visors and floormats l OutGear Solutions Full Length roofrack l Morimoto 40" LED lightbar
03-24-2015, 10:00 PM
Real Name: Scott
Real Name: Scott
I'd like to see a writeup. I've got a leak on that side, but I assumed it was residual spillage from pulling the oil filter. Not sure now
03-24-2015, 10:03 PM
OK guys, I will do a "photo documentary" and write up on the change. I am just hoping it is as easy as it seems in the FSM. I think this is something that has to impact ALL of our T4R's at one point or another and if I can help someone save some time and take the questions out of doing it on their own rig, I am happy to do it!
03-24-2015, 10:51 PM
Real Name: Scott
Real Name: Scott
I was surprised to see that camelback wants $480 for the whole cooler unit. I wonder what the expected lifetime for that whole thing is...
Anyway...
03-24-2015, 11:33 PM
I replaced the coolant hoses going to the oil cooler during my last timing belt change. Getting to that area is a nightmare. I considered swapping out those O-rings while I was in there, but it was a gigantic NOPE.
Good luck. Try to get pictures that show what angles you are going at it. Its not going to be easy to get back in there.
03-25-2015, 05:30 PM
Did you try going in through the driver's side front wheel well to get to the oil cooler?
03-25-2015, 06:37 PM
Real Name: John
Real Name: John
^^This When I did ,my UCAs, the cooler and hoses were right there. Should be fairly easy.
04-11-2015, 12:52 PM
Yes. Went from the side, top, and bottom near the power steering rack. Removing the alternator is a must. Its just a ***** getting back in there.
04-11-2015, 01:03 PM
I was able to do the change in about an hours time. No need to remove alternator or anything. I went from the bottom/above the steering rack from the back side. Takes a little bit of figuring out where to access it with wrenches and shit but in due time it'll come out.
Quite a straight forward and easy swap. I remember when looking for write ups to change mine back then there was none
If I remember correctly don't forget to drain your coolant and oil before removing it. Otherwise you will have that shit everywhere and possibility of one getting to the other where they shouldn't mix.
My o ring was hard and brittle upon removal. It was definitely my leak that I thought was my CV axels the whole time. Replaced the driver side front diff seals a couple times as well as reseating the CV a couple of times.
2016 Toyota 4Runner Trail Edition
04-11-2015, 01:30 PM
I thought to go up from under the steering rack but didn't see a way to get at it from underneath. Maybe removing the driver's side CV would help free up some space.
10-26-2018, 04:26 PM
Can someone clarify if the oil needs, I mean absolutely needs, to be drained? Is it the risk of coolant & oil contamination, resting oil level sits at or above the cooler, or does the cooler carry enough oil in it to need more after replacing the seals?
Thanks for the help.
Sent from my XT1635-01 using Tapatalk
10-26-2018, 05:02 PM
Real Name: John
Real Name: John
Don't need to drain the oil but you will lose some coolant. Remove the hoses first, let it drain then remove the cooler. Top off the coolant when complete.
