Originally Posted by The Cold War Kid
Radiator cap. Controls/releases pressure in radiator. Other possibility is sudden and catastrophic head gasket failure.
Which is why I won't ever truly know what happened because the overheating caused serious warping of the heads.
The egg or the chicken; which was first? Did the cap or something else cause the hose to blow or did the head gasket(s) blow and cause the overheating? It's possible the new cap worked correctly but also put a higher pressure into the cooling system causing an already weak gasket to blow. The old cap was quite tired with a weak spring which is why I replaced it. Better the engine blew close to home than on a road trip though.
In my case it's a moot point. Water under the bridge. I do wish I could have learned something from the experience other than how to tear down the top end of a 3.4L T4R engine.
It does reinforce my belief in being proactive with maintenance as much as possible though so I guess that's something. I think it's better to fix something that's not broken (yet) than wait for it to leave me stranded because I was too cheap or lazy to do basic maintenance.
I do think the alarm on the Ultragauge for coolant temps is worth triple its weight in gold. Two out of my 3 cars now have them. The 3rd will soon. The Ford F150 I had overheated once but it had a safety feature that put it into a "limp mode" which prevents catastrophic damage. I wish our Toyota's had something similar.
Live and learn I suppose...
