Old 11-10-2019, 11:46 PM #1
STI_MECE's Avatar
STI_MECE STI_MECE is offline
STI_MECE will become famous soon enough
STI_MECE's Avatar
Front brakes dragging after steering wheel wobble
So, as title reads....at around 60-65 the steering wheel wobbles a good amount left to right, then gradually after that about 10 minutes or so, the front brakes are full on locked up (not retracting) and just dragging hard.
Eventually it get to the point where the truck will not go anywhere.
Alittle backstory....I had this exact problem when going to NTB to get an alignment done. On the way their, brakes locked up. They told me the calipers were siezed so they put remanufactured ones on.
Fast forward two or three months, my brakes locked up again....so I go ahead and replaced the rubber brake lines.
That didn't change anything. I made sure the Pistons on the calipers were still moving and they were.
Even after I did all of that, plus flushing the bell out of front end I couldn't get the pads to stop dragging.
This problem is repeatable. To a T, get in truck when the brakes are cold drive on high for a few minutes, and then steering wheel wobbles then brakes begin to drag more and more.
I think the wobble comes from the brakes swelling then eventually they get so hot everything mashes together. but even cold, the brakes are slightly dragging.
What gives? The entire week the brakes were stellar. I rebuilt the rear brakes and bleed them and my brakes were good as new then all the sudden the front craps on it self. And I never touched them since NTB did it.
And both sides drag as well....so that tells me it's something related to the entire system itself than just 1 side.
Sent from my Pixel 2 XL using Tapatalk
2000 SR5 4x2 Resto/Maintenance
STI_MECE is offline   Reply With QuoteReply With Quote
Old 11-11-2019, 07:24 AM #2
STI_MECE's Avatar
STI_MECE's Avatar
I'm also missing the anti squeal and shim pads on both sides for the brakes Front brakes dragging after steering wheel wobble so I can at least start there.
And whenever I tried getting the Pistons to retract I had to open the bleeder and the cap on the master cylinder resivoir to get them to push back but what was funny is that they came back to their original spot after I push them back in.
I have not had to drive this deep in a brake system before.
I'm ready to order some OEM parts lol
Old 11-11-2019, 09:30 AM #3
brillo_76's Avatar
Real Name: Jon
brillo_76 is a name known to all brillo_76 is a name known to all brillo_76 is a name known to all brillo_76 is a name known to all brillo_76 is a name known to all brillo_76 is a name known to all
brillo_76's Avatar
Real Name: Jon
What did you use for parts?? Where did the calipers and shoes come from??
1997 4X4 V6 5 Speed Sr5 4 Runner (97 5 speed )
1997 4X4 V6 Red limited 4 Runner (97 Limited)
1998 4X4 V6 Sr5 Red 4 Runner (98 Tetanus1 )
1998 4X4 V6 Sr5 Silver 4 Runner (98 Tetanus2)
2001 4X4 V6 Sport Green 4 Runner (01 Green Sport)
Old 11-11-2019, 10:07 AM #4
STI_MECE's Avatar
STI_MECE's Avatar
From what NTB told me, they are just "remanufactured" calipers, and most likely rebuilt with non OEM stuff.
I got rubber brake lines from NAPA.
Everything else, pads and rotors i have not touched on the front end since I got it.
Old 11-11-2019, 10:47 AM #5
Bad Luck Bad Luck is offline
Real Name: Patrick
Bad Luck is just really nice Bad Luck is just really nice Bad Luck is just really nice Bad Luck is just really nice Bad Luck is just really nice
Real Name: Patrick
That would lead me to believe the remanufactured calipers are the issue
2000 Limited V6 Auto E-Locker
Old 11-11-2019, 11:10 AM #6
BoomerBob's Avatar
BoomerBob BoomerBob is offline
BoomerBob will become famous soon enough BoomerBob will become famous soon enough
BoomerBob's Avatar
I agree 100%. I've been hearing reman calipers are a waste of money. They don't need to be OEM but they should be new from a reputable company. I'm looking at the Callahan's.
I replaced the rotors and pads on the front of my 01 and now I have the dreaded pulsing that indicates a warped rotor or two. I just got back from a 1200 mile trip and it didn't get worse but at times I didn't get the steering wheel shake (without hitting the brakes) which tells me the pistons sometimes retracted more than others.
I'll be checking for rotor warp with a dial indicator and if my new rotors are warped I'll replace them or it and the caliper(s).
What I'm wondering is if the ABS system can be causing any of this...
2001 2wd - Daily Driver
BoomerBob is offline   Reply With QuoteReply With Quote
Old 11-11-2019, 11:12 AM #7
BoomerBob's Avatar
BoomerBob's Avatar
Does anyone know if this is normal or does it indicate an issue somewhere?
Old 11-11-2019, 11:16 AM #8
brillo_76's Avatar
Real Name: Jon
brillo_76's Avatar
Real Name: Jon
Sadly, Even some of the pads from the Chain autoparts are junk too. They don't fit or are too tight etc.
I put Napa Remains on my 98 Tetanus 1. I most of lucked out. They brake perfectly and are not hanging up. My original ones were but they had over 240K in the rust belt on them.
I would suspect like the others suggested that its either the calipers or the ABS system as you have VSC.
Some brake pads come with the shims already on them too. I have seen that as well from the Autoparts chain stores.
Old 11-11-2019, 11:21 AM #9
brillo_76's Avatar
Real Name: Jon
brillo_76's Avatar
Real Name: Jon
I never really paid that close attention when I changed brakes in my Tocuma or 01 4 Runner. I just pushed the calipers pistons back.
I didn't have to take a bleeder loose or take a brake fluid cap off though.
The pistons stayed put though until I got it all back together. I never had them move or anything.
You might be onto something there Boomerbob. I didn't have the same experience.
Old 11-11-2019, 11:21 AM #10
STI_MECE's Avatar
STI_MECE's Avatar
That is what im saying....I do not think its normal. My logic tells me there is still pressure being generated from somewhere else (like the master).
With the car off, and opening the bleeders, then pushing the piston in, the piston should not come back out unless something else is acting on it.
It didnt come back as far as it was initially but it did come back out.
Maybe the brake pedal is not fully disengaging off the master, the booster is aftermarket. And considering the POS has screwed up everything in existence on this thing, maybe the push rod was out of adjustment and eventually wore the internal springs out from returning to their original spot??
That is a hail mary lol To me, after drawing it out more and more, there is something going on in the master cylinder, or there is something coming on between the booster push rod and master cylinder, or its the brake pedal not fully returning to its normal height (easy test) lol
its just all far fetched because I always got problems that no one else seems to have
I did try doing some emergency braking too and I cant get ABS to engage, but i was doing it on concrete, but i was definitely make those tires scream pretty good.
Old 11-11-2019, 11:47 AM #11
brillo_76's Avatar
Real Name: Jon
brillo_76's Avatar
Real Name: Jon
What was the brakes and the calipers like before the remain change?
Maybe they use the crappiest cheapest calipers they could find and caused you this unnecessary grief. :-(
Old 11-11-2019, 12:14 PM #12
STI_MECE's Avatar
STI_MECE's Avatar
I will provided a play by play of my lovely brake story lol
the brakes were always mushy....like stupid soft before....from the first day i got it.
i would have to stand on the pedal to get it to stop not completely stand on it but the pedal would drop farrrr. Took him home, noticed drive side rear bleeder was leaking, it was just look (totally safe i know lol) that was day 1
took it home went HAM on suspension for 1 month. never drove it during that period.
Then after suspension was done, took it to NTB to get alignment. driving it there, the front brakes were dragging and gradually dragging more and more.
The only way for me to get back home was to have NTB put re-manufactured calipers on. they told the calipers were frozen, both of tthem.
They didn't replace the pads or rotors, just the calipers.
Took it home drove great, brakes still spongy or soft. I attributed that to the fact that my rear drums had oil on them. Because before i got new tires, i saw the ones that were on there, had the lovely oil streaks (they were not fresh either).
The PO had reciept of repair they only did the seals and cleaned drums
the brake were soft from that point on, always had to stand on brakes to get it to stop.
fast forward two months and 2k miles, oil leaking out of rear axles.
Rebuilt axles, rebuilt drums, bleeded the rear brakes. stopped like a dream. progression was back to normal and had stopping power.
then another 1k miles just drove 185 miles, ran like a top. turned it on the next morning and boom brakes started dragging on highway. (front ones)
Old 11-11-2019, 12:34 PM #13
Real Name: Patrick
Real Name: Patrick
@STI_MECE I forgot that you were the proud owner of a poorly repaired vehicle by the previous owner. With that in mind and thinking more about you having to crack the bleeders to push the pistons back in, there is a possibility that the piston in the master cylinder isn't returning all the way to allow the brake lines to depressurize and return fluid back into the reservoir. Just a thought and something to consider if new calipers don't fix your issue.
Old 11-11-2019, 12:46 PM #14
STI_MECE's Avatar
STI_MECE's Avatar
I leaning more towards the master cylinder being the issue considering both sides are dragging and exhibiting the exact same symptoms.
I need to do some surfing to see if there is a way to diagnose a bad master cylinder. There are no leaks what so ever. But I wouldnt be surprised if all the flushing I have done dislodged something to the cylinder and just clogged it or something.
semi unrelated, I have a used OEM booster ready to go on. just need a few small things. Would be nice if it was the master then i can trash the whole thing together.
I think my time is better spent doing the timing belt for now lol
Old 11-11-2019, 01:33 PM #15
STI_MECE's Avatar
STI_MECE's Avatar
Got some prices from dealership.
Remanufactured calipers (Per Side) - 111
Shim and Squeal Pads (Both Sides) - 18.75
OE Pads (Both Sides) - 79
Rotor (Per Side) - 63.00
Master Cylinder - 239
I am super tempted to replace all lol I cant argue with these prices.
brakes , dragging , front , steering , wheel
Front Brakes dragging tristero 5th gen T4Rs 10 06-16-2018 11:28 PM
Wheel wobble and steering off mendozer 3rd gen T4Rs 0 04-04-2016 03:00 PM
Steering Wheel Wobble Deadly_Scionide 5th gen T4Rs 13 05-18-2012 03:27 PM
steering wheel wobble Cox 4th Gen T4Rs 7 05-09-2011 01:29 PM
Brakes dragging front left. HELP SOMS4RUNNER Problems & Warranty Issues 1 10-24-2010 05:09 PM
