11-12-2019, 11:16 PM
first year 4Runner to get second generation airbags?
Anyone know? I know a lot of passenger cars started getting them in 1998. Thanks
11-13-2019, 12:09 AM
Not sure. However, I do know that beginning in 2000 or 2001, Toyota added a weight sensor to the passenger side seat that disables the airbag if it falls below a certain weight (IIRC below 79 lbs), which it interprets as a child occupying the seat.
11-13-2019, 12:49 AM
later 1998's and all 1999's had them, from what I've read
1997 4x4 SR5 3" Lift @254,000 miles
I welded my own bumper!
11-13-2019, 11:47 AM
This sounds right. Any way to verify on the vehicle itself? I don't see anything in the 98 or 99 owners manuals.
If it's the new style (98+) steering wheel do you just assume it's been fitted with second gen airbags?
11-13-2019, 01:48 PM
Real Name: Jerod
Real Name: Jerod
The part number for the airbags changed in 1998. Prior to that they used a different part. I'd assume that's when the change happened. Oddly enough, 2002's have a different part number for the airbags as well though.
11-13-2019, 05:17 PM
Steering wheel shape changed in '98 - not sure if it was driven by an airbag change or the airbag change was driven by the steering wheel shape change...
'17 Chevy Volt Premier
'16 Honda Odyssey Elite
11-13-2019, 05:52 PM
My guess is the second generation airbag design necessitated a change in the steering wheel, but have not been able to confirm.
11-13-2019, 06:47 PM
My 96 has both airbags.
1996 4Runner with a 3rz-fe, e-locker and 5spd
2005 Passat TDI 5spd swapped
1997 E350 4x4 7.3 Powerstroke
11-13-2019, 07:21 PM
Originally Posted by brillo_76
No they are asking when the 2nd Gen Airbags came out. Not airbags in general..;) Best answer so far is mid 1998..
I misread it too. 1996 through 1998 early half of the year are 1st gen airbags. ;)
My bad, so whats the difference, weight sensor and an off switch? Or is the bag itself different?
11-13-2019, 07:44 PM
The bag/inflator itself. Gen 1 airbags inflated with much more force and are possibly dangerous to smaller people. Gen 2 airbags are safer for smaller passengers. Only later (gen 3 or 'advanced' airbags) ones got multi-stage squibs, etc.
11-13-2019, 08:36 PM
Yep I want the Gen 2 for the wife and kids.
