Old 11-12-2019, 06:00 PM #16
DK327's Avatar
DK327 DK327 is offline
DK327 is on a distinguished road
DK327's Avatar
Originally Posted by T4R2014 View Post
Does it really? Both take more time than you'd think to warm up. Even with driving around for twenty minutes on a cold winter day the coolant will be lukewarm at best. I would think the coolant warms up the ATF faster and then maintains the temps.
In the winter, with the inline trans cooler, my trans consistently runs at 120F and i haven't had any issues, at all. A cool trans is a happy trans. I bet a trans running cooler than "normal" will last longer than one that's running hotter than normal. AFAIK, high temp is the #1 killer of transmissions and I've never heard of transmissions issues because they ran too cool. But hey, what do I know...
00 T4R LTD V6 4WD 275K e-locker
11 RAV4 LTD V6 4WD 100K
DK327 is offline   Reply With QuoteReply With Quote
Old 11-12-2019, 06:35 PM #17
T4R2014's Avatar
T4R2014 T4R2014 is offline
T4R2014 is a splendid one to behold T4R2014 is a splendid one to behold T4R2014 is a splendid one to behold T4R2014 is a splendid one to behold T4R2014 is a splendid one to behold T4R2014 is a splendid one to behold
T4R2014's Avatar
Originally Posted by DK327 View Post
Right on, when I replaced mine I went with Koyorad from Amazon and I guess got lucky that it wasn't damaged during shipping. It's been going strong for 30K so far and I've already flushed the coolant once, at 15K miles. I also have an inline trans cooler, I opted to NOT bypass, since the rad is new.
I'm thinking you have a regular plastic tank Koyo. I'm speaking of the all aluminum they just released this year. Only downside is that they didn't include the trans cooler so bypass in mandatory.
Old 11-12-2019, 06:37 PM #18
T4R2014's Avatar
T4R2014's Avatar
Yeah, I honestly see no problem with the factory cooler when not towing. Agreed better cooler than hotter.
Old 11-12-2019, 06:47 PM #19
twitchee2's Avatar
twitchee2 twitchee2 is offline
twitchee2 is on a distinguished road
twitchee2's Avatar
So I was in the same camp as you. My trans cooler actually came out of a 5.9 cummins from a junk yard ($18 if I remember correctly) and I ran just that cooler for close to 8+ years and never had a problem. it would sit at 140* in 85* ambient and spike to 160 if I got on it. Last winter I was driving through a -2*F section of road and my trans temp cooled off to 90*F after driving from Sacramento to Tahoe up hwy 80, it had 1.5hr to get to full operating temp.
That was too cold in my book. I installed that oil thermostat and its been great. Cruising on the hwy I sit at 159* as long as its not 100*+ outside then will spike to 185 if I jump on it to pass someone or climb a long grade with the torque converter unlocked. I did a quick cool down time using my scan gauge and a stopwatch in my head. The scan gauge will report 185* and cool back down to 165* is about 7s, having excess cooling is a great thing!
I doubt it was the only reason but noticed a pretty significant mpg gain but I do not know if that was related to something else, who knows.
I do agree with you, it is better to have a cold trans than hot, but I also think there is a better way to control the temperature rather just let it get as cold as possible.
2002 SR5 4WD
deckplate + ISR, Airlift 1000, OME 881/890, Goodyear Wrangler Duratrac 265/75/16C
Tundra 231mm Brakes - yes they DO fit the stock 5 spoke rims - Stubbs Welding HD-SKO sliders.
twitchee2 is offline   Reply With QuoteReply With Quote
Old 11-12-2019, 06:53 PM #20
Bad Luck Bad Luck is offline
Real Name: Patrick
Real Name: Patrick
The dealer sells the same Chinese made POS you would buy at autozone. You can buy an legitimate OEM for $600 shipped from Partsouq, at that money you could have a Koyo aluminum with an external cooler! But maybe $600 is a steal since it lasts 20 years when maintained.
I got an OEM one from my local toyota dealership for $200.
Old 11-12-2019, 07:03 PM #21
T4R2014's Avatar
T4R2014's Avatar
And where was it made? At $200, definitely not Japan. Like I said, legitimate OEM meaning exactly what it came from the factory with.
Old 11-12-2019, 08:20 PM #22
BoomerBob's Avatar
BoomerBob BoomerBob is offline
BoomerBob will become famous soon enough BoomerBob will become famous soon enough
BoomerBob's Avatar
I found a link to this all aluminum 3 row radiator but they are always out of stock. Do you know of another place that has them in stock normally?
I'm thinking I may move the new Denso radiator I installed in the 01 to the 98 since it probably needs one anyway and get one of these 3 row aluminum ones for the 01 since it's my keeper.
Also; I wonder if this 88-95 2-row aluminum radiator could be retrofitted for the 3rd gen 4runners. The price is decent enough. The inlet and outlets are in the right spot but I don't know about the hose size and if the mounting holes line up. Any experts here know?
3rd gen Denso:
2001 2wd - Daily Driver
BoomerBob is offline   Reply With QuoteReply With Quote
Old 11-12-2019, 11:27 PM #23
negusm negusm is offline
negusm will become famous soon enough
Call them. They probably need to special order it which is why they don't stock it.
negusm is offline   Reply With QuoteReply With Quote
Old 11-12-2019, 11:43 PM #24
BoomerBob's Avatar
BoomerBob's Avatar
Probably right. They are likely made to order so they don't have a bunch sitting around taking up space if they don't sell that many.
Old 11-13-2019, 01:05 AM #25
Boudin's Avatar
Boudin Boudin is offline
Boudin is on a distinguished road
Boudin's Avatar
Well decided to buy local to verify condition and put an end to this returning madness. Went with one from Advance auto, Carquest brand, $107 with 25% coupon with tax. Looks exactly like every other radiator on the aftermarket. Trans fittings were tight, mounting holes and hangers lined up perfect, threads were clean, no broken nipple or damaged fins. Literally took 20 minutes to swap out.
Multiple extensions and wobblers make accessing the mounting holes through the grille and bumper a breeze.
We'll see how it holds up.
Prior to changing I a ran a bottle of Thermocure from Evaporust. Seemed to work really well.
Now, we're do I position the jiggler on the OEM thermostat? Bypass radiotor instead of replacing?Bypass radiotor instead of replacing?
Sent from my SM-G965U using Tapatalk
Boudin is offline   Reply With QuoteReply With Quote
Old 11-13-2019, 01:26 AM #26
Did you get the one with lifetime warranty? I just swapped one in to Advance for a free replacement. No questions asked.
Old 11-13-2019, 08:55 AM #27
Boudin's Avatar
Boudin's Avatar
I didn't even think to ask but I just checked online and it sure does fall under the limited lifetime warranty. That's great.
Old 11-13-2019, 09:55 AM #28
Real Name: Patrick
Real Name: Patrick
You'd have to ask Toyota, but it was OEM toyota. Came with the toyota part number sticker and everything on the box.
Old 11-13-2019, 09:56 AM #29
Real Name: Patrick
Real Name: Patrick
Jiggle valve goes at the 6 o'clock position per the factory service manual instructions.
Old 11-13-2019, 01:35 PM #30
T4R2014's Avatar
T4R2014's Avatar
You got the Taiwan one.
Lifetime warranty usually means you will spend a lifetime returning and replacing. They tend to last 4-5 years of normal driving in my experience.
bypass , cooler , good , radiator , trans
Oil Bypass - Should I? TravisT Maintenance/Detailing 3 07-25-2013 12:09 AM
Does Toyota recommend replacing the TB tensioner when replacing the TB? tsonnenl 4th Gen T4Rs 2 03-16-2012 10:34 AM
Brake Bypass kclancy00 Engines / Suspension / Wheels / Tires / Audio / Accessories 5 10-15-2010 08:35 AM
JBL Amp bypass clogee Engines / Suspension / Wheels / Tires / Audio / Accessories 0 08-22-2006 01:47 PM
ByPass Kits Fatty Engines / Suspension / Wheels / Tires / Audio / Accessories 1 10-13-2004 08:50 PM
